UPS battery lifetime alert
Re: UPS battery lifetime alert
No, this replaces the plugin you were previously using as @tgrtjake modified it for you.
i am sorry, bare with me plz, where do i have to use this code? i am new on nagiosrkennedy wrote:No, this replaces the plugin you were previously using as @tgrtjake modified it for you.
#!/usr/local/groundwork/bin/perl
# Copyright (C) 2004 Altinity Limited
# E: [email protected] W: http://www.altinity.com/
# Modified by [email protected]
# This program is free software; you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation; either version 2 of the License, or
# (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program; if not, write to the Free Software
# Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
use Net::SNMP;
use Getopt::Std;
$script = "check_ups_pow.pl";
$script_version = "1.0";
$metric = 1;
$ipaddress = "192.168.1.1"; # default IP address, if none supplied
$version = "1"; # SNMP version
$timeout = 2; # SNMP query timeout
# $warning = 100;
# $critical = 150;
$status = 0;
$returnstring = "";
$perfdata = "";
$community = "public"; # Default community string
$oid_sysDescr = ".1.3.6.1.2.1.1.1.0";
$oid_upstype = ".1.3.6.1.2.1.1.5.0";
#$oid_upstype = ".1.3.6.1.4.1.318.1.1.1.1.1.1.0";
$oid_battery_capacity = ".1.3.6.1.4.1.318.1.1.1.2.2.1.0";
$oid_output_status = ".1.3.6.1.4.1.318.1.1.1.4.1.1.0";
$oid_output_current = ".1.3.6.1.4.1.318.1.1.1.4.2.4.0";
$oid_output_load = ".1.3.6.1.4.1.318.1.1.1.4.2.3.0";
$oid_temperature = ".1.3.6.1.4.1.318.1.1.1.2.2.2.0";
$upstype = "";
$battery_capacity = 0;
$output_status = 0;
$output_current =0;
$output_load = 0;
$temperature = 0;
# Do we have enough information?
if (@ARGV < 1) {
print "Too few arguments\n";
usage();
getopts("h:H:C:w:c:");
if ($opt_h){
usage();
exit(0);
if ($opt_H){
$hostname = $opt_H;
else {
print "No hostname specified\n";
usage();
if ($opt_C){
$community = $opt_C;
else {
# Create the SNMP session
my ($s, $e) = Net::SNMP->session(
-community => $community,
-hostname => $hostname,
-version => $version,
-timeout => $timeout,
main();
# Close the session
$s->close();
if ($status == 0){
print "Status is OK -- $returnstring|$perfdata\n";
# print "$returnstring\n";
elsif ($status == 1){
print "Status is at WARNING -- $returnstring|$perfdata\n";
elsif ($status == 2){
print "Status is at CRITICAL -- $returnstring|$perfdata\n";
else{
print "Problem with monitoring plugin. No response from SNMP agent.\n";
exit $status;
# This is where we gather data via SNMP and return results #
sub main {
if (!defined($s->get_request($oid_upstype))) {
if (!defined($s->get_request($oid_sysDescr))) {
$returnstring = "SNMP agent not responding";
$status = 1;
return 1;
else {
$returnstring = "SNMP OID does not exist";
$status = 1;
return 1;
foreach ($s->var_bind_names()) {
$upstype = $s->var_bind_list()->{$_};
if (!defined($s->get_request($oid_battery_capacity))) {
$status = 1;
return 1;
else {
$status = 1;
return 1;
$battery_capacity = $s->var_bind_list()->{$_};
if (!defined($s->get_request($oid_output_status))) {
$status = 1;
return 1;
else {
$status = 1;
return 1;
$output_status = $s->var_bind_list()->{$_};
if (!defined($s->get_request($oid_output_current))) {
$status = 1;
return 1;
else {
$status = 1;
return 1;
$output_current = $s->var_bind_list()->{$_};
if (!defined($s->get_request($oid_output_load))) {
$status = 1;
return 1;
else {
$status = 1;
return 1;
$output_load = $s->var_bind_list()->{$_};
if (!defined($s->get_request($oid_temperature))) {
$status = 1;
return 1;
else {
$status = 1;
return 1;
$temperature = $s->var_bind_list()->{$_};
$temp = $temperature * 1.8 + 32;
$returnstring = "";
$status = 0;
$perfdata = "";
# if (defined($oid_upstype)) {
# $returnstring = "$upstype - ";
if ($battery_capacity < 25) {
$returnstring = $returnstring . "BATTERY AT $battery_capacity% -- ";
$status = 2;
elsif ($battery_capacity < 50) {
$status = 1 if ( $status != 2 );
elsif ($battery_capacity <= 100) {
else {
$returnstring = $returnstring . "BATTERY CAPACITY UNKNOWN! -- ";
$status = 3 if ( ( $status != 2 ) && ( $status != 1 ) );
if ($output_status eq "2"){
$returnstring = $returnstring . "UPS IS NORMAL -- ";
elsif ($output_status eq "3"){
$returnstring = $returnstring . "UPS IS ON BATTERY! -- ";
elsif ($output_status eq "4"){
$returnstring = $returnstring . "UPS IS ON SMART BOOST! - ";
elsif ($output_status eq "5"){
$returnstring = $returnstring . "UPS IS ON TIMED SLEEP! -- ";
elsif ($output_status eq "6"){
$returnstring = $returnstring . "UPS IS ON SOFTWARE BYPASS! -- ";
elsif ($output_status eq "7"){
$returnstring = $returnstring . "UPS IS OFF! -- ";
elsif ($output_status eq "8"){
$returnstring = $returnstring . "UPS IS REBOOTING! -- ";
elsif ($output_status eq "9"){
$returnstring = $returnstring . "UPS IS ON SWITCHED BYPASS! -- ";
elsif ($output_status eq "10"){
$returnstring = $returnstring . "UPS IS ON HARDWARE FAILURE BYPASS! -- ";
elsif ($output_status eq "11"){
$returnstring = $returnstring . "UPS IS SLEEPING UNTIL POWER RETURN! -- ";
elsif ($output_status eq "12"){
$returnstring = $returnstring . "UPS IS ON SMART TRIM! -- ";
elsif ($output_status eq "13"){
$returnstring = $returnstring . "UPS IS ON ECO MODE! -- ";
elsif ($output_status eq "14"){
$returnstring = $returnstring . "UPS IS ON HOT STANDBY! -- ";
elsif ($output_status eq "15"){
$returnstring = $returnstring . "UPS IS PERFORMING BATTERY TEST! -- ";
# $status = 1 if ( $status != 2 );
elsif ($output_status eq "16"){
$returnstring = $returnstring . "UPS IS ON EMERGENCY STATIC BYPASS! -- ";
elsif ($output_status eq "17"){
$returnstring = $returnstring . "UPS IS ON STATIC BYPASS STANDBY! -- ";
elsif ($output_status eq "18"){
$returnstring = $returnstring . "UPS IS ON POWER SAVING MODE! -- ";
elsif ($output_status eq "19"){
$returnstring = $returnstring . "UPS IS ON SPOT MODE! -- ";
elsif ($output_status eq "20"){
$returnstring = $returnstring . "UPS IS ON ECONVERSION! -- ";
else {
$returnstring = $returnstring . "UNKNOWN OUTPUT STATUS! -- ";
if ($output_load > 90) {
$returnstring = $returnstring . "OUTPUT LOAD $output_load% -- ";
$perfdata = $perfdata . "'load'=$output_load ";
$status = 2;
elsif ($output_load > 80) {
elsif ($output_load >= 0) {
else {
$returnstring = $returnstring . "OUTPUT LOAD UNKNOWN! -- ";
$perfdata = $perfdata . "'load'=NAN ";
if ($temperature > 93) {
$returnstring = $returnstring . "INTERNAL TEMP $temp F";
$perfdata = $perfdata . "'temp'=$temp ";
$status = 2;
elsif ($temperature > 89) {
elsif ($temperature >= 0) {
else {
$returnstring = $returnstring . "INTERNAL TEMP UNKNOWN!";
$perfdata = $perfdata . "'temp'=NAN ";
# help and usage information #
sub usage {
print << "USAGE";
$script v$script_version
Monitors PowerWare UPS via SNMP management card.
Usage: $script -H <hostname> -C <community> [...]
Options: -H Hostname or IP address
-C Community (default is public)
Copyright 2004 Altinity Limited
This program is free software; you can redistribute it or modify
USAGE
exit 1;
}Re: UPS battery lifetime alert
This is a perl script so you would need perl installed to use this. In my case it works great. You may or may not like it, but I thought I would suggest it to you to try.
Here's the link for the plugin.
https://exchange.nagios.org/directory/P ... 1451320184
Nagios Core 4.1.1 running on Ubuntu 14.04
sa77if wrote:i am sorry, bare with me plz, where do i have to use this code? i am new on nagiosrkennedy wrote:No, this replaces the plugin you were previously using as @tgrtjake modified it for you.Code: Select all
#!/usr/local/groundwork/bin/perl # Copyright (C) 2004 Altinity Limited # E: [email protected] W: http://www.altinity.com/ # Modified by [email protected] # # This program is free software; you can redistribute it and/or modify # it under the terms of the GNU General Public License as published by # the Free Software Foundation; either version 2 of the License, or # (at your option) any later version. # # This program is distributed in the hope that it will be useful, # but WITHOUT ANY WARRANTY; without even the implied warranty of # MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the # GNU General Public License for more details. # # You should have received a copy of the GNU General Public License # along with this program; if not, write to the Free Software # Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA use Net::SNMP; use Getopt::Std; $script = "check_ups_pow.pl"; $script_version = "1.0"; $metric = 1; $ipaddress = "192.168.1.1"; # default IP address, if none supplied $version = "1"; # SNMP version $timeout = 2; # SNMP query timeout # $warning = 100; # $critical = 150; $status = 0; $returnstring = ""; $perfdata = ""; $community = "public"; # Default community string $oid_sysDescr = ".1.3.6.1.2.1.1.1.0"; $oid_upstype = ".1.3.6.1.2.1.1.5.0"; #$oid_upstype = ".1.3.6.1.4.1.318.1.1.1.1.1.1.0"; $oid_battery_capacity = ".1.3.6.1.4.1.318.1.1.1.2.2.1.0"; $oid_output_status = ".1.3.6.1.4.1.318.1.1.1.4.1.1.0"; $oid_output_current = ".1.3.6.1.4.1.318.1.1.1.4.2.4.0"; $oid_output_load = ".1.3.6.1.4.1.318.1.1.1.4.2.3.0"; $oid_temperature = ".1.3.6.1.4.1.318.1.1.1.2.2.2.0"; $upstype = ""; $battery_capacity = 0; $output_status = 0; $output_current =0; $output_load = 0; $temperature = 0; # Do we have enough information? if (@ARGV < 1) { print "Too few arguments\n"; usage(); } getopts("h:H:C:w:c:"); if ($opt_h){ usage(); exit(0); } if ($opt_H){ $hostname = $opt_H; } else { print "No hostname specified\n"; usage(); } if ($opt_C){ $community = $opt_C; } else { } # Create the SNMP session my ($s, $e) = Net::SNMP->session( -community => $community, -hostname => $hostname, -version => $version, -timeout => $timeout, ); main(); # Close the session $s->close(); if ($status == 0){ print "Status is OK -- $returnstring|$perfdata\n"; # print "$returnstring\n"; } elsif ($status == 1){ print "Status is at WARNING -- $returnstring|$perfdata\n"; } elsif ($status == 2){ print "Status is at CRITICAL -- $returnstring|$perfdata\n"; } else{ print "Problem with monitoring plugin. No response from SNMP agent.\n"; } exit $status; #################################################################### # This is where we gather data via SNMP and return results # #################################################################### sub main { ####################################################### if (!defined($s->get_request($oid_upstype))) { if (!defined($s->get_request($oid_sysDescr))) { $returnstring = "SNMP agent not responding"; $status = 1; return 1; } else { $returnstring = "SNMP OID does not exist"; $status = 1; return 1; } } foreach ($s->var_bind_names()) { $upstype = $s->var_bind_list()->{$_}; } ####################################################### if (!defined($s->get_request($oid_battery_capacity))) { if (!defined($s->get_request($oid_sysDescr))) { $returnstring = "SNMP agent not responding"; $status = 1; return 1; } else { $returnstring = "SNMP OID does not exist"; $status = 1; return 1; } } foreach ($s->var_bind_names()) { $battery_capacity = $s->var_bind_list()->{$_}; } ####################################################### if (!defined($s->get_request($oid_output_status))) { if (!defined($s->get_request($oid_sysDescr))) { $returnstring = "SNMP agent not responding"; $status = 1; return 1; } else { $returnstring = "SNMP OID does not exist"; $status = 1; return 1; } } foreach ($s->var_bind_names()) { $output_status = $s->var_bind_list()->{$_}; } ####################################################### if (!defined($s->get_request($oid_output_current))) { if (!defined($s->get_request($oid_sysDescr))) { $returnstring = "SNMP agent not responding"; $status = 1; return 1; } else { $returnstring = "SNMP OID does not exist"; $status = 1; return 1; } } foreach ($s->var_bind_names()) { $output_current = $s->var_bind_list()->{$_}; } ####################################################### if (!defined($s->get_request($oid_output_load))) { if (!defined($s->get_request($oid_sysDescr))) { $returnstring = "SNMP agent not responding"; $status = 1; return 1; } else { $returnstring = "SNMP OID does not exist"; $status = 1; return 1; } } foreach ($s->var_bind_names()) { $output_load = $s->var_bind_list()->{$_}; } ####################################################### if (!defined($s->get_request($oid_temperature))) { if (!defined($s->get_request($oid_sysDescr))) { $returnstring = "SNMP agent not responding"; $status = 1; return 1; } else { $returnstring = "SNMP OID does not exist"; $status = 1; return 1; } } foreach ($s->var_bind_names()) { $temperature = $s->var_bind_list()->{$_}; } $temp = $temperature * 1.8 + 32; ####################################################### $returnstring = ""; $status = 0; $perfdata = ""; # if (defined($oid_upstype)) { # $returnstring = "$upstype - "; # } if ($battery_capacity < 25) { $returnstring = $returnstring . "BATTERY AT $battery_capacity% -- "; $status = 2; } elsif ($battery_capacity < 50) { $returnstring = $returnstring . "BATTERY AT $battery_capacity% -- "; $status = 1 if ( $status != 2 ); } elsif ($battery_capacity <= 100) { $returnstring = $returnstring . "BATTERY AT $battery_capacity% -- "; } else { $returnstring = $returnstring . "BATTERY CAPACITY UNKNOWN! -- "; $status = 3 if ( ( $status != 2 ) && ( $status != 1 ) ); } if ($output_status eq "2"){ $returnstring = $returnstring . "UPS IS NORMAL -- "; } elsif ($output_status eq "3"){ $returnstring = $returnstring . "UPS IS ON BATTERY! -- "; $status = 1 if ( $status != 2 ); } elsif ($output_status eq "4"){ $returnstring = $returnstring . "UPS IS ON SMART BOOST! - "; $status = 1 if ( $status != 2 ); } elsif ($output_status eq "5"){ $returnstring = $returnstring . "UPS IS ON TIMED SLEEP! -- "; $status = 1 if ( $status != 2 ); } elsif ($output_status eq "6"){ $returnstring = $returnstring . "UPS IS ON SOFTWARE BYPASS! -- "; $status = 1 if ( $status != 2 ); } elsif ($output_status eq "7"){ $returnstring = $returnstring . "UPS IS OFF! -- "; $status = 1 if ( $status != 2 ); } elsif ($output_status eq "8"){ $returnstring = $returnstring . "UPS IS REBOOTING! -- "; $status = 1 if ( $status != 2 ); } elsif ($output_status eq "9"){ $returnstring = $returnstring . "UPS IS ON SWITCHED BYPASS! -- "; $status = 1 if ( $status != 2 ); } elsif ($output_status eq "10"){ $returnstring = $returnstring . "UPS IS ON HARDWARE FAILURE BYPASS! -- "; $status = 1 if ( $status != 2 ); } elsif ($output_status eq "11"){ $returnstring = $returnstring . "UPS IS SLEEPING UNTIL POWER RETURN! -- "; $status = 1 if ( $status != 2 ); } elsif ($output_status eq "12"){ $returnstring = $returnstring . "UPS IS ON SMART TRIM! -- "; $status = 1 if ( $status != 2 ); } elsif ($output_status eq "13"){ $returnstring = $returnstring . "UPS IS ON ECO MODE! -- "; $status = 1 if ( $status != 2 ); } elsif ($output_status eq "14"){ $returnstring = $returnstring . "UPS IS ON HOT STANDBY! -- "; $status = 1 if ( $status != 2 ); } elsif ($output_status eq "15"){ $returnstring = $returnstring . "UPS IS PERFORMING BATTERY TEST! -- "; # $status = 1 if ( $status != 2 ); } elsif ($output_status eq "16"){ $returnstring = $returnstring . "UPS IS ON EMERGENCY STATIC BYPASS! -- "; $status = 1 if ( $status != 2 ); } elsif ($output_status eq "17"){ $returnstring = $returnstring . "UPS IS ON STATIC BYPASS STANDBY! -- "; $status = 1 if ( $status != 2 ); } elsif ($output_status eq "18"){ $returnstring = $returnstring . "UPS IS ON POWER SAVING MODE! -- "; $status = 1 if ( $status != 2 ); } elsif ($output_status eq "19"){ $returnstring = $returnstring . "UPS IS ON SPOT MODE! -- "; $status = 1 if ( $status != 2 ); } elsif ($output_status eq "20"){ $returnstring = $returnstring . "UPS IS ON ECONVERSION! -- "; $status = 1 if ( $status != 2 ); } else { $returnstring = $returnstring . "UNKNOWN OUTPUT STATUS! -- "; $status = 3 if ( ( $status != 2 ) && ( $status != 1 ) ); } if ($output_load > 90) { $returnstring = $returnstring . "OUTPUT LOAD $output_load% -- "; $perfdata = $perfdata . "'load'=$output_load "; $status = 2; } elsif ($output_load > 80) { $returnstring = $returnstring . "OUTPUT LOAD $output_load% -- "; $perfdata = $perfdata . "'load'=$output_load "; $status = 1 if ( $status != 2 ); } elsif ($output_load >= 0) { $returnstring = $returnstring . "OUTPUT LOAD $output_load% -- "; $perfdata = $perfdata . "'load'=$output_load "; } else { $returnstring = $returnstring . "OUTPUT LOAD UNKNOWN! -- "; $perfdata = $perfdata . "'load'=NAN "; $status = 3 if ( ( $status != 2 ) && ( $status != 1 ) ); } if ($temperature > 93) { $returnstring = $returnstring . "INTERNAL TEMP $temp F"; $perfdata = $perfdata . "'temp'=$temp "; $status = 2; } elsif ($temperature > 89) { $returnstring = $returnstring . "INTERNAL TEMP $temp F"; $perfdata = $perfdata . "'temp'=$temp "; $status = 1 if ( $status != 2 ); } elsif ($temperature >= 0) { $returnstring = $returnstring . "INTERNAL TEMP $temp F"; $perfdata = $perfdata . "'temp'=$temp "; } else { $returnstring = $returnstring . "INTERNAL TEMP UNKNOWN!"; $perfdata = $perfdata . "'temp'=NAN "; $status = 3 if ( ( $status != 2 ) && ( $status != 1 ) ); } } #################################################################### # help and usage information # #################################################################### sub usage { print << "USAGE"; ----------------------------------------------------------------- $script v$script_version Monitors PowerWare UPS via SNMP management card. Usage: $script -H <hostname> -C <community> [...] Options: -H Hostname or IP address -C Community (default is public) ----------------------------------------------------------------- Copyright 2004 Altinity Limited This program is free software; you can redistribute it or modify it under the terms of the GNU General Public License ----------------------------------------------------------------- USAGE exit 1; }
can we just modify the current code?
Yes, but we are not sure what changes have been made so I recommend using what was posted above.
ok i will give it a tryrkennedy wrote:Yes, but we are not sure what changes have been made so I recommend using what was posted above.
thanks
i modified the values according to this article and it works fine now
tank you though
you guys were great
https://exchange.nagios.org/directory/P ... ad/details
tank you though
you guys were great
Glad it's working! Mind if we close up this ticket?
