check_snmp not working but snmpget works
rhassing
Re: check_snmp not working but snmpget works
Post by rhassing »
I'm sorry, but I'm out of options.
I've got no idea what could still be wrong :-(
Rob Hassing
abrist
Red Shirt
Post by abrist »
Can you post a log of the full configure and make processes?
Kerflumpre
Post by Kerflumpre »
Before I post the wrong stuff, you mean for Nagios and the plugins?
abrist
Red Shirt
Post by abrist »
nagios-plugins specifically. I want to see if there were any issues in the check_snmp configure or build.
Kerflumpre
Attached
putty-nagios-plugins.log
(136.84 KiB) Downloaded 491 times
sreinhardt
-fno-stack-protector
Post by sreinhardt »
It does look like it was unable to find net-snmp libraries according to the config, in fact it looks like few important things were not detected:
configure: WARNING: Tried /usr/bin/perl - install Net::SNMP perl module if you want to use the perl snmp plugins
configure: WARNING: OpenSSL or GnuTLS libs could not be found or were disabled
Let's just check one more time for those:
dpkg --get-selections | grep -v deinstall | grep -i 'net-snmp\|openssl'
Kerflumpre
root@nagios-core:~/downloads/nagios-plugins-2.0.3# dpkg --get-selections | grep -v deinstall | grep -i 'net-snmp\|openssl'
openssl                                         install
rhassing
Post by rhassing »
I'm missing libnet-snmp-perl, that is also installed on my system.
Rob Hassing
Kerflumpre
I installed it and recompiled the plugins. No change.
abrist
Red Shirt
Post by abrist »
Can you post the new build log?
