Nagios on XenServer 5.5
Re: Nagios on XenServer 5.5
Build the nagios-plugins source as you will most likely want them: http://www.nagios.org/download/plugins/
http://sourceforge.net/projects/nagiosplug/
brianweeks22
but im still receiving this w/in nagios
CHECK_NRPE: Error - Could not complete SSL handshake.
Yes, but we are helping you get the system set up properly, we should do this all in order so that you do not run into more issues down the road when they could have been fixed today
We will be able to work on the handshake issue once we get the rest of your system up to spec so to speak, and running in a stable environment. Of course, if you would like to work on this first we certainly can, it is just recommended to get everything up to speed before configuring external checks.
Can you telnet/nmap port 5666 on the remote host from the nagios server? Is it open?
brianweeks22
Yes.. I can telnet
Alright, lets run check_nrpe from the nagios server to the remote host from the cli:
On the nagios server:
You should receive the nrpe version on the remote host.
/usr/local/nagios/libexec/check_nrpe -H <ip of remote host> Former Nagios employee
brianweeks22
under /usr/local/nagios/libexex i only have
check_myssql_health and check_proc_meminfo
I am running 3 other VM's that ARE reporting to nagios correctly tho.. could check_nrpe be in another locatioN
Brian
Brian
Are they reporting through nrpe or some other mechanism? (passive checks, etc) You nagios server should have a plugins directory. You could check /usr/lib or /usr/lib64 for the directories "plugins" or "libexec". Inside that folder you should have the plugin "check_nrpe".
brianweeks22
plugin directory at /usr/lib/nagios/plugins
this is the output from the previous cmd you wanted me to run:
[root@rodan2 nagios]# /usr/lib/nagios/plugins/check_nrpe -H <IP ADDRESS OF SERVER>
Lets check if ssl is the issue (the "-n" disables ssl for the test):
Is nrpe started on the remote host?
/usr/lib/nagios/plugins/check_nrpe -H <IP ADDRESS OF SERVER> -nCode: Select all
service nrpe status
service xinetd statusFormer Nagios employee
