Option to monitor or check custom made services in Ubuntu
Re: Option to monitor or check custom made services in Ubunt
Can you post the latest version of your script on the forum?
When you run the script locally on the client, and then run:
echo $?
what is the output that you see (when the "cmmt_revolution" is running and when it is stopped)?
epixelitsupport
Post by epixelitsupport »
output when it is not running: https://prnt.sc/qcmppy
When it is running: https://prnt.sc/qcmr34
servicescript.sh
scriptfile
(86 Bytes) Downloaded 180 times
Looking at the script it was not capturing the proper exit code of the systemctl command
If you modify to the following you should get the desired results
#!/bin/bash
status=$(systemctl status cmmt_revolution)
exitcode=$?
echo "$status" | tr -cd '\11\12\15\40-\176'
if [ $exitcode -eq 0 ]; then
    exit 0
else
    exit 2
fi
As a FYI, a general rule of thumb support on this forum should be related to Nagios Core, debugging your custom scripts is not within the scope of Nagios project support
epixelitsupport
Worked !!! Thanks, A lot
