Am in the middle of constructing a test setup of Nagios 4 on openSUSE 13.1 ahead of my retool of the works system on 3.2.3 under openSUSE 11.4. As has been mentioned above, the /etc/init.d/nagios file that is generated fails miserably but I found this post, which was a start. The two problems I have with is are that I have no "daemon" command available and I have no "status_of_proc" command available. The latter of these isn't so much of a bother as it doesn't appear to affect the running of the Nagios daemon once you can.magna.vis wrote:Looks like this guy may have some input as well: http://roger.steneteg.org/492/installin ... om-source/
I'm also thinking about cloning my current setup, and upgrading without doing the make install-init command and seeing if it still works. If I get around to it in the next couple of days, I'll post my results.
And here it is in code brackets:Code: Select all
#! /bin/sh ### BEGIN INIT INFO # Provides: nagios # Required-Start: $remote_fs $syslog # Required-Stop: $remote_fs $syslog # Default-Start: 2 3 4 5 # Default-Stop: 0 1 6 # Short-Description: start and stop Nagios monitoring server # Description: Nagios is a service monitoring system ### END INIT INFO # Author: Foo Bar <[email protected]> # # Please remove the "Author" lines above and replace them # with your own name if you copy and modify this script. # Do NOT "set -e" # PATH should only include /usr/* if it runs after the mountnfs.sh script PATH=/sbin:/usr/sbin:/bin:/usr/bin DESC="Nagios monitoring system" NAME=nagios PREFIX=/srv/nagios STATEDIR=/var/nagios CONFIGDIR=/etc/nagios CONFIGFILE="$CONFIGDIR/nagios.cfg" DAEMON="${PREFIX}/bin/${NAME}" DAEMON_ARGS="-d $CONFIGFILE" SCRIPTNAME=/etc/init.d/$NAME PIDFILE=/var/run/$NAME.pid USER="nagios" GROUP="nagios" # Exit if the package is not installed [ -x "$DAEMON" ] || exit 0 # Read configuration variable file if it is present [ -r /etc/default/$NAME ] && . /etc/default/$NAME # Load the VERBOSE setting and other rcS variables . /lib/init/vars.sh # Define LSB log_* functions. # Depend on lsb-base (>= 3.2-14) to ensure that this file is present # and status_of_proc is working. . /lib/lsb/init-functions check_config() { RESULTFILE="$STATEDIR/configcheck$$" CHECKRESULT=`$DAEMON -v $CONFIGFILE > $RESULTFILE` WARN=`grep ^"Total Warnings:" $RESULTFILE | awk -F: '{print $2}' |sed s/' '//g` ERR=`grep ^"Total Errors:" $RESULTFILE | awk -F: '{print $2}' |sed s/' '//g` if test "${WARN}" = "0" && test "${ERR}" = "0"; then echo "OK - Configuration check verified" return 0 else cat $RESULTFILE exit 8 fi } # # Function that starts the daemon/service # do_start() { # Return # 0 if daemon has been started # 1 if daemon was already running # 2 if daemon could not be started test -x $DAEMON || exit 2 test -f $CONFIGGILE || exit 2 if test "$1" = "checkconfig"; then check_config fi echo -n "Starting $NAME .." start-stop-daemon --start --quiet --pidfile $PIDFILE --exec $DAEMON --test > /dev/null || return 1 start-stop-daemon --start --quiet --make-pidfile --pidfile $PIDFILE --exec $DAEMON -- $DAEMON_ARGS || return 2 echo ". $NAME started" } # # Function that stops the daemon/service # do_stop() { # Return # 0 if daemon has been stopped # 1 if daemon was already stopped # 2 if daemon could not be stopped # other if a failure occurred echo -n "Stopping $NAME .." # start-stop-daemon --stop --quiet --retry=5 --pidfile $PIDFILE --name $NAME # RETVAL="$?" # [ "$RETVAL" = 2 ] && return 2 # Wait for children to finish too if this is a daemon that forks # and if the daemon is only ever run from this initscript. # If the above conditions are not satisfied then add some other code # that waits for the process to drop all resources that could be # needed by services started subsequently. A last resort is to # sleep for some time. start-stop-daemon --stop --quiet --oknodo --retry=5 --exec $DAEMON RETVAL="$?" [ "$RETVAL" = 2 ] && return 2 # Many daemons don't delete their pidfiles when they exit. rm -f $PIDFILE echo ". $NAME stopped" return "$RETVAL" } # # Function that sends a SIGHUP to the daemon/service # do_reload() { # # If the daemon can reload its configuration without # restarting (for example, when it is sent a SIGHUP), # then implement that here. # check_config # This does not seem to be working #start-stop-daemon --stop --signal HUP --quiet --pidfile $PIDFILE --name $NAME echo "There is something wrong with the reload function, use restart instead" return 0 } case "$1" in start) [ "$VERBOSE" != no ] && log_daemon_msg "Starting $DESC" "$NAME" do_start "checkconfig" case "$?" in 0|1) [ "$VERBOSE" != no ] && log_end_msg 0 ;; 2) [ "$VERBOSE" != no ] && log_end_msg 1 ;; esac ;; stop) [ "$VERBOSE" != no ] && log_daemon_msg "Stopping $DESC" "$NAME" do_stop case "$?" in 0|1) [ "$VERBOSE" != no ] && log_end_msg 0 ;; 2) [ "$VERBOSE" != no ] && log_end_msg 1 ;; esac ;; status) status_of_proc "$DAEMON" "$NAME" && exit 0 || exit $? ;; reload) # # If do_reload() is not implemented then leave this commented out # and leave 'force-reload' as an alias for 'restart'. # log_daemon_msg "Reloading $DESC" "$NAME" do_reload log_end_msg $? ;; restart) # # If the "reload" option is implemented then remove the # 'force-reload' alias # log_daemon_msg "Restarting $DESC" "$NAME" check_config do_stop case "$?" in 0|1) do_start case "$?" in 0) log_end_msg 0 ;; 1) log_end_msg 1 ;; # Old process is still running *) log_end_msg 1 ;; # Failed to start esac ;; *) # Failed to stop log_end_msg 1 ;; esac ;; *) echo "Usage: $SCRIPTNAME {start|stop|restart|reload|force-reload}" >&2 exit 3 ;; esac
The change I made, however, to actually get it started was to whip out the "daemon" command at line 82 and replace it with
startproc -u $user -- $exec -d $config
