Syntax Command Check_netstat_conn
ednaldojta
Re: Syntax Command Check_netstat_conn
Post by ednaldojta »
Hello friends,
I thank all of you help!
But really it takes is starting a criterion, for example.
if [ "$ arg1" -gt 2]
Then
echo "Service is OK"
fi
And starting this status or otherwise, the status it it in Dashboard green turns to red or yellow, referring to the criteria that I set.
As follows the image below. I set a criterion, but the service is still green despite being Warning regarding the criteria that define the Scritp.
Ah, you'll want to add in exit codes for this. Using your example -
Then
exit 0
fi
exit 1 - represents warning
exit 2 - represents critical
exit 3 - represents unknown
Once you update the script, it should work accordingly.
ednaldojta
OK! Thank you friends for help! Already meets the desired result!
Thank you so!
To the next!
: D
Good to hear!
Am I good to mark this thread as resolved?
ednaldojta
Yes!
And one more time! thank you!
No problem! We're here to help.
If you need any assistance in the future, feel free to open up a new thread.
