Better Apache Dashboard stopped working
Re: Better Apache Dashboard stopped working
Post by mcapra »
NLS doesn't currently have that functionality, though there is a pending feature request for it. Currently, you'll need a user to login as if you want to display a dashboard.
GhostRider2110
Post by GhostRider2110 »
Can you submit that within the URL for the dashboard?
Post by mcapra »
Unfortunately no, though you could probably write a dirt simple Greasemonkey script to plug in the credentials and login if the page isn't currently displaying the dashboard.
GhostRider2110
Ok thanks, this can be locked now.
