Problem with enabling notifications with postfix
Re: Problem with enabling notifications with postfix
Okay, the configuration to allow the ISP to gmail in my ubuntu in main.cf of postfix, would be the same in centos?
Yes.
But in the configuration of ubuntu i have this:
that cacert.pem is neccesary on centos?, because with the tutorial of ubuntu i cant see the certs
relayhost =[smtp.gmail.com]:587
smtp_sasl_auth_enable = yes
smtp_sasl_password_maps = hash:/etc/postfix/sasl_passwd
smtp_sasl_security_options = noanonymous
smtp_tls_CAfile = /etc/postfix/cacert.pem
smtp_use_tls = yes-
jdalrymple
- Skynet Drone
The directive smtp_tls_CAfile or smtp_tls_CApath will be required if you're using TLS. Without it postfix has no way to verify the certificate chain presented by the smtp server.
You would have to contact support at gmail for that.
Oh okay:/, can look this thread, very thanks!
