Nagios on XenServer 5.5
brianweeks22
Re: Nagios on XenServer 5.5
Post by brianweeks22 »
FROM NAGIOS SERVER
[root@rodan2 nagios]# /usr/lib/nagios/plugins/check_nrpe -H <IP ADDRESS> -n
CHECK_NRPE: Error receiving data from daemon.
FROM CLIENT:
[root@XenHost8 nagios]# service nrpe status
nrpe (pid 19126) is running...
[root@XenHost8 nagios]# service xinetd status
xinetd: unrecognized service
abrist
Red Shirt
Post by abrist »
Alright ssl is most definitely working. (you can remove the "-n" from your nrpe checks)
Edit the nrpe.cfg file on the remote host and look for the line: allowed_hosts=127.0.0.1 You will need to add the ip address of your Nagios server to this line (it is comma-separated).
nano /usr/local/nagios/etc/nrpe.cfg
(Your nrpe.cfg file may be located somewhere else. If you do not have one, you should find the sample-config in the nrpe source directory.)
Change:
To:
allowed_hosts=127.0.0.1,<nagios server ip>
brianweeks22
I already had that completed..
(0.0.0.0=nagios server)
allowed_hosts=127.0.0.1,0.0.0.0
do i need to put spaces after the comma?
abrist
Red Shirt
Post by abrist »
No, it just needs to have unix line endings. Have you built the nagios-plugins on the remote system yet? I ask because we can use the "check_nrpe" plugin to troubleshoot further on the remote host by running it locally to see if it can connect to itself. If the architecture is the same, you could just copy over the "check_nrpe" binary from the nagios server to plugins directory on the remote host and then run the following on the remote host:
/path/to/plugins/check_nrpe -H 127.0.0.1
brianweeks22
[root@XenHost8 plugins]# /usr/lib/nagios/plugins/check_load -H 127.0.0.1
/usr/lib/nagios/plugins/check_load: invalid option -- 'H'
Usage:
check_load [-r] -w WLOAD1,WLOAD5,WLOAD15 -c CLOAD1,CLOAD5,CLOAD15
abrist
Red Shirt
Post by abrist »
Check load will run locally. We want to connect to the nrpe daemon on the remote host from the remote host. You will have to use check_nrpe to do this.
brianweeks22
[root@xenhost7 libexec]# find / -name check_nrpe
returned nothing
abrist
Red Shirt
Post by abrist »
Yeah, you will either need to build the nagios-plugins package on the remote host, or copy the check_nrpe binary from the nagios server to the remote host's plugin directory (only if the archs are the same).
brianweeks22
attached is from a working server.. under the plugins, there is no check_nrpe
i also attached a screenshot of the services running on that server..
/usr/lib/nagios/plugins is where I located the plugins..
under /usr/local/nagios/libexec i also attached a screenshot of that as well..
NagPlugins.doc
(435.5 KiB) Downloaded 229 times
abrist
Red Shirt
Post by abrist »
I understand that your other servers do not have the check_nrpe plugin as it is the checking binary and usually only on the nagios server. I just wanted to try to connect locally (from check_nrpe to the nrpe server on the same box) to further drill down the issue.
