Nagios Map
abrist
Red Shirt
Re: Nagios Map
Post by abrist »
Looks like you are missing some package dependencies:
*** GD, PNG, and/or JPEG libraries could not be located... *********
Boutell's GD library is required to compile the statusmap, trends
and histogram CGIs.  Get it from http://www.boutell.com/gd/, compile
it, and use the --with-gd-lib and --with-gd-inc arguments to specify
the locations of the GD library and include files.
NOTE: In addition to the gd-devel library, you'll also need to make
      sure you have the png-devel and jpeg-devel libraries installed
      on your system.
NOTE: After you install the necessary libraries on your system:
      1. Make sure /etc/ld.so.conf has an entry for the directory in
         which the GD, PNG, and JPEG libraries are installed.
      2. Run 'ldconfig' to update the run-time linker options.
      3. Run 'make clean' in the Nagios distribution to clean out
         any old references to your previous compile.
      4. Rerun the configure script.
NOTE: If you can't get the configure script to recognize the GD libs
      on your system, get over it and move on to other things.  The
      CGIs that use the GD libs are just a small part of the entire
      Nagios package.  Get everything else working first and then
      revisit the problem.  Make sure to check the nagios-users
      mailing list archives for possible solutions to GD library
      problems when you resume your troubleshooting.
Lets try to get the dependencies:
yum install -y gd gd-devel png-devel jpeg-devel
Afterward, reconfigure and make clean:
./configure --with-command-group=nagcmd
make clean
make all
make install
diverseft
Re: Nagios Map
Post by diverseft »
yum install -y gd gd-devel png-devel jpeg-devel Gives me:
Setting up Install Process
No package gd available.
No package gd-devel available.
No package png-devel available.
No package jpeg-devel available.
Nothing to do
abrist
Red Shirt
Re: Nagios Map
Post by abrist »
You may need to enable some repos . . . what distro/version are you running?
diverseft
Re: Nagios Map
Post by diverseft »
Running 12.04.3 Ubuntu server
diverseft
Re: Nagios Map
Post by diverseft »
If I run "yum repolist all" I get repolist: 0
sreinhardt
-fno-stack-protector
Re: Nagios Map
Post by sreinhardt »
you would need to use apt-get and find the appropriate ubuntu package names, they often differ from cent\rhel names to some extent.
diverseft
Re: Nagios Map
Post by diverseft »
So I tried:
sudo apt-get install php5-gd
make clean
make all
make install
/etc/init.d/nagios restart
Still not working
abrist
Red Shirt
Re: Nagios Map
Post by abrist »
Ubuntu Packages:
apt-get install libgd2-xpm php5-gd libgd2-xpm-dev
make clean
make all
make install
make install-cgis
If you see the error:
[snip]
Then you are still missing required packages.
diverseft
Re: Nagios Map
Post by diverseft »
THANK YOU everyone (particularly abrist and sreinhardt) who has helped in this thread. I finally got it working with this command:
sudo apt-get install libgd2-xpm-dev
from here: http://nagios.sourceforge.net/docs/3_0/ ... buntu.html - followed by:
make clean
make all
make install
As stated before, my Linux skills basic hence the struggle. Why would this be required since upgrading Nagios?
Anyway, Thanks again. Really happy I have the maps working :)
abrist
Red Shirt
Re: Nagios Map
Post by abrist »
diverseft wrote:As stated before, my Linux skills basic hence the struggle. Why would this be required since upgrading Nagios?
Not entirely sure. Most of the packages you were missing were most likely required for earlier versions as well. Maybe they were too far out of date?
Anyways, glad we could help you resolve this. You may want to make a mental (or physical) note about which packages you had to install for future cases. Happy trails.
