Error No data found
mgallamore
Re: Error No data found
Post by mgallamore »
Looks like we are having the same issue with a evaluation setup of NNA 2R1.0 with our ASA 5520 running ios 9.1.3, while our Cisco 6509 are working perfect.
nfdump -r
2015-04-03 14:09:20.282     0.000 TCP     192.168.220.57:55550 ->   54.225.150.195:443          0     2978     1
2015-04-03 14:09:36.971     0.000 TCP     192.168.220.57:55589 ->    23.12.251.197:443          0      576     1
2015-04-03 14:09:36.971     0.000 TCP     192.168.220.57:55590 ->    23.12.251.197:443          0      576     1
1969-12-31 18:00:00.56344   -56.344 TCP     192.168.220.57:55590 ->    23.12.251.197:443          0        0     1
2015-04-03 14:09:38.971     0.000 TCP     192.168.220.57:55594 ->    216.249.24.56:443          0      576     1
2015-04-03 14:09:41.151     0.000 TCP     192.168.220.57:55598 ->    216.249.24.56:443          0      576     1
2015-04-03 14:09:32.641     0.000 TCP     192.168.220.57:55581 ->    50.97.233.185:443          0      576     1
We have our network time all in sync as that was my first thought but i've hit a roadblock on this. Issue is we are attempting to replace another monitoring solution which works fine with the ASA in question.
Can you edit the settings in the Cisco ASA to match our default settings that are known to work.
flow-export destination inside XXX.XXX.XXX.XXX YYYY
flow-export template timeout-rate 1
flow-export delay flow-create 60
logging flow-export-syslogs disable
access-list netflow-export extended permit any any
class-map netflow-export-class
	match access-list netflow-export
policy-map global-policy
class netflow-export-class
	flow-export event-type all destination XXX.XXX.XXX.XXX
Where XXX.XXX.XXX.XXX is the IP address of the NA server
Where YYYY is the port used on the NA server
mgallamore
Running into the same issue with those settings. Been playing with the setting for a couple days and cant get past that 1969 time stamp and the time window unknown on the nfdump
Setting active during my last port
flow-export destination inside x.x.x.x 10000
flow-export delay flow-create 20
access-list global_mpc extended permit ip any4 any4
class-map Netflow
match access-list global_mpc
policy-map global_policy
class Netflow
  flow-export event-type all destination x.x.x.x
Test setting and result
class-map Netflow
class Netflow
nfdump -r
2015-04-07 07:24:56.257     0.000 ICMP   192.168.181.110:0     ->   192.168.220.50:2.0          0       32     1
2015-04-07 07:24:56.257     0.000 ICMP   192.168.181.110:0     ->   192.168.220.57:2.0          0       32     1
2015-04-07 07:24:56.257     0.000 ICMP   192.168.181.110:0     ->   192.168.220.58:2.0          0       32     1
1969-12-31 18:00:00.000     0.000 TCP    192.168.220.217:54801 ->     66.210.135.6:443          0        0     1
2015-04-07 07:24:57.427     0.000 UDP    192.168.222.131:53125 ->  192.168.190.190:53           0       42     1
2015-04-07 07:24:58.337     0.000 TCP    192.168.220.132:55361 ->     172.16.11.35:10081        0      117     1
2015-04-07 07:24:56.387     0.000 TCP    192.168.181.100:63136 ->  192.168.221.170:49152        0    4.4 M     1
2015-04-07 07:24:28.488     0.000 TCP    192.168.220.234:57970 ->    10.83.170.141:9301         0        0     1
2015-04-07 07:24:58.517     0.000 UDP     192.168.220.35:61687 ->  192.168.190.190:53           0       42     1
1969-12-31 18:00:00.000     0.000 TCP     192.168.222.54:55888 ->     66.210.135.6:443          0        0     1
2015-04-07 07:24:13.359     0.000 TCP    192.168.181.100:63112 ->  192.168.221.170:49152        0  351.6 M     1
2015-04-07 07:24:59.257     0.000 ICMP   192.168.181.110:0     ->   192.168.220.20:2.0          0       32     1
Summary: total flows: 14473, total bytes: 2695001176, total packets: 0, avg bps: 15, avg pps: 0, avg bpp: 0
Time window: Time Window unknown
Total flows processed: 14473, Blocks skipped: 0, Bytes read: 868828
Sys: 0.247s flows/second: 58367.8    Wall: 0.420s flows/second: 34378.1
I am going to try and recreate the issue. It might take a while.
sput
Post by sput »
I am having the exact same issue with two ASA's running 9.2.2(4) -- netflow works fine with PRTG but not getting any data in Nagios. Bandwidth graphs show up fine. I'm also seeing random entries in nfdump showing a date of 1969-12-31. Has anyone found a fix for this yet? Please advise!
jolson
Attack Rabbit
Post by jolson »
mgallamore, sput,
It's possible that this issue is cropping up with devices that use NSEL - Cisco's netflow variant for ASA devices. This is different than normal netflow, and can require a special option to be enabled when nfdump is compiled.
Please note that you may lose previous flow information by performing this procedure.
To enable NSEL support in nfdump:
cd /tmp
wget http://sourceforge.net/projects/nfdump/files/stable/nfdump-1.6.13/nfdump-1.6.13.tar.gz/download
tar xzf download
cd nfdump-1.6.13/
./configure --enable-sflow --enable-nsel
make
make install
You can check whether NSEL support is on with the following command:
nfdump -V
We can easily revert to the previous nfdump version if the above does not work. Any test results you guys could provide could be a big help.
Twits Blog
sput
Post by sput »
You are the BEST jolson! This fixed the issue for me :)
Thank you so much!
Great to hear!
We'll leave this open for mgallamore to test and respond.
mgallamore
Jolson, that did the trick for us as well. got 5 ASA reporting netflow now.
Thanks for the help.
I'll be closing this thread now, but feel free to open another if you need anything in the future!
