How do i edit the .RRD? i tried vi but it brings up a wall o text that i can't decipher.
Thanks.
Custom SNMP check
Re: Custom SNMP check
I think i got it. I PMed you the results.
It looks like the /usr/local/nagios/etc/pnp/check_commands/check_snmp_gauge.cfg file is corrupted, Try over writing it with this one that is attached to this post.
Do i need to go through the whole process again? I replaced the file and am waiting to see a difference. I am going to delete the rrd and the xml for the service.
The graph just updated. It looks like we are in business! I will keep an eye on this and apply the changes to my other effected services. Thanks for sticking in there with me and going the extra mile.
No problem. Glad to help.
