CHECK_NRPE: Receive header underflow - only 0 bytes received
cocoyanouck
Re: CHECK_NRPE: Receive header underflow - only 0 bytes rece
Yes I think.
I run this command : apt install nagios-nrpe-server
On the nagios machine?cocoyanouck wrote:Yes I think.
You likely need the following for the check_nrpe plugin
apt install nagios-nrpe-plugin-
cocoyanouck
Sorry, Yes on the nagios-VZ machine.
And Yes I have launched nagios-nrpe-server and nagios-nrpe-plugin one after the other.
Please attach the full commands that are being executed that give the screenshots above
cocoyanouck
Please find the history of commands on this server :
So, apt nagios-nrpe-server found on line 70, but no nagios-nrpe-plugin.
I made a snapshot of this virtual machine, and configured it many times, so It seems this time, I have forgotten it ...
1 vi /etc/apt/sources.list
2 vi /etc/apt/sources.list
3 apt-get update
4 apt-get upgrade
5 apt-get dist-upgrade
6 apt-get autoremove
7 sudo apt-get install ssh
8 apt-get install ssh
9 cp /media/cdrom/VMwareTools-9.2.2-893683.tar.gz /usr/local/src
10 cp /media/cdrom/VMwareTools-10.1.15-6677369.tar.gz
11 cp /media/cdrom/VMwareTools-10.1.15-6677369.tar.gz /usr/local/src/
12 cd /usr/local/src/
13 tar xzf VMwareTools-10.1.15-6677369.tar.gz
14 cd vmware-tools-distrib/
15 ./vmware-install.pl
16 apt install nagios-nrpe-plugin
17 /usr/lib/nagios/plugins/check_nrpe
18 cd /usr/lib/nagios/plugins/
19 ls
20 cd
21 vi /etc/nagios-plugins/
22 cd /etc/nagios-plugins/
23 ls
24 cd config/
25 ls
26 vi check_nrpe.cfg
27 vi check_nrpe.cfg
28 vi check_nrpe.cfg
29 apt list --installed |grep nrpe
30 apt list --installed |grep libc6
31 uname -a
32 cat /etc/*release*
33 $
34 apt update
35 apt upgrade
36 /usr/lib/nagios/plugins/check_nrpe -H 10.0.2.130
37 /usr/lib/nagios/plugins/check_nrpe -H localhost
38 /usr/lib/nagios/plugins/check_nrpe -V
39 to 42 : (SOME BAD cp text)
43 apt-get install build-essential openssl perl make php-gd libgd2-xpm-dev libapache2-mod-php libperl-dev libssl-dev daemon apache2-utils unzip
44 useradd nagios
45 groupadd nagcmd
46 usermod -a -G nagcmd nagios
47 usermod -a -G nagcmd www-data
48 wget https://assets.nagios.com/downloads/nagioscore/releases/nagios-4.3.4.tar.gz
49 tar -zxvf nagios-4.3.4.tar.gz
50 cd nagios-4.3.4
51 ./configure --with-nagios-group=nagios --with-command-group=nagcmd --with-httpd_conf=/etc/apache2/sites-enabled/
52 make all
53 make install
54 make install-init
55 make install-config
56 make install-commandmode
57 make install-webconf
58 vi /usr/local/nagios/etc/objects/contacts.cfg
59 htpasswd -c /usr/local/nagios/etc/htpasswd.users nagiosadmin
60 a2enmod cgi
61 service apache2 restart
62 cd ..
63 wget https://nagios-plugins.org/download/nagios-plugins-2.2.1.tar.gz
64 tar -zxvf /tmp/nagios-plugins-2.2.1.tar.gz
65 tar -zxvf nagios-plugins-2.2.1.tar.gz
66 cd nagios-plugins-2.2.1
67 ./configure --with-nagios-user=nagios --with-nagios-group=nagios
68 make
69 make install
70 /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg
71 /etc/init.d/nagios start
72 systemctl enable nagios
73 apt install nagios-nrpe-server
74 vi /etc/nagios/nrpe.cfg
75 /etc/init.d/nagios start
76 system nrpe restart
77 systemctl enable nrpe.service
78 service nrpe start
79 service nrpe restart
80 systemctl start nrpe.service
81 restart nrpe
82 cd /usr/local/nagios/libexec/
83 ls
84 apt list --installed |grep nrpe
85 /usr/lib/nagios/plugins/check_nrpe -H 10.0.2.130
86 cd
87 /usr/lib/nagios/plugins/check_nrpe -H 10.0.2.130
88 cd /usr/lib/nagios/plugins/
89 ls
90 ./check_nrpe -H localhost
91 ./check_nrpe -H 10.0.2.130
92 vi /etc/nagios/nrpe.cfg
93 lsof -i:5666
94 chkconfig --add nrpe
95 cd
96 chkconfig --add nrpe
97 iptables -I RH-Firewall-1-INPUT 10 -p tcp --dport 5666 -j ACCEPT
98 /etc/init.d/nagios-nrpe-server start
99 cd /usr/lib/nagios/plugins/
100 ./check_nrpe -H 10.0.2.130
101 vi /usr/local/nagios/etc/objects/commands.cfg
102 ./check_nrpe -H 10.0.2.130
103 vi /etc/nagios/nrpe.cfg
104 ./check_nrpe -H 10.0.2.130
105 ./check_nrpe -H localhost
106 netstat -nlp|grep 5666
107 apt install netstat
108 apt install net=tools
109 apt install net-tools
110 netstat -nlp|grep 5666
111 cd /etc/nagios/
112 cat nrpe.cfg
113 /etc/init.d/nagios-nrpe-server start
114 cd /usr/lib/nagios/plugins/
115 ./check_nrpe -H 10.0.2.130
116 cd /usr/lib/nagios/plugins/
117 ./check_nrpe -H localhost
118 wget http://prdownloads.sourceforge.net/sourceforge/nagios/nagios-4.4.1.tar.gz
119 tar xzf nagios-4.4.1.tar.gz
120 cd nagios-4.4.1
121 ./configure --with-command-group=nagcmd
122 make all
123 make install
124 /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg
125 service nagios restart
126 D3bi@n
127 su
128 su
129 cd /usr/lib/nagios/plugins/
130 ./check_nrpe -h|head -8
131 ./check_nrpe -H localhost
132 ./check_nrpe -H 10.0.2.130
133 cd /usr/lib/nagios/plugins/
134 ./check_nrpe -H 10.0.2.130
135 ./check_nrpe -H localhost
136 service nrpe stop
137 service nrpe.service stop
138 chmod 777 /etc/nagios/nrpe/cfg
139 chmod 777 /etc/nagios/nrpe.cfg
140 service start nrpe
141 service nrpe start
142 service nrpe start
143 /etc/init.d/nagios-nrpe-server start
144 cd /usr/local/nagios/libexec/
145 ls
146 cd /usr/lib/nagios/
147 ls
148 cd plugins/
149 ms
150 ls
151 ./check_nrpe -H 10.0.2.130
152 cd /usr/lib/nagios/plugins/
153 ./check_nrpe -H localhost
154 vi /etc/nagios/nrpe.cfg
155 vi /etc/nagios/nrpe.cfg
156 service nrpe restart
157 restart nrpe
158 reboot
159 cd /usr/lib/nagios/plugins/
160 ./check_nrpe -H localhost
161 ./check_nrpe -H 10.0.2.130
162 ./check_nrpe -H 10.0.2.130
163 cp /usr/lib/nagios/plugins/check_* /usr/local/nagios/libexec
164 /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg
165 service nagios restart
166 historyI made a snapshot of this virtual machine, and configured it many times, so It seems this time, I have forgotten it ...
Did everything work after installing it?
cocoyanouck
Nop this had never work on this server.
Please post the output of the following from the nagios server
per your screenshot the file doesn't even exist
ls -al /usr/local/nagios/libexec/check_nrpe-
cocoyanouck
-rwxr-xr-x 1 root nagios 43056 juil. 2 11:00 /usr/local/nagios/libexec/check_nrpe-
your screenshot in Capture.PNG of this post shows that the file doesn't exist
https://support.nagios.com/forum/viewto ... 30#p255342
Are you sure these are the same servers?
Can you show the nagios configs for these services?
