Informix Monitoring
donnyforbes
Re: Informix Monitoring
Post by donnyforbes »
This is the same plugin from the previous that you worked on me with
OK, take a look at the previous post then.
donnyforbes
ok I have been... everything looks correct. I looked at the script and even ran this line from it and got the correct output.
[root@huey libexec]# $INFORMIXDIR/bin/onstat -
IBM Informix Dynamic Server Version 12.10.FC8W2WE -- Updatable (Sec) -- Up 20 days 16:55:53 -- 1138808 Kbytes
[root@huey libexec]# /usr/local/nagios/libexec/check_informix.sh /usr/informix hueynet
IBM Informix Dynamic Server Version 12.10.FC8W2WE -- Updatable (Sec) -- Up 20 days 17:29:51 -- 1138808 Kbytes
[code][root@nag libexec]# /usr/local/nagios/libexec/check_nrpe -H 192.168.1.42 -c check_informix -a '/usr/informix hueynet'
NRPE: Unable to read output
You have mail in /var/spool/mail/root
[root@nag libexec]#
[/code]
Not sure what is going on. I need to get this working and also, I have another one I need to get working as well.
Login to the huey server and add the following lines to the /etc/sudoers file on the remote servers.
nagios ALL=NOPASSWD: /usr/local/nagios/libexec/check_informix.sh
nagios ALL=NOPASSWD: /usr/informix/bin/onstat *
then run the following to test and see if the plugin runs as the nagios user and post the output.
su - nagios
It is passes, try running it from the Nagios server to see if it functions from there.
donnyforbes
I got this
[nagios@huey ~]$ /usr/local/nagios/libexec/check_informix.sh /usr/informix hueynet
-bash: /usr/local/nagios/libexec/check_informix.sh: Permission denied
[nagios@huey ~]$
do I need to change the script to this
chmod 777 & chgrp nagios.nagios
Here is what the permission are now...
[nagios@huey ~]$ ls -l /usr/local/nagios/libexec/check_informix.sh
-rwxr-x---. 1 root root 684 Nov 19 12:35 /usr/local/nagios/libexec/check_informix.sh
Run these commands again to set the permissions on that plugin again.
chown nagios.nagios /usr/local/nagios/libexec/check_informix.sh
chmod a+x /usr/local/nagios/libexec/check_informix.sh
donnyforbes
here is the output from the remote server.
IBM Informix Dynamic Server Version 12.10.FC8W2WE -- Updatable (Sec) -- Up 20 days 19:32:58 -- 1138808 Kbytes
Here is the output from the NAGIOS server.
[root@nag libexec]# [nagios@huey ~]$ /usr/local/nagios/libexec/check_informix.sh /usr/informix hueynet
-bash: [nagios@huey: command not found
[root@nag libexec]# IBM Informix Dynamic Server Version 12.10.FC8W2WE -- Updatable (Sec) -- Up 20 days 19:32:58 -- 1138808 Kbytes
-bash: syntax error near unexpected token `('
[root@nag libexec]#
Also when I run this from NAGIOS
IBM Informix Dynamic Server Version 12.10.FC8W2WE -- Updatable (Sec) -- Up 20 days 19:37:43 -- 1138808 Kbytes
[root@nag libexec]#
Any thoughts?
donnyforbes
I tested on all 3 remote servers and NAGIOS server after making those changes. And it seems to be good. Here is the output from the NAGIOS server
[root@nag libexec]# /usr/local/nagios/libexec/check_nrpe -H 192.168.39.10 -c check_informix -a '/usr/informix louienet'
IBM Informix Dynamic Server Version 12.10.FC8W2WE -- Updatable (RSS) -- Up 23 days 16:31:38 -- 1138808 Kbytes
[root@nag libexec]#
IBM Informix Dynamic Server Version 12.10.FC8W2WE -- Updatable (Sec) -- Up 20 days 19:48:19 -- 1138808 Kbytes
[root@nag libexec]#
[root@nag libexec]# /usr/local/nagios/libexec/check_nrpe -H 192.168.1.43 -c check_informix -a '/usr/informix dueynet'
IBM Informix Dynamic Server Version 12.10.FC8W2WE -- On-Line (Prim) -- Up 23 days 16:34:54 -- 1204344 Kbytes
[root@nag libexec]#
Now what I need to do is add to nagios right? I have this in there already. I believe, I will send you a screenshot shortly...
The correct command to run on the nagios server to run the plugin on the remote server is this.
which is your 3rd example in your post and it passed.
Your second example looks like you tried to run this as a command "[nagios@huey ~]$" which would fail as it is not valid.
donnyforbes
I got the command to run on all 3 servers and NAGIOS. I went and enable the service that was in XI and here is the screenshot. What does the status of 'Unknown" mean" It should say "OK"
