2012 R1.6 : apply configuration doesn't work
Frédéric GRANAT
Re: 2012 R1.6 : apply configuration doesn't work
Post by Frédéric GRANAT »
Done, but that doesn't solve my problem.
Rgds,
Frederic
Can you show the exact command that you are running from the command line, and the output of it (hide the sensitive data)?
Frédéric GRANAT
[root@nagiosxi libexec]# ll | grep 500
-rwxr-xr-x 1    500 nagios   6897 Sep 27  2011 check_asterisk.pl
-rw-r--r-- 1    500 nagios      0 Sep  6  2011 check.bat
-rwxr-xr-x 1    500 users    4173 Oct 22 11:49 check_bl
-rwxr-xr-x 1    500 nagios   2289 Oct 22 11:49 check_bpi.php
-rwxr-xr-x 1    500 nagios     45 Sep  6  2011 check_dummy.sh
-rwxr-xr-x 1    500 nagios  38345 Oct 22 11:49 check_email_delivery
-rwxr-xr-x 1    500 nagios  20511 Oct 22 11:49 check_email_delivery_epn
-rwxr-xr-x 1    500 nagios  20039 Aug 29  2011 check_email_loop.pl
-rwxr-xr-x 1    500 nagios  82841 Oct 22 11:49 check_esx3.pl
-rwxr-xr-x 1    500 nagios   3437 Oct 22 11:49 check_ftp_fully
-rwxr-xr-x 1    500 nagios  18663 Oct 25 12:28 check_iftraffic3.pl
-rwxr-xr-x 1    500 nagios  35413 Oct 22 11:49 check_imap_receive
-rwxr-xr-x 1    500 nagios  15576 Oct 22 11:49 check_imap_receive_epn
-rwxr-xr-x 1    500 nagios  12537 Oct 22 11:49 check_mssql
-rwxr-xr-x 1    500 nagios  98717 Aug 29  2011 check_mysql_health
-rwxr-xr-x 1    500 nagios   6364 Oct 22 11:49 check_nagios_performance.php
-rwxr-xr-x 1    500 nagios  17400 Oct 22 11:49 check_nagiosxiserver.php
-rwxrwxr-x 1    500 nagios  62333 Sep 27  2011 check_nrpe
drwxr-xr-x 5    500 nagios   4096 Oct 20  2011 check_oracle_health-1.7.2
-rwxr-xr-x 1    500 nagios   6189 Oct 22 11:42 check_pnp_rrds.pl
-rwxr-xr-x 1    500 nagios 281655 Oct 22 11:49 check_postgres.pl
-rwxr-xr-x 1    500 nagios  23327 Oct 22 11:49 check_radius_adv
-rwxr-xr-x 1    500 nagios   6768 Sep 19 11:06 check_riverbed_status
-rwxr-xr-x 1    500 nagios   2998 Oct 24 09:08 check_route
-rwxr-xr-x 1    500 nagios   9232 Aug 29  2011 check_rrdtraf
-rwxr-xr-x 1    500 nagios   5299 Aug 29  2011 check_rrdtraf.php
-rwxr-xr-x 1    500 nagios     76 Sep  6  2011 check.sh
-rwxr-xr-x 1    500 nagios   6563 Sep  6  2011 check_shinken.py
-rwxr-xr-x 1    500 nagios   7599 Sep 27  2011 check_sip
-rwxr-xr-x 1    500 nagios  20226 Oct 22 11:49 check_smtp_send
-rwxr-xr-x 1    500 nagios  10440 Oct 22 11:49 check_smtp_send_epn
-rwxr-xr-x 1    500 nagios  10951 Aug 29  2011 check_snmp_boostedge.pl
-rwxr-xr-x 1    500 nagios  17866 Aug 29  2011 check_snmp_cpfw.pl
-rwxr-xr-x 1    500 nagios   8747 Aug 29  2011 check_snmp_css_main.pl
-rwxr-xr-x 1    500 nagios  16786 Aug 29  2011 check_snmp_css.pl
-rwxr-xr-x 1    500 nagios  33562 Aug 29  2011 check_snmp_env.pl
-rwxr-xr-x 1    500 nagios  31919 Aug 29  2011 check_snmp_int.pl
-rwxr-xr-x 1    500 nagios  10108 Aug 29  2011 check_snmp_linkproof_nhr.pl
-rwxr-xr-x 1    500 nagios  22839 Oct 22 11:49 check_snmp_load.pl
-rwxr-xr-x 1    500 nagios  18734 Aug 29  2011 check_snmp_mem.pl
-rwxr-xr-x 1    500 nagios  53265 Sep  5  2011 check_snmp_mgeeaton_ups.pl
-rwxr-xr-x 1    500 nagios   4312 Sep  5  2011 check_snmp_mge_ups
-rwxr-xr-x 1    500 nagios  11898 Aug 29  2011 check_snmp_nsbox.pl
-rwxr-xr-x 1    500 nagios  26182 Oct 22 11:49 check_snmp_process.pl
-rwxr-xr-x 1    500 nagios  25483 Oct 22 11:49 check_snmp_storage.pl
-rwxr-xr-x 1    500 nagios  14489 Aug 29  2011 check_snmp_vrrp.pl
-rwxr-xr-x 1    500 nagios  12058 Oct 22 11:49 check_snmp_win.pl
-rwxr-xr-x 1    500 nagios    169 Sep 27  2011 check_vmware_config_vcenter01_example
-rwxr-xr-x 1    500 nagios  59991 Sep 27  2011 check_vmware.pl
-rwxr-xr-x 1    500 nagios    307 Aug 29  2011 check_webinject.sh
-rwxr-xr-x 1    500 nagios   2411 Oct 22 13:58 check_wmi_plus.conf
-rw-r--r-- 1    500 nagios   2358 Sep 23  2011 check_wmi_plus.conf.sample
drwxr-xr-x 2    500 nagios   4096 Oct 22 13:56 check_wmi_plus.d
-rwxr-xr-x 1    500 nagios  46543 Oct 22 11:50 check_wmi_plus.ini
-rwxr-xr-x 1    500 nagios 237169 Oct 22 15:21 check_wmi_plus.pl
-rw-r--r-- 1    500 nagios  83948 Sep 23  2011 check_wmi_plus.README.txt
-rw-r--r-- 1    500 nagios    215 Sep 19  2011 cookie.txt
-rw-r--r-- 1    500 nagios    258 Sep  6  2011 getwmic.sh
-rwxr-xr-x 1    500 nagios   6263 Sep  6  2011 link_vmware_host_vm.py
-rwxr-xr-x 1    500 nagios     47 Sep 23  2011 lol.pl
-rwxr-xr-x 1    500 nagios  12029 Sep  6  2011 nmap_discovery_runner.py
-rwxr-xr-x 1    500 nagios     90 Sep  6  2011 notify.sh
-rw-r--r-- 1    500 nagios   6014 Sep  6  2011 nsca_client.py
-rwxr-xr-x 1    500 nagios  42724 Oct 22 11:42 process_perfdata.pl
-rwxr-xr-x 1    500 nagios   2523 Sep  6  2011 sendmailhost.pl
-rwxr-xr-x 1    500 nagios   2721 Sep  6  2011 sendmailservices.pl
[root@nagiosxi libexec]# find /usr/local/nagios/libexec -user 500 -exec chown nagios.nagios {} \;
I am sorry I was not clear on this. I need the command that you are having issues with (your second problem)...
2) 1 service in critical state, type = Bandwidth
Status information : Return code of 13 is out of bounds
Frédéric GRANAT
check_snmp_int_bw
commande line = $USER1$/check_iftraffic3.pl -H $HOSTADDRESS$ -C $ARG1$ -i $ARG2$ $ARG3$
command defined at the service level (not at template level)
abrist
Red Shirt
Post by abrist »
What values are you using for the $ARGn$s?
Frédéric GRANAT
ARG1=ro
ARG2=226
ARG3=-b 1 -u g -w 80 -c 90
That check doesn't work since update 2012 R.1.6
Post by slansing »
What does the console tell you when you run the command directly from the command line? Bypassing the Nagios side configuration entirely.
Frédéric GRANAT
1) By Using SSH :
/usr/local/nagios/libexec/check_iftraffic3.pl -H 172.31.0.2 -C ro -i 226 -b 1 -u g -w 80 -c 90
Average IN: 7.17KBs (0.01%), Average OUT: 7.13KBs (0.01%)
Total RX: 6223.67 MBytes, Total TX: 6219.56 MBytes|inUsage=0.01%;80;90 outUsage=0.01%;80;90 inBandwidth=7.17KBs outBandwidth=7.13KBs inAbsolut=6525988376 outAbsolut=6521679682
2) By testing check command (on service) :
Testing check from command line...
COMMAND: /usr/local/nagios/libexec/check_iftraffic3.pl -H 172.31.0.2 -C ro -i 226 -b 1 -u g -w 80 -c 90
OUTPUT:
can we see the current permissions of this exact plugin
ls -l /usr/local/nagios/libexec/check_iftraffic3.pl
Also, can you run
cat /etc/group|nag
