How to stop a currently running snapshot?
Re: How to stop a currently running snapshot?
Should I run each command you listed individually or can I run them as a block all together?
I tried to start by just deleting the curator job, but it threw an error:
When I look at the snapshot jobs I'm seeing this:
root@nagioslscc2:/root> curl -XDELETE 'http://localhost:9200/_snapshot/NLSREPCC/curator-curator-20191029053112'
{"error":"RemoteTransportException[[fc00210a-5231-46f3-84f2-6e3c61c7ac0e][inet[/10.128.207.112:9300]][cluster:admin/snapshot/delete]]; nested: SnapshotMissingException[[NLSREPCC:curator-curator-20191029053112] is missing]; nested: FileNotFoundException[/nlsrepcc/snapshot-curator-curator-20191029053112 (No such file or directory)]; ","status":404}Code: Select all
"snapshot" : "curator-20191029053112",
"version_id" : 1070699,
"version" : "1.7.6",
"indices" : [ "logstash-2019.10.08", "logstash-2019.10.09", "logstash-2019.10.10", "logstash-2019.10.11", "logstash-2019.10.12", "logstash-2019.10.13", "logstash-2019.10.14", "logstash-2019.10.15", "logstash-2019.10.16", "logstash-2019.10.17", "logstash-2019.10.18", "logstash-2019.10.19", "logstash-2019.10.20", "logstash-2019.10.21", "logstash-2019.10.22", "logstash-2019.10.23", "logstash-2019.10.24", "logstash-2019.10.25", "logstash-2019.10.26", "logstash-2019.10.27", "logstash-2019.10.28" ],
"state" : "PARTIAL",
"start_time" : "2019-10-29T05:31:12.493Z",
"start_time_in_millis" : 1572327072493,
"end_time" : "2019-10-29T21:14:22.438Z",
"end_time_in_millis" : 1572383662438,
"duration_in_millis" : 56589945,
"failures" : [ {
"node_id" : "pcqYieAcSAK7http3p3yzQ",
"index" : "logstash-2019.10.11",
"reason" : "IndexShardSnapshotFailedException[[logstash-2019.10.11][3] Failed to perform snapshot (index files)]; nested: FileSystemException[/nlsrepcc/indices/logstash-2019.10.11/3/__4c: Resource temporarily unavailable]; ",
"shard_id" : 3,
"status" : "INTERNAL_SERVER_ERROR"
"reason" : "IndexShardSnapshotFailedException[[logstash-2019.10.11][4] Failed to perform snapshot (index files)]; nested: IOException[Input/output error]; ",
"shard_id" : 4,
"index" : "logstash-2019.10.13",
"reason" : "IndexShardSnapshotFailedException[[logstash-2019.10.13][3] Failed to perform snapshot (index files)]; nested: IOException[Input/output error]; ",
"shard_id" : 3,
"index" : "logstash-2019.10.10",
"reason" : "IndexShardSnapshotFailedException[[logstash-2019.10.10][3] Failed to perform snapshot (index files)]; nested: IOException[Input/output error]; ",
"shard_id" : 3,
"index" : "logstash-2019.10.22",
"reason" : "IndexShardSnapshotFailedException[[logstash-2019.10.22][4] Failed to perform snapshot (index files)]; nested: IOException[Input/output error]; ",
"shard_id" : 4,
"shards" : {
"total" : 105,
"failed" : 5,
"successful" : 100
Do them in a block(note the simcolons betwee commands):
Do it directly on the console as well so we don't run into any issues with the ssh client timing out and can see status messages.
/usr/local/nagioslogserver/scripts/curator.sh snapshot --repository "NLSREPCC" --ignore_unavailable indices --older-than 15 --time-unit days --timestring %Y.%m.%d;/usr/local/nagioslogserver/scripts/curator.sh snapshot --repository "NLSREPCC" --ignore_unavailable indices --older-than 10 --time-unit days --timestring %Y.%m.%d;/usr/local/nagioslogserver/scripts/curator.sh snapshot --repository "NLSREPCC" --ignore_unavailable indices --older-than 5 --time-unit days --timestring %Y.%m.%d;/usr/local/nagioslogserver/scripts/curator.sh snapshot --repository "NLSREPCC" --ignore_unavailable indices --older-than 1 --time-unit days --timestring %Y.%m.%dAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
Small typo. This should work better:
curl -XDELETE 'http://localhost:9200/_snapshot/NLSREPCC/curator-20191029053112'As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
When you run a snapshot manually like this, does it not show up in the Command Subsystem?
I'm trying to get a sense of if it's still running and when it's done. I guess I can just keep running the all?pretty command from an SSH session?
Ok, the snapshot completed. Please leave this support thread open. I would like to see a snapshot run on it's own this evening.
I don't think it will show up in the command subsytem since it wasn't initialized there, but you should see output on the command line when you run it and it wont allow you to use the command line until it is complete. You can also check to see if the curator script is running from another terminal window:
ps aux | grep curatorAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
Looks like our updates passed each other. Glad to hear the commands worked. We'll wait for your update.
The snapshot from last night finished this morning PARTIAL, here's the output with errors:
Anything I should be concerned with or are these standard errors? Thank you.
"snapshot" : "curator-20191031053043",
"indices" : [ "logstash-2019.10.10", "logstash-2019.10.11", "logstash-2019.10.12", "logstash-2019.10.13", "logstash-2019.10.14", "logstash-2019.10.15", "logstash-2019.10.16", "logstash-2019.10.17", "logstash-2019.10.18", "logstash-2019.10.19", "logstash-2019.10.20", "logstash-2019.10.21", "logstash-2019.10.22", "logstash-2019.10.23", "logstash-2019.10.24", "logstash-2019.10.25", "logstash-2019.10.26", "logstash-2019.10.27", "logstash-2019.10.28", "logstash-2019.10.29", "logstash-2019.10.30" ],
"start_time" : "2019-10-31T05:30:44.111Z",
"start_time_in_millis" : 1572499844111,
"end_time" : "2019-10-31T15:36:03.246Z",
"end_time_in_millis" : 1572536163246,
"duration_in_millis" : 36319135,
"failures" : [ {
"node_id" : "D_ao-uEBSi62BE2caGHsHw",
"index" : "logstash-2019.10.24",
"reason" : "IndexShardSnapshotFailedException[[logstash-2019.10.24][4] Failed to perform snapshot (index files)]; nested: IOException[Input/output error]; ",
"shard_id" : 4,
"index" : "logstash-2019.10.25",
"reason" : "IndexShardSnapshotFailedException[[logstash-2019.10.25][2] Failed to perform snapshot (index files)]; nested: FileNotFoundException[/nlsrepcc/indices/logstash-2019.10.25/2/__5 (Stale file handle)]; ",
"shard_id" : 2,
"reason" : "IndexShardSnapshotFailedException[[logstash-2019.10.25][3] Failed to perform snapshot (index files)]; nested: IOException[Input/output error]; ",
"shard_id" : 3,
"node_id" : "olHQlucoSmO-CIohLIKLhQ",
"index" : "logstash-2019.10.18",
"reason" : "IndexShardSnapshotFailedException[[logstash-2019.10.18][2] Failed to perform snapshot (index files)]; nested: IOException[Input/output error]; ",
"shard_id" : 2,
"index" : "logstash-2019.10.21",
"reason" : "IndexShardSnapshotFailedException[[logstash-2019.10.21][0] Failed to perform snapshot (index files)]; nested: FileNotFoundException[/nlsrepcc/indices/logstash-2019.10.21/0/__1 (Stale file handle)]; ",
"shard_id" : 0,
"shards" : {
"total" : 105,
"failed" : 5,
"successful" : 100
Are there any unassigned shards or is the cluster in a state other than green? It may have been a temporary issue and since corrected itself. Keep an eye out for tomorrow's snapshot results or force another snapshot now. PM me a fresh profile if you continue getting problems with these shards.
