Problem with nagios and ndoutils
jdalrymple
Skynet Drone
Re: Problem with nagios and ndoutils
Post by jdalrymple »
eFusion wrote: ndo2db:
lock_file=/usr/local/nagios/var/ndo2db.lock
ndo2db_user=nagios
ndo2db_group=nagios
socket_type=unix
#socket_type=tcp
socket_name=/usr/local/nagios/var/ndo.sock
Not once...
eFusion wrote: /usr/local/nagios/var#
ls -lG
total 42
-rw-r--r--  1 nagios  nagios  86537 Mar  4 13:14 ndo2db.debug
but twice...
eFusion wrote: ls -lG /usr/local/nagios/var/
total 53
-rw-r--r-- 1 nagios nagios 110918 Mar 18 15:24 ndo2db.debug
No UNIX socket. Does the nagios user have rwx permissions for that /usr/local/nagios/var directory?
eFusion
Post by eFusion »
/usr/local/nagios]# ls -al
drwxr-xr-x   4 nagios  nagios   4 Feb 26 11:07 .
drwxr-xr-x  16 root    wheel   16 Feb 26 10:13 ..
drwxrwxr-x   2 nagios  nagios   9 Feb 26 10:49 bin
drwxrwxr-x   2 nagios  nagios   3 Mar 30 17:44 var
/usr/local]# ls -al
drwxr-xr-x  17 root    wheel    17 Nov 13  2013 ..
drwxr-xr-x   4 nagios  nagios    4 Feb 26 11:07 nagios
jdalrymple
Skynet Drone
What is inside /usr/local/nagios/var/ WHILE NAGIOS IS RUNNING is what matters. Without that socket ndo2db will not work.
--edit--
turned "lockfile" into "socket" ... oops
eFusion
Post by eFusion »
How to make the file appear?
Another thing: after start ndo2db in console and restart nagios, in nagios web-interface status of objects and services are not update unless kill ndo and restart nagios again. This is due to lack of file?
If you are killing the ndo2db service, that is why none of your host and services are being added to the MYSQL database. The ndo2db service is what puts them in there.
Start up the ndo2db and nagios services, let them run for a long time to see it they get updated. Since you have a lot to add to the database, it might take a while to do so.
While it it running, run the following to see if the ndo2db.lock and ndo.sock files are created.
ll /usr/local/nagios/var/
eFusion
Post by eFusion »
Launched ndo2db - wait awhile
jdalrymple
Skynet Drone
tgriep wrote:While it it running, run the following to see if the ndo2db.lock and ndo.sock files are created.
If they're not - ndo2db WILL NOT work.
