Nagios Map
abrist
Red Shirt
Re: Nagios Map
Post by abrist »
Did you run the following as well:
make install-cgis
diverseft
Re: Nagios Map
Post by diverseft »
Where do I make install-cgis?
Here is what i tried which no luck
mkdir tmp2
cd tmp2
wget http://prdownloads.sourceforge.net/sour ... 0.2.tar.gz
tar xzf nagios-4.0.2.tar.gz
cd nagios-4.0.2
./configure --with-command-group=nagcmd
make all
make install-cgis
make install
/etc/init.d/nagios restar
abrist
Red Shirt
Re: Nagios Map
Post by abrist »
From the source folder. Looks like it was right above.
ZaphoidPA
Re: Nagios Map
Post by ZaphoidPA »
I have just upgraded from 3.5 to 4.0.2, and noticed that whenever I go to my maps, trends of histogram, I get failure messages, specifically "Error: Could not read object configuration data!".
As I was looking around, I noticed that none of these files were updated when I built the new nagios core. They all have a date stamp of March, not today.
Looking in the cgi source directory, I see that none of these 3 files have been built.
root@nagios:~/nagios-4.0.2/cgi# ls -l histo*
-rw-rw-r-- 1 root root 83318 Nov 25 06:16 histogram.c
-rw-rw-r-- 1 root root 30100 Nov 25 06:16 history.c
-rwxr-xr-x 1 root root 634562 Dec 20 10:24 history.cgi
root@nagios:~/nagios-4.0.2/cgi# ls -l status*
-rw-rw-r-- 1 root root 208448 Nov 25 06:16 status.c
-rwxr-xr-x 1 root root 773457 Dec 20 10:24 status.cgi
-rw-r--r-- 1 root root 16836 Dec 20 10:24 statusdata-cgi.o
-rw-rw-r-- 1 root root 92851 Nov 25 06:16 statusmap.c
-rw-rw-r-- 1 root root 49853 Nov 25 06:16 statuswml.c
-rwxr-xr-x 1 root root 663870 Dec 20 10:24 statuswml.cgi
-rw-rw-r-- 1 root root 36263 Nov 25 06:16 statuswrl.c
-rwxr-xr-x 1 root root 640632 Dec 20 10:24 statuswrl.cgi
root@nagios:~/nagios-4.0.2/cgi# ls -l trends*
-rw-rw-r-- 1 root root 97395 Nov 25 06:16 trends.c
Is there an error in the Makefile that is stopping these modules from being built? As I look through the build spam, I don't even see these three modules being referenced.
sreinhardt
-fno-stack-protector
Re: Nagios Map
Post by sreinhardt »
I realize this is a similar issue zaphoid, but could you please create a new topic so that we can address this specifically for your environment.
diverseft
Re: Nagios Map
Post by diverseft »
Could I manually delete the status maps cgi's and then do another:
make all
make install-cgis
make install
/etc/init.d/nagios restart
abrist
Red Shirt
Re: Nagios Map
Post by abrist »
diverseft wrote:Could I manually delete the status maps cgi's and then do another:
[snip]
Yes, but I have a feeling that you are still missing a few dependencies for the map - probably gd/gd-devel. You should get a warning/error about this on compile - the text of the warning should be fairly noticeable on stdout.
diverseft
Re: Nagios Map
Post by diverseft »
So shall I do another make install and take a note of the any errors?
Re: Nagios Map
Post by slansing »
That would be beneficial, we need to make sure you are not missing anything. If you can ouput the contents of your commands to a text file that would be great. Then just upload it here when done.
diverseft
Re: Nagios Map
Post by diverseft »
http://pastebin.com/eKH5LnRL
make all
http://pastebin.com/s5cTLxtV
make install
http://pastebin.com/7Ci64uBf
