I installed nagios trough this guide:
http://www.unixmen.com/how-to-install-a ... n-freebsd/
Maybe i should try to install nagios on a diffirent Linux/unix? or is there a beter install guide if this one isnt the correct one?
i cant make non-official plugins to work
Re: i cant make non-official plugins to work
CentOS will have the most support from us, not to mention most of the official docs assume that you use cent.
(sorry for this way to long reply, i did massive amounts of research and such..reinstalls)
I upgraded nagios from 3.1 to 4.0.2 (and the newest nagios-plugin) and i have installed it on Centos.
i get very good results from check_snmp, instead of OK - STATUS 2 i get OK -STATUS Running(2). i can also monitor switch ports with check_snmp (including check_mrtg)
All nice.
But "third-party" plugins: It is WORKING!
Toner black
CRITICAL 03-17-2014 11:40:37 0d 0h 0m 49s 1/3 Canon C-EXV 29 Black Toner is at 5% - CRITICAL!
Thanks for all the reply's. i learned alot from those replies!
All nice.
Toner black
I will admit I was a little scared when I saw a reply from a post made in September of last year, but I am glad everything worked out for you!
Since things seem to be going well I will be locking this topic now, but feel free to open another if you need anything in the future.
