logstash daemon stopping
benhank
Re: logstash daemon stopping
Post by benhank »
I did try the fixes last week and my partner redid them on monday. the logfile i sent was from this morning
Proudly running:
Nagios Network Analyser
Nagios Fusion
Then you may be hitting a different limit.
Lets edit the following file, /etc/sysconfig/logstash
change this
#LS_OPEN_FILES=2048
to this
LS_OPEN_FILES=4096
and restart logstash
service logstash restart
Do this on all instances
benhank
Post by benhank »
done. here is a partial log file from /var/log/logstash/logstash.log
Proudly running:
Nagios Fusion
Ok, not it seems like there is more than one logstash process running... Ugh.
Lets do this
service logstash stop
ps -ef|grep logstash
If you get ANY processes, you are going to have to kill them
Then,
service logstash start
benhank
Post by benhank »
done Ill update you as time passes
Hey scott how does it work?
I have servers shooting logs to NLS. When the logstash daemon dies for whatever reason, are those logs still accumulating on the NLS server? t
How can I get the data that accumulated when the daemon was off? Is this even possible if there is only one instance running?
Proudly running:
Nagios Fusion
Logstash is the first link in the chain. It is responsible for listening on the ports, taking in the logs, processing them, and then sending them off to Elasticsearch for storage and retrieval. If Logstash is not running then nothing will get into Elasticsearch.
benhank
Post by benhank »
thanks!
Proudly running:
Nagios Fusion
Post by slansing »
Awesome, how are things looking now?
benhank
Post by benhank »
I gotta wait till tomorrow
Proudly running:
Nagios Fusion
cmerchant
Post by cmerchant »
We'll await your reply. Thanks.
