Runtime Error for host and service notification
Re: Runtime Error for host and service notification
That is great news!
If you made backups if the files I had you edit, you can revert the settings so it will not print out the debug and log info.
These are the files that were edited that you can put back to the original settings.
/usr/local/nagiosxi/scripts/handle_nagioscore_notification.php
/usr/local/nagiosxi/scripts/handle_nagioscore.inc.php
/etc/php.ini
Go ahead and setup a user to use the notification command and see if the emails are sent from the system now.
valmberg
Post by valmberg »
Thanks for all your help. I think we can lock this thread now.
Your welcome.
I'll close and lock the post as solved but if you have any questions in the future, please open a new post.
