What do you mean by patch, here? Do you mean the suggestions from your previous post or the package I recently put out?arnab.roy wrote:Please withdraw this patch if you released it completely breaks snmptrap handling. As snmptraphandling.py is never called so nagios never receives the processed traps !!!!!
Nagios XI SNMPTT install script issues
Re: Nagios XI SNMPTT install script issues
The previous RPM package, as well as any modifications.....the problem seems to be nothing is getting into nagios.cmd I added some debug to see if snmptraphandling.py is getting called or not and found it is not I couldnt find any reference to snmptraphandling.py in snmptthandler script so not sure how it writes the trap events into nagios....
Okay, I would just like to verify some things. The RPM package currently doesn't do proper trap translation for you, nor does it pass traps to Nagios. The changes you mentioned earlier get trap translation to function, but they still don't integrate with Nagios. Is that correct?
Also, are you sure your custom OPTIONS line is even doing anything? If you have the snmptt package installed, that line should be getting overrided by /etc/sysconfig/snmptrapd or /etc/sysconfig/snmptrapd.options (depending on your distro version).
Digging deeper if i look for output from snmptt it looks like this
karma-rbht snmptt[0]: healthMonDeviceTrap Normal "Status Events" 192.168.11.1 - Device-level rising/falling threshold crossing trap. noChange noChange noChange crossedBelowThreshold noChange noChange
As you can see its not printing the name of the service so I have a feeling some variable has got messed up ...somewhere
...will try back tracking all the changes and see what happens...
OK re-installed Net-SNMP and your snmptt package which over wrote all my settings now I am back to a situtation where the trap oid is displayed in a numeric fashion and nothing is getting passed to Nagios...I am continuing to do some further tests and see whats going on...
ok I think this is what is happening for some reason the formatting on the output from snmptt has gone off and I am getting this
usage: services.py <HOST> <SERVICE> <SEVERITY> <TIME> <PERFDATA> <DATA>
Agent IP address was blank, so setting to the same as the host IP address of 172.20.0.14
Agent IP address (172.20.0.14) is the same as the host IP, so copying the host name: wireless-loopback.khipu-networks.com
wlsxUserEntryAttributesChanged Normal "Status Events" wireless-loopback - 2012-10-30,23:30:13.0,-1:0 0.0.0.0 0:17:23:11:80:5c 0:1a:1e:86:13:a0 Khipu-Technical-Area 0 0 4
Host IP address (2.0.1.42) could not be resolved by DNS. Variable $r / $R etc will use the IP address
Agent IP address was blank, so setting to the same as the host IP address of 2.0.1.42
Agent IP address (2.0.1.42) is the same as the host IP, so copying the host name: 2.0.1.42
wlsxAuthServerReqTimedOut Normal "Status Events" 2.0.1.42 - bns2
wlsxAPRadioEntryChanged Normal "Status Events" wireless-loopback - 2012-10-30,23:30:22.0,-1:0 21699 0
86:68:cc:5f 1 modify
wlsxAPChannelChange Normal "Status Events" wireless-loopback - 2012-10-30,23:30:22.0,-1:0 11 none 6 none 0
86:68:cc:5f 1 Test-WCC armErrorThresh
wlsxNRadioAttributesChanged Normal "Status Events" wireless-loopback - 2012-10-30,23:30:22.0,-1:0 0
86:68:cc:5f 0 10.10.10.40 11 40
wlsxAPRadioEntryChanged Normal "Status Events" wireless-loopback - 2012-10-30,23:30:26.0,-1:0 21700 0:24:6c:c2:2b:40 1 modify
Hi Guys...
Any idea whats going on ? I would like to go back to old style install of snmptt , would it be possible to get the old install script back ...
For everyones benefit ...the trap handler into nagios is broken in this package please replace it with the attached and that should fix it
Note for Alex: Please upload this into the rpm to finally put this to grave / the previous modifications in snmptt.ini are important and should be done for proper trap translation ...
What I've noticed is that the NagiosXI-SNMPTrap.sh (downloaded from here http://assets.nagios.com/downloads/nagi ... rap.tar.gz 20121031) is broken.
/etc/rc.d/init.d/snmptt is both used a a file (last line with sed e.g.) and as a directory (cp ./snmptt_${snmpttver}/snmptt-init.d /etc/rc.d/init.d/snmptt/) ? I think this is what arnab.roy is experiencing here.
# Install the SNMP trap translator
snmpttver=1.3
wget http://superb-sea2.dl.sourceforge.net/project/snmptt/snmptt/snmptt_${snmpttver}/snmptt_${snmpttver}.tgz
tar -xzf snmptt_${snmpttver}.tgz
cp ./snmptt_${snmpttver}/snmptt \
./snmptt_${snmpttver}/snmptthandler /usr/local/sbin/
cp ./snmptt_${snmpttver}/snmptt.ini /etc/snmp/
cp ./snmptt_${snmpttver}/snmpttconvertmib /usr/local/bin/
sed -i 's_/usr/sbin_/usr/local/sbin_' /etc/rc.d/init.d/snmptt
The fix should be to remove the / at the end of /etc/rc.d/init.d/snmptt to signify it's not a directory.arnab.roy wrote:Ok just tried the new version and
Mind you this system already had the previous installer run on it....Code: Select all
oaded plugins: fastestmirror, security Determining fastest mirrors epel/metalink | 18 kB 00:00 * base: mirrors.coreix.net * epel: mirrors.coreix.net * extras: mirrors.coreix.net * rpmforge: www.mirrorservice.org * updates: mirrors.coreix.net base | 3.7 kB 00:00 cr | 3.0 kB 00:00 epel | 4.3 kB 00:00 epel/primary_db | 4.7 MB 00:01 extras | 3.0 kB 00:00 rpmforge | 1.9 kB 00:00 rpmforge/primary_db | 2.5 MB 00:00 updates | 3.5 kB 00:00 updates/primary_db | 3.4 MB 00:01 vmware-tools | 951 B 00:00 Setting up Install Process Package 1:net-snmp-5.5-41.el6_3.1.x86_64 already installed and latest version Package rpmdevtools-7.5-1.el6.noarch already installed and latest version Package 1:net-snmp-perl-5.5-41.el6_3.1.x86_64 already installed and latest version Package perl-Config-IniFiles-2.72-2.el6.noarch already installed and latest version Nothing to do --2012-10-18 20:03:13-- http://superb-sea2.dl.sourceforge.net/project/snmptt/snmptt/snmptt_1.3/snmptt_1.3.tgz Resolving superb-sea2.dl.sourceforge.net... 209.160.57.180 Connecting to superb-sea2.dl.sourceforge.net|209.160.57.180|:80... connected. HTTP request sent, awaiting response... 200 OK Length: 146314 (143K) [application/octet-stream] Saving to: `snmptt_1.3.tgz' 100%[=======================================================================================================================================>] 146,314 157K/s in 0.9s 2012-10-18 20:03:14 (157 KB/s) - `snmptt_1.3.tgz' saved [146314/146314] cp: cannot create regular file `/etc/rc.d/init.d/snmptt/': Is a directory
Can you guys kindly test this please....
snmpttver=1.3
I've troubleshooted some more now:
Trap entering on interface:
A reverse lookup on the source IP of the trap from Nagios:
/var/log/snmptt/snmptt.log file:
I hooked the snmptraphandling.py script to print the sys.argv variable received from snmptt:
When I ran the command on the CLI, writes to /usr/local/nagios/var/rw/nagios.cmd without problem. However, no trap appears in the trap service of the host. But when I change the first argument to the script to contain the FQDN instead of just the hostname:
It works. The trap appears to my host in Nagios. However, it's not translated. I have translated the appropriate MIB into /etc/snmp/snmptt.conf:
Then I noticed this directive in /etc/snmp/snmptt.ini:
Changed it to 0. Now traps are shown in Nagios for my hosts. However, they are not translated. My snmptt.ini is configured according to the previous posts in this thread. Any suggestions as how to troubleshoot translations would be welcome.
Edit: I've tried with traps from other vendors and they are translated just fine. I think I've been provided the wrong MIB for the Aruba system I initially tried to traps from.
# tcpdump -i eth1 -n udp port 162
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on eth1, link-type EN10MB (Ethernet), capture size 65535 bytes
14:23:40.419449 IP 10.254.30.12.32789 > 10.232.130.65.snmptrap: C=obfuscated V2Trap(201) .1.3.6.1.2.1.1.3.0=1881160600 .1.3.6.1.6.3.1.1.4.1.0=.1.3.6.1.4.1.14823.2.3.1.11.1.2.1224 .1.3.6.1.4.1.14823.2.3.1.11.1.1.60=07_dc_0b_01_0f_0c_14_00_2b_01_00 .1.3.6.1.4.1.14823.2.3.1.11.1.1.53.0="fakeloginname" .1.3.6.1.4.1.14823.2.3.1.11.1.1.51.0=10.232.120.1 .1.3.6.1.4.1.14823.2.3.1.11.1.1.26.0="obfuscated"
;; QUESTION SECTION:
;12.30.254.10.in-addr.arpa. IN PTR
;; ANSWER SECTION:
12.30.254.10.in-addr.arpa. 3600 IN PTR hostname.zonename.
Thu Nov 1 14:23:40 2012 .1.3.6.1.4.1.14823.2.3.1.11.1.2.1224 Normal "Status Events" hostname - 07 DC 0B 01 0F 0C 14 00 2B 01 00 fakeloginname obfuscated-ip obfuscated-fqdn
/usr/local/bin/snmptraphandling.py "hostname" "SNMP Traps" "Normal" "1351767722" "enterprises.14823.2.3.1.11.1.1.60 ():07 DC 0B 01 0C 32 28 00 2B 01 00 enterprises.14823.2.3.1.11.1.1.53.0 ():fakeloginname enterprises.14823.2.3.1.11.1.1.51.0 ():10.232.120.1 enterprises.14823.2.3.1.11.1.1.26.0 ():obfuscated-fqdn" " 07 DC 0B 01 0C 32 28 00 2B 01 00 fakeloginname obfuscated-ip obfuscated-fqdn"
/usr/local/bin/snmptraphandling.py [b]"FQDN"[/b] "SNMP Traps" "Normal" "1351767722" "enterprises.14823.2.3.1.11.1.1.60 ():07 DC 0B 01 0C 32 28 00 2B 01 00 enterprises.14823.2.3.1.11.1.1.53.0 ():fakeloginname enterprises.14823.2.3.1.11.1.1.51.0 ():10.232.120.1 enterprises.14823.2.3.1.11.1.1.26.0 ():obfuscated-fqdn" " 07 DC 0B 01 0C 32 28 00 2B 01 00 fakeloginname obfuscated-ip obfuscated-fqdn"
EVENT wlsxNUserAuthenticationFailed .1.3.6.1.4.1.14823.2.3.1.11.1.2.1018 "Status Events" Normal
FORMAT $*
EXEC /usr/local/bin/snmptraphandling.py "$r" "SNMP Traps" "$s" "$@" "$-*" " $*"
SDESC
This trap indicates that a user authentication has failed.
Variables:
1: wlsxTrapTime
2: wlsxTrapUserIpAddress
3: wlsxTrapUserPhyAddress
EDESC
strip_domain = 1
