Hi @Support_Talea,
You can alter the check command by adding -2 option to use the version 2 packets.
See:
https://support.nagios.com/kb/article/n ... s-786.html
The issue here is with the Run Check Command feature in the GUI of the Core Configuration Manager. I would recommend testing from the CLI to verify the command for NSClient as a workaround.
If you continue to have issues, please open a separate forum topic.
Best Regards,
Benjamin
NRPE 4.0.3 and the NSClient - CHECK_NRPE: Invalid packet ver
benjaminsmith
Re: NRPE 4.0.3 and the NSClient - CHECK_NRPE: Invalid packet
