Could not complete SSL handshake (check_nrpe is fine)
Re: Could not complete SSL handshake (check_nrpe is fine)
On the client run something like:
/usr/local/nagios/bin/nrpe --help
NRPE - Nagios Remote Plugin Executor
Copyright (c) 1999-2008 Ethan Galstad ([email protected])
Version: 2.12
Last Modified: 03-10-2008
License: GPL v2 with exemptions (-l for more info)
SSL/TLS Available: Anonymous DH Mode, OpenSSL 0.9.6 or higher required
On the Nagios server run something like:
/usr/local/nagios/libexec/check_nrpe --help
NRPE Plugin for Nagios
Version: 2.12
Lets see the output of both, they should both say something like "SSL/TLS Available"
hazmat
Post by hazmat »
Thanks.
Client:
Version: 2.12
TCP Wrappers Available
Server:
Version: 2.12
Post by slansing »
Do you by any chance have another NRPE enabled system you can run a test against? One that was either compiled with SSL support or not?
hazmat
Post by hazmat »
Actually, this nagios server has been successfully monitoring a Windows server as well as a bunch of networked printers and switches.
I'll repeat the current setup for the monitoring.
nagios server:
check_command        check_nrpe!check_disk!-a '-w 20% -c 10% -p /var'
monitored client:
command[check_disk]=/usr/local/nagios/libexec/check_disk $ARG1$
hazmat wrote:Thanks again for the help here. I took the nagios install from the server and now I can run remote commands from the command line.
$ check_nrpe -H 1.2.3.4 -c check_disk -a '-w 20% -c 10% -p /var'
DISK OK - free space: /var 5418 MB (72% inode=99%);| /var=2107MB;6348;7141;0;7935
However, when I run via the application, I get "No output returned from plugin". This is the command I have in the cfg on the nagios server:
Thanks.
I am a little confused, if you can run this from the nagios server, where 1.2.3.4 is your client, then it really doesn't make any sense why you would get "No output returned from plugin" when run from Nagios if infact your check_nrpe command is set to
command_line    /usr/local/nagios/libexec/check_nrpe -n -H $HOSTADDRESS$ -c $ARG1$ $ARG2$
Is this correct?
hazmat
Post by hazmat »
Yeah, that's correct, but the error, at least now, is "CHECK_NRPE: Error receiving data from daemon". Not sure what else I should look at. The "command_line" statement should be in commands.cfg?
Thanks.
Post by slansing »
Yes, in nagios core you would set your command there and reference it across your services. We still need to know if you have another server with NRPE on it that you can test this against, you mentioned printers and switches... well they don't use NRPE. I was trying to ask if you could test this on a known, working, linux system with NRPE on it.
hazmat
Post by hazmat »
I tried it on another Linux machine in the same data center and am getting the same errors. I'm finding it hard to believe that it's a networking issue, though, since running check_nrpe from the command line of the nagios server gets the proper results. So I'm guessing it's a configuration problem. Here's what I have.
From commands.cfg:
From the client's config on the nagios server:
From nrpe.cfg on the client machine:
Thanks as always.
Here, you are not passing "-n" flag...
but here, you are...
hazmat
Post by hazmat »
Holy crap that did it. THANK YOU!
