Unable to ACK (again)
- Box293
- Too Basu
Re: Unable to ACK (again)
Sorry for the long delay between posts.
I was finally able to upgrade NSCA to 2.9.1, but the issue persists...
Guess we're back to the drawing board?
Is the system receiving SNMP Traps from remote systems?
Can you run this and post the output when the issue is happening?
ps -ef
Here you go - had to snip out some of the system cruft as the ps was too big to paste
UID PID PPID C STIME TTY TIME CMD
root 1 0 0 May10 ? 00:00:04 /sbin/init
root 2 0 0 May10 ? 00:00:00 [kthreadd]
apache 627 3060 6 08:53 ? 00:01:43 /usr/sbin/httpd
postgres 809 2935 0 08:53 ? 00:00:02 postgres: nagiosxi nagiosxi ::1(46118) idle
root 892 2 0 May10 ? 00:00:00 [kdmflush]
root 894 2 0 May10 ? 00:00:00 [kdmflush]
root 911 2 0 May10 ? 01:37:16 [jbd2/dm-0-8]
root 912 2 0 May10 ? 00:00:00 [ext4-dio-unwrit]
root 995 1 0 May10 ? 00:00:00 /sbin/udevd -d
root 1235 65058 2 09:19 pts/0 00:00:01 -bash
root 1903 2 0 May10 ? 00:00:00 [kdmflush]
root 1942 2 0 May10 ? 00:00:00 [jbd2/sda1-8]
root 1943 2 0 May10 ? 00:00:00 [ext4-dio-unwrit]
root 1944 2 0 May10 ? 00:02:40 [jbd2/dm-2-8]
root 1945 2 0 May10 ? 00:00:00 [ext4-dio-unwrit]
root 1988 2 0 May10 ? 00:01:29 [kauditd]
root 2107 1 0 Jun07 ? 00:00:00 python /usr/local/bin/snmptraphandling.py XXXXXXXXXXXXXXXXXXXXXXXX SNMP Traps Normal 1465332479 tran
root 2144 2 0 May10 ? 00:01:18 [bond0]
root 2235 2 0 May10 ? 06:14:51 [flush-253:0]
root 2236 2 0 May10 ? 00:07:43 [flush-253:2]
root 2311 1 0 May10 ? 00:05:20 auditd
root 2336 1 0 May10 ? 00:10:01 /sbin/rsyslogd -i /var/run/syslogd.pid -c 5
rpc 2423 1 0 May10 ? 00:00:04 rpcbind
rpcuser 2441 1 0 May10 ? 00:00:00 rpc.statd
dbus 2551 1 0 May10 ? 00:00:00 dbus-daemon --system
root 2567 1 0 May10 ? 00:00:00 cupsd -C /etc/cups/cupsd.conf
root 2592 1 0 May10 ? 00:00:00 /usr/sbin/acpid
68 2601 1 0 May10 ? 00:00:33 hald
root 2602 2601 0 May10 ? 00:00:00 hald-runner
root 2632 2602 0 May10 ? 00:00:00 hald-addon-input: Listening on /dev/input/event3 /dev/input/event2 /dev/input/event0
68 2642 2602 0 May10 ? 00:00:00 hald-addon-acpi: listening on acpid socket /var/run/acpid.socket
root 2653 1 0 May10 ? 00:02:28 /usr/sbin/sssd -f -D
root 2654 2653 0 May10 ? 00:47:49 /usr/libexec/sssd/sssd_be --domain LDAP --debug-to-files
root 2655 2653 0 May10 ? 00:06:32 /usr/libexec/sssd/sssd_nss --debug-to-files
root 2656 2653 0 May10 ? 00:11:34 /usr/libexec/sssd/sssd_pam --debug-to-files
root 2676 1 0 May10 ? 00:00:31 automount --pid-file /var/run/autofs.pid
root 2692 1 0 May10 ? 00:00:00 /usr/sbin/mcelog --daemon
root 2701 1 0 May10 ? 00:40:19 /usr/sbin/snmpd -LS0-6d -Lf /dev/null -p /var/run/snmpd.pid
root 2709 1 0 May10 ? 00:56:56 /usr/sbin/snmptrapd -Lsd -p /var/run/snmptrapd.pid
root 2735 1 0 May10 ? 00:00:08 /usr/sbin/sshd
ntp 2751 1 0 May10 ? 00:00:06 ntpd -u ntp:ntp -p /var/run/ntpd.pid -g
root 2786 1 0 May10 ? 00:00:00 /bin/sh /usr/bin/mysqld_safe --datadir=/var/lib/mysql --socket=/var/lib/mysql/mysql.sock --pid-file=/var/
mysql 2888 2786 0 May10 ? 00:20:13 /usr/libexec/mysqld --basedir=/usr --datadir=/var/lib/mysql --user=mysql --log-error=/var/log/mysqld.log
postgres 2935 1 0 May10 ? 00:10:48 /usr/bin/postmaster -p 5432 -D /var/lib/pgsql/data
postgres 2937 2935 0 May10 ? 00:01:47 postgres: logger process
postgres 2939 2935 0 May10 ? 00:12:02 postgres: writer process
postgres 2940 2935 0 May10 ? 00:07:33 postgres: wal writer process
postgres 2941 2935 0 May10 ? 00:04:24 postgres: autovacuum launcher process
postgres 2942 2935 0 May10 ? 00:22:47 postgres: stats collector process
root 3020 1 0 May10 ? 00:01:06 /usr/libexec/postfix/master
postfix 3040 3020 0 May10 ? 00:00:43 qmgr -l -t fifo -u
root 3044 1 0 May10 ? 00:00:00 /usr/sbin/abrtd
root 3052 1 0 May10 ? 00:01:40 abrt-dump-oops -d /var/spool/abrt -rwx /var/log/messages
root 3060 1 0 May10 ? 00:02:25 /usr/sbin/httpd
root 3068 1 0 May10 ? 00:03:40 crond
nagios 3190 1 0 May10 ? 00:06:08 /usr/local/nagios/bin/npcd -d -f /usr/local/nagios/etc/pnp/npcd.cfg
root 3200 1 0 May10 ? 00:00:00 /usr/sbin/atd
nagios 3214 1 0 May10 ? 00:00:00 /usr/local/nagios/bin/ndo2db -c /usr/local/nagios/etc/ndo2db.cfg
root 3230 1 0 May10 ? 00:00:00 /usr/bin/rhsmcertd
root 3239 1 0 May10 ? 00:00:00 /usr/sbin/oddjobd -p /var/run/oddjobd.pid -t 300
ajaxterm 3255 1 0 May10 ? 00:22:54 python /usr/share/ajaxterm/ajaxterm.py --daemon --port=8022 --uid=ajaxterm
root 3268 1 0 May10 ? 00:00:05 /usr/sbin/certmonger -S -p /var/run/certmonger.pid
root 3394 1 0 May10 tty1 00:00:00 /sbin/mingetty /dev/tty1
root 3396 1 0 May10 tty2 00:00:00 /sbin/mingetty /dev/tty2
root 3398 1 0 May10 tty3 00:00:00 /sbin/mingetty /dev/tty3
root 3400 1 0 May10 tty4 00:00:00 /sbin/mingetty /dev/tty4
root 3402 1 0 May10 tty5 00:00:00 /sbin/mingetty /dev/tty5
root 3404 1 0 May10 tty6 00:00:00 /sbin/mingetty /dev/tty6
root 3411 995 0 May10 ? 00:00:00 /sbin/udevd -d
root 3915 3068 0 09:20 ? 00:00:00 CROND
root 3916 3068 0 09:20 ? 00:00:00 CROND
root 3917 3068 0 09:20 ? 00:00:00 CROND
root 3918 3068 0 09:20 ? 00:00:00 CROND
root 3919 3068 0 09:20 ? 00:00:00 CROND
root 3920 3068 0 09:20 ? 00:00:00 CROND
root 3925 3920 38 09:20 ? 00:00:18 /usr/bin/perl -w /usr/bin/mrtg /etc/mrtg/mrtg.cfg --lock-file /var/lock/mrtg/mrtg_l --confcache-file /var
nagios 3927 3916 0 09:20 ? 00:00:00 /bin/sh -c /usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php > /usr/local/nagiosxi/var/feedproc.log 2
nagios 3930 3915 0 09:20 ? 00:00:00 /bin/sh -c /usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php > /usr/local/nagiosxi/var/perfdatapr
nagios 3932 3919 0 09:20 ? 00:00:00 /bin/sh -c /usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php > /usr/local/nagiosxi/var/sysstat.log 2>&
nagios 3933 3917 0 09:20 ? 00:00:00 /bin/sh -c /usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php > /usr/local/nagiosxi/var/eventman.log 2
nagios 3934 3918 0 09:20 ? 00:00:00 /bin/sh -c /usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php > /usr/local/nagiosxi/var/cmdsubsys.log
nagios 3938 3932 0 09:20 ? 00:00:00 /usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php
nagios 3939 3930 0 09:20 ? 00:00:00 /usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php
nagios 3942 3927 4 09:20 ? 00:00:01 /usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php
nagios 3943 3933 0 09:20 ? 00:00:00 /usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php
nagios 3944 3934 0 09:20 ? 00:00:00 /usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php
postgres 3951 2935 0 09:20 ? 00:00:00 postgres: nagiosxi nagiosxi ::1(55631) idle
postgres 3952 2935 0 09:20 ? 00:00:00 postgres: nagiosxi nagiosxi ::1(55632) idle
postgres 3953 2935 0 09:20 ? 00:00:00 postgres: nagiosxi nagiosxi ::1(55633) idle
postgres 3956 2935 0 09:20 ? 00:00:00 postgres: nagiosxi nagiosxi ::1(55636) idle
postgres 3959 2935 0 09:20 ? 00:00:00 postgres: nagiosxi nagiosxi ::1(55650) idle
root 5740 3925 0 09:20 ? 00:00:00 /usr/bin/perl -w /usr/bin/mrtg /etc/mrtg/mrtg.cfg --lock-file /var/lock/mrtg/mrtg_l --confcache-file /var
root 5741 3925 0 09:20 ? 00:00:00 /usr/bin/perl -w /usr/bin/mrtg /etc/mrtg/mrtg.cfg --lock-file /var/lock/mrtg/mrtg_l --confcache-file /var
root 5742 3920 0 09:20 ? 00:00:00 /usr/sbin/sendmail -FCronDaemon -i -odi -oem -oi -t -f root
root 5743 3925 3 09:20 ? 00:00:00 /usr/bin/perl -w /usr/bin/mrtg /etc/mrtg/mrtg.cfg --lock-file /var/lock/mrtg/mrtg_l --confcache-file /var
root 5744 3925 3 09:20 ? 00:00:01 /usr/bin/perl -w /usr/bin/mrtg /etc/mrtg/mrtg.cfg --lock-file /var/lock/mrtg/mrtg_l --confcache-file /var
root 5745 5742 0 09:20 ? 00:00:00 /usr/sbin/postdrop -r
nagios 5946 61630 0 09:20 ? 00:00:00 /usr/local/nagios/libexec/check_nrpe -H 10.139.3.179 -t 60 -c check_pingdum -a -u http://wpsservices.marc
apache 5996 3060 6 08:41 ? 00:02:35 /usr/sbin/httpd
postgres 6055 2935 0 08:41 ? 00:00:04 postgres: nagiosxi nagiosxi ::1(44973) idle
nagios 6509 61627 0 09:20 ? 00:00:00 /usr/local/nagios/libexec/check_nrpe -H 10.139.3.179 -t 60 -c check_pingdum -a -u http://wpsservices.marc
root 8477 1 0 May11 ? 00:00:00 python /usr/local/bin/snmptraphandling.py XXXXXXXXXXXXXXXXXX SNMP Traps Normal 1462979793 transmissi
nagios 8506 61597 0 09:20 ? 00:00:00 /usr/local/nagios/libexec/check_nrpe -H 10.98.17.147 -t 60 -c check_cpu_stats
nagios 8675 61637 0 09:20 ? 00:00:00 /usr/local/nagios/libexec/check_nrpe -H 172.22.32.73 -t 60 -c check_cpu_stats
nagios 8745 61604 0 09:20 ? 00:00:00 /usr/local/nagios/libexec/check_icmp -H 192.168.4.13 -w 3000.0 80 -c 5000.0 100 -p 5
nagios 8802 61606 0 09:20 ? 00:00:00 /usr/local/nagios/libexec/check_nt -H 10.44.12.52 -t 60 -s -p 12489 -v CPULOAD -l 5 89 90
nagios 8807 61613 0 09:20 ? 00:00:00 /usr/local/nagios/libexec/check_nt -H 10.50.48.27 -t 60 -s -p 12489 -v SERVICESTATE -l Dns -d SHOWALL
root 8809 1235 0 09:20 pts/0 00:00:00 ps -ef
postfix 10871 3020 0 08:16 ? 00:00:00 pickup -l -t fifo -u
apache 12464 3060 6 08:43 ? 00:02:31 /usr/sbin/httpd
postgres 12668 2935 0 08:43 ? 00:00:04 postgres: nagiosxi nagiosxi ::1(48197) idle
apache 15772 3060 6 08:56 ? 00:01:38 /usr/sbin/httpd
postgres 15868 2935 0 08:56 ? 00:00:02 postgres: nagiosxi nagiosxi ::1(53573) idle
root 17415 1 0 Jun09 ? 00:00:00 python /usr/local/bin/snmptraphandling.py XXXXXXXXXXXXXXXXXXXXXXXX SNMP Traps Normal 1465480436 transmissi
apache 17483 3060 5 08:04 ? 00:04:25 /usr/sbin/httpd
postgres 18014 2935 0 08:04 ? 00:00:07 postgres: nagiosxi nagiosxi ::1(37362) idle
apache 21667 3060 5 09:10 ? 00:00:36 /usr/sbin/httpd
postgres 22114 2935 0 09:10 ? 00:00:01 postgres: nagiosxi nagiosxi ::1(60708) idle
apache 24023 3060 6 09:11 ? 00:00:39 /usr/sbin/httpd
postgres 24151 2935 0 09:11 ? 00:00:00 postgres: nagiosxi nagiosxi ::1(33564) idle
root 26484 1 0 Jun09 ? 00:00:00 python /usr/local/bin/snmptraphandling.py XXXXXXXXXXXXXXXXXXXXXXXX SNMP Traps Normal 1465504667 tran
apache 27222 3060 6 09:11 ? 00:00:36 /usr/sbin/httpd
postgres 27398 2935 0 09:11 ? 00:00:01 postgres: nagiosxi nagiosxi ::1(35179) idle
root 30224 1 0 Jun13 ? 01:01:36 splunkd -p 8089 restart
root 30230 30224 0 Jun13 ? 00:00:00 [splunkd pid=30224] splunkd -p 8089 restart [process-runner]
root 31210 1 0 Jun01 ? 00:00:40 xinetd -stayalive -pidfile /var/run/xinetd.pid
root 32066 1 0 Jun10 ? 00:00:00 python /usr/local/bin/snmptraphandling.py XXXXXXXXXXXXXXXXXXXXXXXX SNMP Traps Normal 1465565845 tran
nagios 32398 1 0 Jun16 ? 00:00:48 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios 32400 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32401 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32402 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32403 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32404 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32405 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32406 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32407 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32408 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32409 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32410 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32411 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32412 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32413 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32414 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32415 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32416 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32417 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32418 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32419 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32420 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32421 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32422 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32423 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32424 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32425 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32426 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32427 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32428 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32429 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32430 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32431 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32432 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32433 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32435 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32436 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32437 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32439 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32440 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32441 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32442 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32443 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32444 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32445 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32446 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32447 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32448 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32449 32398 0 Jun16 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 32453 3214 0 Jun16 ? 00:00:04 /usr/local/nagios/bin/ndo2db -c /usr/local/nagios/etc/ndo2db.cfg
nagios 32454 32453 0 Jun16 ? 00:04:16 /usr/local/nagios/bin/ndo2db -c /usr/local/nagios/etc/ndo2db.cfg
nagios 32560 32398 0 Jun16 ? 00:00:44 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
root 33093 1 0 09:00 ? 00:00:00 /usr/bin/perl /usr/sbin/snmptt --daemon
snmptt 33094 33093 0 09:00 ? 00:00:10 /usr/bin/perl /usr/sbin/snmptt --daemon
apache 33323 3060 6 09:00 ? 00:01:20 /usr/sbin/httpd
postgres 33452 2935 0 09:00 ? 00:00:02 postgres: nagiosxi nagiosxi ::1(34163) idle
apache 38142 3060 7 09:13 ? 00:00:29 /usr/sbin/httpd
postgres 38516 2935 0 09:14 ? 00:00:00 postgres: nagiosxi nagiosxi ::1(40633) idle
apache 41713 3060 6 09:14 ? 00:00:25 /usr/sbin/httpd
postgres 41800 2935 0 09:14 ? 00:00:00 postgres: nagiosxi nagiosxi ::1(42213) idle
root 43616 3068 0 09:15 ? 00:00:00 CROND
root 43617 43616 5 09:15 ? 00:00:19 /usr/bin/perl -w /usr/bin/mrtg /etc/mrtg/mrtg.cfg --lock-file /var/lock/mrtg/mrtg_l --confcache-file /var
root 45432 43616 0 09:15 ? 00:00:00 /usr/sbin/sendmail -FCronDaemon -i -odi -oem -oi -t -f root
root 45436 45432 0 09:15 ? 00:00:00 /usr/sbin/postdrop -r
apache 48643 3060 6 09:03 ? 00:01:08 /usr/sbin/httpd
postgres 48779 2935 0 09:03 ? 00:00:01 postgres: nagiosxi nagiosxi ::1(41779) idle
root 49770 1 0 May16 ? 00:00:00 python /usr/local/bin/snmptraphandling.py XXXXXXXXXXXXXXXXXXXXXXXX SNMP Traps Normal 1463420298 transmissi
apache 51287 3060 6 09:03 ? 00:01:10 /usr/sbin/httpd
postgres 51398 2935 0 09:03 ? 00:00:01 postgres: nagiosxi nagiosxi ::1(43073) idle
apache 51753 3060 6 09:16 ? 00:00:17 /usr/sbin/httpd
root 51766 1 0 Jun03 ? 00:00:00 python /usr/local/bin/snmptraphandling.py XXXXXXXXXXXXXXXXXXXXXXXX SNMP Traps Normal 1464992306 transmission.21.1464992306
nagios 51796 1 0 Jun03 ? 00:02:45 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios 51798 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51799 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51800 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51801 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51802 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51803 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51804 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51805 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51806 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51807 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51808 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51809 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51810 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51811 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51812 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51813 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51814 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51815 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51816 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51817 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51818 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51819 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51820 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51821 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51822 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51823 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51824 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51825 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51826 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51827 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51828 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51829 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51830 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51831 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51832 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51833 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51834 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51835 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51836 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51838 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51839 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51840 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51842 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51843 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51844 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51845 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51846 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51847 51796 0 Jun03 ? 00:00:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 51851 3214 0 Jun03 ? 00:00:15 /usr/local/nagios/bin/ndo2db -c /usr/local/nagios/etc/ndo2db.cfg
nagios 51852 51851 0 Jun03 ? 00:13:41 /usr/local/nagios/bin/ndo2db -c /usr/local/nagios/etc/ndo2db.cfg
postgres 51856 2935 0 09:16 ? 00:00:00 postgres: nagiosxi nagiosxi ::1(47286) idle
nagios 51915 51796 0 Jun03 ? 00:01:34 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
root 52889 995 0 May20 ? 00:00:00 /sbin/udevd -d
root 52890 2 0 May20 ? 00:00:00 [bluetooth]
apache 54330 3060 7 09:17 ? 00:00:16 /usr/sbin/httpd
postgres 54559 2935 0 09:17 ? 00:00:00 postgres: nagiosxi nagiosxi ::1(48560) idle
apache 55363 3060 4 06:11 ? 00:08:23 /usr/sbin/httpd
apache 55689 3060 6 08:51 ? 00:01:52 /usr/sbin/httpd
postgres 55788 2935 0 08:51 ? 00:00:03 postgres: nagiosxi nagiosxi ::1(41059) idle
postgres 55841 2935 0 06:11 ? 00:00:14 postgres: nagiosxi nagiosxi ::1(38817) idle
root 56401 1 0 Jun16 ? 00:00:00 python /usr/local/bin/snmptraphandling.py rso-parsippany-rtr-mpls SNMP Traps Normal 1466125412 transmissi
apache 57520 3060 3 01:48 ? 00:16:45 /usr/sbin/httpd
postgres 57842 2935 0 01:48 ? 00:00:28 postgres: nagiosxi nagiosxi ::1(37309) idle
nagios 61593 1 5 Jun24 ? 03:39:34 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios 61595 61593 0 Jun24 ? 00:02:40 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61596 61593 0 Jun24 ? 00:02:38 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61597 61593 0 Jun24 ? 00:02:37 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61598 61593 0 Jun24 ? 00:02:37 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61599 61593 0 Jun24 ? 00:02:42 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61600 61593 0 Jun24 ? 00:02:39 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61601 61593 0 Jun24 ? 00:02:39 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61602 61593 0 Jun24 ? 00:02:41 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61603 61593 0 Jun24 ? 00:02:38 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61604 61593 0 Jun24 ? 00:02:38 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61605 61593 0 Jun24 ? 00:02:40 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61606 61593 0 Jun24 ? 00:02:40 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61607 61593 0 Jun24 ? 00:02:39 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61608 61593 0 Jun24 ? 00:02:37 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61610 61593 0 Jun24 ? 00:02:40 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61612 61593 0 Jun24 ? 00:02:40 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61613 61593 0 Jun24 ? 00:02:39 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61614 61593 0 Jun24 ? 00:02:37 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61615 61593 0 Jun24 ? 00:02:40 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61616 61593 0 Jun24 ? 00:02:38 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61617 61593 0 Jun24 ? 00:02:36 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61618 61593 0 Jun24 ? 00:02:38 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61619 61593 0 Jun24 ? 00:02:36 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61621 61593 0 Jun24 ? 00:02:41 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61622 61593 0 Jun24 ? 00:02:39 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61623 61593 0 Jun24 ? 00:02:38 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61625 61593 0 Jun24 ? 00:02:39 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61626 61593 0 Jun24 ? 00:02:40 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61627 61593 0 Jun24 ? 00:02:37 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61629 61593 0 Jun24 ? 00:02:39 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61630 61593 0 Jun24 ? 00:02:39 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61631 61593 0 Jun24 ? 00:02:38 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61632 61593 0 Jun24 ? 00:02:38 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61633 61593 0 Jun24 ? 00:02:39 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61634 61593 0 Jun24 ? 00:02:36 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61635 61593 0 Jun24 ? 00:02:39 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61636 61593 0 Jun24 ? 00:02:39 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61637 61593 0 Jun24 ? 00:02:41 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61638 61593 0 Jun24 ? 00:02:37 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61639 61593 0 Jun24 ? 00:02:39 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61640 61593 0 Jun24 ? 00:02:41 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61641 61593 0 Jun24 ? 00:02:41 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61642 61593 0 Jun24 ? 00:02:38 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61643 61593 0 Jun24 ? 00:02:39 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61644 61593 0 Jun24 ? 00:02:39 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61645 61593 0 Jun24 ? 00:02:39 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61646 61593 0 Jun24 ? 00:02:41 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61647 61593 0 Jun24 ? 00:02:38 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 61649 3214 0 Jun24 ? 00:19:14 /usr/local/nagios/bin/ndo2db -c /usr/local/nagios/etc/ndo2db.cfg
nagios 61650 61649 25 Jun24 ? 17:00:14 /usr/local/nagios/bin/ndo2db -c /usr/local/nagios/etc/ndo2db.cfg
nagios 61718 61593 0 Jun24 ? 00:00:12 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
apache 64441 3060 6 09:19 ? 00:00:06 /usr/sbin/httpd
postgres 64587 2935 0 09:19 ? 00:00:00 postgres: nagiosxi nagiosxi ::1(53499) idle
One thing, there are multiple nagios processes and snmptraphandling python processes running on your system which could be causing the issue.
Login to the XI server as root, run the following to stop the multiple nagios processes
Next, stop all of the snmptraphandling processes running on that server. An example of one of then is below. Make sure to stop them all.
To minimize the stuck snmptraphandling processes from happening in to the future, edit the following file
Add the following at the bottom of the start) section of the nagios init script. Right below the echo " done." section.
Save the file and every time the nagios process is started, it will restart the snmptt process stopping the stuck snmptraphandling processes from causing any issues.
Try that and let us know if this helps.
service nagios stop
killall -9 nagios
service nagios start
/etc/init.d/nagios
/etc/init.d/snmptt restart
Made all the previously mentioned changes, but we're still experiencing the issue.
Can you run these 2 commands as root and post the output?
Can you login to the Core interface and see if you can acknowledge a service or host and see if that works?
ls -l /usr/local/nagios/var/rw/
ps -ef
Just had it happen again before I saw this message. I'll do that the next time it happens and post the results here.tgriep wrote:Can you run these 2 commands as root and post the output?Can you login to the Core interface and see if you can acknowledge a service or host and see if that works?Code: Select all
ls -l /usr/local/nagios/var/rw/ ps -ef
Thank you.
root@fe1.nagios (Linux) $ ls -la /usr/local/nagios/var/rw/
total 12
drwxrwsr-x 2 nagios nagcmd 4096 Jul 1 10:27 .
drwxrwxr-x 6 nagios nagios 4096 Jul 1 10:40 ..
-rw-rw-r-- 1 root nagcmd 500 Jul 1 10:39 nagios.cmd
srw-rw---- 1 nagios nagcmd 0 Jul 1 10:27 nagios.qh
root@fe1.nagios (Linux) $ ps -ef
root 2409 1 0 May10 ? 00:23:43 irqbalance --pid=/var/run/irqbal
rpc 2423 1 0 May10 ? 00:00:05 rpcbind
68 2601 1 0 May10 ? 00:00:35 hald
root 2653 1 0 May10 ? 00:02:40 /usr/sbin/sssd -f -D
root 2654 2653 0 May10 ? 00:51:58 /usr/libexec/sssd/sssd_be --doma
root 2655 2653 0 May10 ? 00:07:06 /usr/libexec/sssd/sssd_nss --deb
root 2656 2653 0 May10 ? 00:12:33 /usr/libexec/sssd/sssd_pam --deb
root 2676 1 0 May10 ? 00:00:33 automount --pid-file /var/run/au
root 2701 1 0 May10 ? 00:43:41 /usr/sbin/snmpd -LS0-6d -Lf /dev
root 2709 1 0 May10 ? 01:02:23 /usr/sbin/snmptrapd -Lsd -p /var
mysql 2888 2786 0 May10 ? 00:21:53 /usr/libexec/mysqld --basedir=/u
postgres 2935 1 0 May10 ? 00:11:43 /usr/bin/postmaster -p 5432 -D /
postgres 2937 2935 0 May10 ? 00:01:56 postgres: logger process
postgres 2939 2935 0 May10 ? 00:13:03 postgres: writer process
postgres 2940 2935 0 May10 ? 00:08:11 postgres: wal writer process
postgres 2941 2935 0 May10 ? 00:04:46 postgres: autovacuum launcher pr
postgres 2942 2935 0 May10 ? 00:24:44 postgres: stats collector proces
root 3020 1 0 May10 ? 00:01:11 /usr/libexec/postfix/master
postfix 3040 3020 0 May10 ? 00:00:46 qmgr -l -t fifo -u
root 3052 1 0 May10 ? 00:01:50 abrt-dump-oops -d /var/spool/abr
root 3060 1 0 May10 ? 00:02:37 /usr/sbin/httpd
root 3068 1 0 May10 ? 00:03:59 crond
nagios 3190 1 0 May10 ? 00:06:40 /usr/local/nagios/bin/npcd -d -f
root 3280 3068 0 10:40 ? 00:00:00 CROND
root 3285 3068 0 10:40 ? 00:00:00 CROND
root 3286 3068 0 10:40 ? 00:00:00 CROND
root 3287 3068 0 10:40 ? 00:00:00 CROND
root 3288 3068 0 10:40 ? 00:00:00 CROND
root 3289 3068 0 10:40 ? 00:00:00 CROND
root 3290 3068 0 10:40 ? 00:00:00 CROND
root 3293 3290 93 10:40 ? 00:00:07 /usr/bin/perl -w /usr/bin/mrtg /
nagios 3297 3289 0 10:40 ? 00:00:00 /bin/sh -c /usr/bin/php -q /usr/
nagios 3299 3280 0 10:40 ? 00:00:00 /bin/sh -c /usr/bin/php -q /usr/
nagios 3300 3288 0 10:40 ? 00:00:00 /bin/sh -c /usr/bin/php -q /usr/
nagios 3302 3285 0 10:40 ? 00:00:00 /bin/sh -c /usr/bin/php -q /usr/
nagios 3303 3287 0 10:40 ? 00:00:00 /bin/sh -c /usr/bin/php -q /usr/
nagios 3304 3286 0 10:40 ? 00:00:00 /bin/sh -c /usr/bin/php -q /usr/
nagios 3306 3297 2 10:40 ? 00:00:00 /usr/bin/php -q /usr/local/nagio
nagios 3308 3300 1 10:40 ? 00:00:00 /usr/bin/php -q /usr/local/nagio
nagios 3310 3303 3 10:40 ? 00:00:00 /usr/bin/php -q /usr/local/nagio
nagios 3311 3302 1 10:40 ? 00:00:00 /usr/bin/php -q /usr/local/nagio
nagios 3312 3299 3 10:40 ? 00:00:00 /usr/bin/php -q /usr/local/nagio
nagios 3313 3304 1 10:40 ? 00:00:00 /usr/bin/php -q /usr/local/nagio
postgres 3318 2935 0 10:40 ? 00:00:00 postgres: nagiosxi nagiosxi ::1(
postgres 3319 2935 0 10:40 ? 00:00:00 postgres: nagiosxi nagiosxi ::1(
postgres 3320 2935 0 10:40 ? 00:00:00 postgres: nagiosxi nagiosxi ::1(
postgres 3327 2935 0 10:40 ? 00:00:00 postgres: nagiosxi nagiosxi ::1(
postgres 3328 2935 0 10:40 ? 00:00:00 postgres: nagiosxi nagiosxi ::1(
postgres 3329 2935 0 10:40 ? 00:00:00 postgres: nagiosxi nagiosxi ::1(
nagios 3526 9651 0 10:40 ? 00:00:00 /usr/local/nagios/libexec/check_
nagios 3784 9616 0 10:40 ? 00:00:00 /usr/local/nagios/libexec/check_
nagios 3815 9606 0 10:40 ? 00:00:00 /usr/local/nagios/libexec/check_
nagios 3886 9613 0 10:40 ? 00:00:00 /usr/local/nagios/libexec/check_
nagios 3887 3886 0 10:40 ? 00:00:00 /usr/bin/ssh 192.168.2.138 /usr/
nagios 3895 9621 0 10:40 ? 00:00:00 /usr/local/nagios/libexec/check_
root 3903 7255 0 10:40 pts/0 00:00:00 ps -ef
root 5642 2735 0 10:26 ? 00:00:00 sshd: rickhi [priv]
rickhi 6675 5642 0 10:27 ? 00:00:00 sshd: rickhi@pts/0
root 6706 1 0 Jun28 ? 00:00:00 rhnsd
rickhi 6721 6675 0 10:27 pts/0 00:00:00 -bash
apache 7108 3060 2 05:36 ? 00:07:55 /usr/sbin/httpd
root 7155 6721 0 10:27 pts/0 00:00:00 su -
root 7255 7155 0 10:27 pts/0 00:00:00 -bash
ajaxterm 7511 1 0 Jun27 ? 00:01:49 python /usr/share/ajaxterm/ajaxt
postgres 7992 2935 0 05:36 ? 00:00:14 postgres: nagiosxi nagiosxi ::1(
root 9036 1 0 Jun28 ? 00:00:00 python /usr/local/bin/snmptrapha
nagios 9599 1 5 10:27 ? 00:00:43 /usr/local/nagios/bin/nagios -d
nagios 9601 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9602 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9603 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9604 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9605 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9606 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9608 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9609 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9610 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9611 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9612 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9613 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9614 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9615 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9616 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9617 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9618 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9619 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9620 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9621 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9622 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9623 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9624 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9626 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9627 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9629 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9630 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9631 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9632 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9633 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9634 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9635 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9636 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9637 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9638 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9639 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9640 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9641 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9642 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9643 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9644 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9645 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9646 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9647 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9648 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9649 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9650 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9651 9599 0 10:27 ? 00:00:00 /usr/local/nagios/bin/nagios --w
nagios 9652 3214 0 10:27 ? 00:00:04 /usr/local/nagios/bin/ndo2db -c
nagios 9653 9652 33 10:27 ? 00:04:09 /usr/local/nagios/bin/ndo2db -c
root 9668 1 0 10:27 ? 00:00:00 /usr/bin/perl /usr/sbin/snmptt -
snmptt 9669 9668 0 10:27 ? 00:00:05 /usr/bin/perl /usr/sbin/snmptt -
nagios 9697 9599 0 10:27 ? 00:00:00 [nagios] <defunct>
apache 11105 3060 2 07:01 ? 00:06:24 /usr/sbin/httpd
postgres 11571 2935 0 07:01 ? 00:00:11 postgres: nagiosxi nagiosxi ::1(
apache 25415 3060 2 03:45 ? 00:10:39 /usr/sbin/httpd
postgres 25799 2935 0 03:45 ? 00:00:18 postgres: nagiosxi nagiosxi ::1(
apache 27008 3060 2 06:51 ? 00:06:35 /usr/sbin/httpd
postgres 27378 2935 0 06:51 ? 00:00:11 postgres: nagiosxi nagiosxi ::1(
apache 28688 3060 2 03:17 ? 00:11:10 /usr/sbin/httpd
postgres 29719 2935 0 03:18 ? 00:00:19 postgres: nagiosxi nagiosxi ::1(
root 30224 1 0 Jun13 ? 01:20:10 splunkd -p 8089 restart
apache 30804 3060 3 09:10 ? 00:02:58 /usr/sbin/httpd
apache 30910 3060 3 09:10 ? 00:02:57 /usr/sbin/httpd
apache 30911 3060 3 09:10 ? 00:02:55 /usr/sbin/httpd
apache 30962 3060 3 09:10 ? 00:02:57 /usr/sbin/httpd
apache 30965 3060 3 09:10 ? 00:02:54 /usr/sbin/httpd
apache 30966 3060 3 09:10 ? 00:02:54 /usr/sbin/httpd
root 31144 2735 0 09:10 ? 00:00:00 sshd: rickhi [priv]
root 31210 1 0 Jun01 ? 00:00:47 xinetd -stayalive -pidfile /var/
rickhi 31317 31144 0 09:10 ? 00:00:00 sshd: rickhi@pts/1
rickhi 31318 31317 0 09:10 pts/1 00:00:00 -bash
postgres 31775 2935 0 09:10 ? 00:00:05 postgres: nagiosxi nagiosxi ::1(
postgres 31776 2935 0 09:10 ? 00:00:05 postgres: nagiosxi nagiosxi ::1(
postgres 31822 2935 0 09:10 ? 00:00:05 postgres: nagiosxi nagiosxi ::1(
postgres 31877 2935 0 09:10 ? 00:00:05 postgres: nagiosxi nagiosxi ::1(
postgres 32141 2935 0 09:10 ? 00:00:05 postgres: nagiosxi nagiosxi ::1(
postgres 32142 2935 0 09:10 ? 00:00:05 postgres: nagiosxi nagiosxi ::1(
postfix 32598 3020 0 09:51 ? 00:00:00 pickup -l -t fifo -u
apache 32736 3060 3 08:01 ? 00:04:46 /usr/sbin/httpd
postgres 33064 2935 0 08:01 ? 00:00:08 postgres: nagiosxi nagiosxi ::1(
apache 36758 3060 2 06:39 ? 00:06:34 /usr/sbin/httpd
postgres 37388 2935 0 06:39 ? 00:00:11 postgres: nagiosxi nagiosxi ::1(
apache 37648 3060 3 08:02 ? 00:04:49 /usr/sbin/httpd
apache 37851 3060 3 10:06 ? 00:01:01 /usr/sbin/httpd
postgres 37989 2935 0 08:02 ? 00:00:08 postgres: nagiosxi nagiosxi ::1(
postgres 38093 2935 0 10:06 ? 00:00:01 postgres: nagiosxi nagiosxi ::1(
apache 38549 3060 2 06:53 ? 00:06:33 /usr/sbin/httpd
postgres 38805 2935 0 06:53 ? 00:00:11 postgres: nagiosxi nagiosxi ::1(
apache 42187 3060 3 09:39 ? 00:01:54 /usr/sbin/httpd
postgres 42385 2935 0 09:39 ? 00:00:03 postgres: nagiosxi nagiosxi ::1(
apache 43807 3060 2 04:03 ? 00:09:39 /usr/sbin/httpd
postgres 44415 2935 0 04:04 ? 00:00:17 postgres: nagiosxi nagiosxi ::1(
root 44594 3068 0 10:35 ? 00:00:00 CROND
root 44595 44594 6 10:35 ? 00:00:19 /usr/bin/perl -w /usr/bin/mrtg /
root 46177 44594 0 10:35 ? 00:00:00 /usr/sbin/sendmail -FCronDaemon
root 46178 44595 1 10:35 ? 00:00:04 /usr/bin/perl -w /usr/bin/mrtg /
root 46180 46177 0 10:35 ? 00:00:00 /usr/sbin/postdrop -r
