How to view all the Mount Points on Linux
eloyd
Cool Title Here
Re: How to view all the Mount Points on Linux
Post by eloyd »
Not for this, you don't. It's a simple perl script that queries the remote host's SNMP server to respond to requests about disk space.
systemali
Post by systemali »
Fabulous :)
Thank you so much Eloyd,
I'll have this checked on Monday and will revert back accordingly !
Have a great Week end :)
Definitely let us know how this worked out!
systemali
Post by systemali »
Hello Everybody,
I am so sorry to say, I see no change in my Nagios interface, it is as it was in the beginning.
I guess there is something i need to edit on the Nagios server in the snmpd.conf or nagios configuration or something else,
if somebody would be kind enough to direct me, Please !!!!
Thank you all for your time.
Did you upload and install the plugin on the Nagios server?
If you did, can you post the error you are seeing and how you setup the command?
systemali
Post by systemali »
Hello tgriep,
Yes, I have uploaded and installed the script on the Nagios server in the plugins folder !
I am not seeing any error, I have done NO setup, I have just extracted the script
to the plugins folder, that's all !
This is what i have been asking for all this while, What do i need to do
after i have installed the script, Do i need to Edit it and What do i need to
edit it with and at what location ...
My apologies if i have been loud, You can blame it on my frustration :(
Thank you all for your time !!!
Your continued assistance is appreciated !!!
Thank you once again !!!
Ok, this is what you would have to do to use that plugin on your system.
First you would have to create a command in your commands.cfg file like the example below.
       command_name                             check_snmp_storage
       command_line                             $USER1$/check_snmp_storage.pl -H $HOSTADDRESS$ $ARG1$
Then, you would create a service check like the example below for the host you want to check. The example below would test all mounts starting with /
        host_name                       Host-Name
        service_description             / Disk Usage
        check_command                   check_snmp_storage! -C public --v2c -m "/" -w 80 -c 95 -f!!!!!!!
        max_check_attempts              5
        check_interval                  5
        retry_interval                  1
        notification_interval           60
        notifications_enabled           1
        contacts                        nagiosadmin
        register                        1
Try that and let us know if you have anymore questions.
