CHECK_NRPE: Socket timeout after 20 seconds.
josnavch
Re: CHECK_NRPE: Socket timeout after 20 seconds.
Post by josnavch »
Hello Kakaluru
The first thing you need is to change the following line in the hosts file nrpe.cfg BUGZILLABCK
before
allowed_hosts = 127.0.0.1
After
allowed_hosts = 127.0.0.1, IP Nagios Server
before
dont_blame_nrpe = 0
After
dont_blame_nrpe = 1
At the end of the file you have all commands with arguments marked with # if you will use and additional descomentarlos should rename them as follows
before
#command[check_users]=/usr/local/nagios/libexec/check_users -w $ARG1$ -c $ARG2$
#command[check_load]=/usr/local/nagios/libexec/check_load -w $ARG1$ -c $ARG2$
#command[check_disk]=/usr/local/nagios/libexec/check_disk -w $ARG1$ -c $ARG2$ -p $ARG3$
#command[check_procs]=/usr/local/nagios/libexec/check_procs -w $ARG1$ -c $ARG2$ -s $ARG3$
After
command[check_users_arg]=/usr/local/nagios/libexec/check_users -w $ARG1$ -c $ARG2$
command[check_load_arg]=/usr/local/nagios/libexec/check_load -w $ARG1$ -c $ARG2$
command[check_disk_arg]=/usr/local/nagios/libexec/check_disk -w $ARG1$ -c $ARG2$ -p $ARG3$
command[check_procs_arg]=/usr/local/nagios/libexec/check_procs -w $ARG1$ -c $ARG2$ -s $ARG3$
This way you can have those already with the arguments for and additional templates can use the latter for exceptions.
After these changes you must restart the NRPE or Xinet and you re-try.
Jose Navarrete
Thanks, josnavch!
kakaluru
Post by kakaluru »
Hi Josnovach,
Let me know few points before updating nrpe.cfg
1. MySQL Replication is happening between BUGZILLABackupserver and Production Server. If i do any changes in nrpe.cfg is there any affect on MySQL Replication process in BUGZILLABackupserver?
josnavch
Post by josnavch »
hi kakaluru
And should not affect the replication process database has no relationship with the nrpe process.
An important detail is that the NRPE is and always should be this rule is for monitoring not for automation of tasks.
It's a fine line that often thinks as monitoring goes to validate processes and services should not be used to automate tasks, this monitoring becomes meaningless and threatens the security and can be used for other things .
Jose Navarrete
Post by slansing »
As josnavch mentioned,
It should have no impact on the DB or it's replication status.
kakaluru
Post by kakaluru »
I made the changes in nrpe.cfg and restarted xinetd service. But still i am facing CHECK_NRPE: Socket timeout after 20 seconds
josnavch
Post by josnavch »
Post
1. New NRPE.cfg config
2. Execute command prompt
3. NRPE Log
please!!
Jose Navarrete
abrist
Red Shirt
Post by abrist »
josnavch wrote:1. New NRPE.cfg config
3. NRPE Log
Yeah, lets see everything at once. And please, do not change anything until we have had a chance to comment on the config :)
kakaluru
Post by kakaluru »
[root@BUGZILLABCK ~]# cat /usr/local/nagios/etc/nrpe.cfg
# Sample NRPE Config File
# Written by: Ethan Galstad ([email protected])
# Last Modified: 11-23-2007
# NOTES:
# This is a sample configuration file for the NRPE daemon.  It needs to be
# located on the remote host that is running the NRPE daemon, not the host
# from which the check_nrpe client is being executed.
# LOG FACILITY
# The syslog facility that should be used for logging purposes.
log_facility=daemon
# PID FILE
# The name of the file in which the NRPE daemon should write it's process ID
# number.  The file is only written if the NRPE daemon is started by the root
# user and is running in standalone mode.
pid_file=/var/run/nrpe.pid
# PORT NUMBER
# Port number we should wait for connections on.
# NOTE: This must be a non-priviledged port (i.e. > 1024).
# NOTE: This option is ignored if NRPE is running under either inetd or xinetd
server_port=5666
# SERVER ADDRESS
# Address that nrpe should bind to in case there are more than one interface
# and you do not want nrpe to bind on all interfaces.
#server_address=127.0.0.1
# NRPE USER
# This determines the effective user that the NRPE daemon should run as.
nrpe_user=nagios
# NRPE GROUP
# This determines the effective group that the NRPE daemon should run as.
nrpe_group=nagios
# ALLOWED HOST ADDRESSES
# This is an optional comma-delimited list of IP address or hostnames
# that are allowed to talk to the NRPE daemon. Network addresses with a bit mask
# (i.e. 192.168.1.0/24) are also supported. Hostname wildcards are not currently
# supported.
# Note: The daemon only does rudimentary checking of the client's IP
# address.  I would highly recommend adding entries in your /etc/hosts.allow
# file to allow only the specified host to connect to the port
# you are running this daemon on.
allowed_hosts=127.0.0.1,192.168.30.38
# COMMAND ARGUMENT PROCESSING
# This option determines whether or not the NRPE daemon will allow clients
# to specify arguments to commands that are executed.  This option only works
# if the daemon was configured with the --enable-command-args configure script
# option.
# *** ENABLING THIS OPTION IS A SECURITY RISK! ***
# Read the SECURITY file for information on some of the security implications
# of enabling this variable.
# Values: 0=do not allow arguments, 1=allow command arguments
dont_blame_nrpe=1
# BASH COMMAND SUBTITUTION
# to specify arguments that contain bash command substitutions of the form
# $(...).  This option only works if the daemon was configured with both
# the --enable-command-args and --enable-bash-command-substitution configure
# script options.
# *** ENABLING THIS OPTION IS A HIGH SECURITY RISK! ***
# Values: 0=do not allow bash command substitutions,
#         1=allow bash command substitutions
allow_bash_command_substitution=0
# COMMAND PREFIX
# This option allows you to prefix all commands with a user-defined string.
# A space is automatically added between the specified prefix string and the
# command line from the command definition.
# *** THIS EXAMPLE MAY POSE A POTENTIAL SECURITY RISK, SO USE WITH CAUTION! ***
# Usage scenario:
# Execute restricted commmands using sudo.  For this to work, you need to add
# the nagios user to your /etc/sudoers.  An example entry for alllowing
# execution of the plugins from might be:
# nagios          ALL=(ALL) NOPASSWD: /usr/lib/nagios/plugins/
# This lets the nagios user run all commands in that directory (and only them)
# without asking for a password.  If you do this, make sure you don't give
# random users write access to that directory or its contents!
# command_prefix=/usr/bin/sudo
# DEBUGGING OPTION
# This option determines whether or not debugging messages are logged to the
# syslog facility.
# Values: 0=debugging off, 1=debugging on
debug=0
# COMMAND TIMEOUT
# This specifies the maximum number of seconds that the NRPE daemon will
# allow plugins to finish executing before killing them off.
command_timeout=60
# CONNECTION TIMEOUT
# wait for a connection to be established before exiting. This is sometimes
# seen where a network problem stops the SSL being established even though
# all network sessions are connected. This causes the nrpe daemons to
# accumulate, eating system resources. Do not set this too low.
connection_timeout=300
# WEEK RANDOM SEED OPTION
# This directive allows you to use SSL even if your system does not have
# a /dev/random or /dev/urandom (on purpose or because the necessary patches
# were not applied). The random number generator will be seeded from a file
# which is either a file pointed to by the environment valiable $RANDFILE
# or $HOME/.rnd. If neither exists, the pseudo random number generator will
# be initialized and a warning will be issued.
# Values: 0=only seed from /dev/[u]random, 1=also seed from weak randomness
#allow_weak_random_seed=1
# INCLUDE CONFIG FILE
# This directive allows you to include definitions from an external config file.
#include=<somefile.cfg>
# INCLUDE CONFIG DIRECTORY
# This directive allows you to include definitions from config files (with a
# .cfg extension) in one or more directories (with recursion).
#include_dir=<somedirectory>
#include_dir=<someotherdirectory>
# COMMAND DEFINITIONS
# Command definitions that this daemon will run.  Definitions
# are in the following format:
# command[<command_name>]=<command_line>
# When the daemon receives a request to return the results of <command_name>
# it will execute the command specified by the <command_line> argument.
# Unlike Nagios, the command line cannot contain macros - it must be
# typed exactly as it should be executed.
# Note: Any plugins that are used in the command lines must reside
# on the machine that this daemon is running on!  The examples below
# assume that you have plugins installed in a /usr/local/nagios/libexec
# directory.  Also note that you will have to modify the definitions below
# to match the argument format the plugins expect.  Remember, these are
# examples only!
# The following examples use hardcoded command arguments...
command[check_mem]=/usr/local/nagios/libexec/check_mem.py -w 15 -c 5
command[check_swap]=/usr/local/nagios/libexec/check_swap -w 20 -c 10
command[check_root]=/usr/local/nagios/libexec/check_disk -w 20% -c 10% -p /dev/mapper/vg_bugzillabck-LogVol00
command[check_tmpfs]=/usr/local/nagios/libexec/check_disk -w 20% -c 10% -p /dev/shm
command[check_boot]=/usr/local/nagios/libexec/check_disk -w 20% -c 10% -p /dev/sda1
command[check_usr]=/usr/local/nagios/libexec/check_disk -w 20% -c 10% -p /dev/mapper/vg_bugzillabck-LogVol02
command[check_var]=/usr/local/nagios/libexec/check_disk -w 20% -c 10% -p /dev/mapper/vg_bugzillabck-LogVol03
command[check_total_procs]=/usr/local/nagios/libexec/check_procs -w 650 -c 700
command[check_http]=/usr/local/nagios/libexec/check_http -H 10.174.16.11 -S -u /query.cgi
command[check_url_status]=/usr/local/nagios/libexec/check_url_status -U https://10.174.16.11/query.cgi
command[check_bugdb]=/usr/local/nagios/libexec/check_tcp -H localhost -p 3306 -w 5 -c 10
# The following examples allow user-supplied arguments and can
# only be used if the NRPE daemon was compiled with support for
# command arguments *AND* the dont_blame_nrpe directive in this
# config file is set to '1'.  This poses a potential security risk, so
# make sure you read the SECURITY file before doing this.
[root@BUGZILLABCK ~]# tail -50 /var/log/messages
Nov 13 11:32:59 bugzillabck avahi-daemon[2775]: Invalid query packet.
Nov 13 11:33:00 bugzillabck avahi-daemon[2775]: Invalid query packet.
Nov 13 11:33:03 bugzillabck avahi-daemon[2775]: Invalid query packet.
Nov 13 11:33:04 bugzillabck avahi-daemon[2775]: Invalid query packet.
Nov 13 11:33:07 bugzillabck avahi-daemon[2775]: Invalid query packet.
Nov 13 11:33:11 bugzillabck avahi-daemon[2775]: Invalid query packet.
Nov 13 11:33:12 bugzillabck avahi-daemon[2775]: Invalid query packet.
Nov 13 11:33:15 bugzillabck avahi-daemon[2775]: Invalid query packet.
Nov 13 11:33:24 bugzillabck avahi-daemon[2775]: Invalid query packet.
Nov 13 11:33:51 bugzillabck avahi-daemon[2775]: Invalid query packet.
Nov 13 11:35:55 bugzillabck avahi-daemon[2775]: Invalid query packet.
Nov 13 11:35:56 bugzillabck avahi-daemon[2775]: Invalid query packet.
Nov 13 11:35:57 bugzillabck avahi-daemon[2775]: Invalid query packet.
Nov 13 11:35:59 bugzillabck avahi-daemon[2775]: Invalid query packet.
Nov 13 11:36:00 bugzillabck avahi-daemon[2775]: Invalid query packet.
Nov 13 11:36:01 bugzillabck avahi-daemon[2775]: Invalid query packet.
Nov 13 11:36:02 bugzillabck avahi-daemon[2775]: Invalid query packet.
Nov 13 11:36:06 bugzillabck avahi-daemon[2775]: Invalid query packet.
Nov 13 11:36:09 bugzillabck avahi-daemon[2775]: Invalid query packet.
Nov 13 11:36:36 bugzillabck avahi-daemon[2775]: Invalid query packet.
Nov 13 11:36:39 bugzillabck avahi-daemon[2775]: Invalid query packet.
Nov 13 11:36:40 bugzillabck avahi-daemon[2775]: Invalid query packet.
Nov 13 11:36:41 bugzillabck avahi-daemon[2775]: Invalid query packet.
Nov 13 11:36:42 bugzillabck avahi-daemon[2775]: Invalid query packet.
Nov 13 11:36:43 bugzillabck avahi-daemon[2775]: Invalid query packet.
Nov 13 11:36:45 bugzillabck avahi-daemon[2775]: Invalid query packet.
Nov 13 11:36:52 bugzillabck avahi-daemon[2775]: Invalid query packet.
Nov 13 11:37:19 bugzillabck avahi-daemon[2775]: Invalid query packet.
Nov 13 11:41:22 bugzillabck avahi-daemon[2775]: Invalid query packet.
Nov 13 11:41:23 bugzillabck avahi-daemon[2775]: Invalid query packet.
Nov 13 11:41:24 bugzillabck avahi-daemon[2775]: Invalid query packet.
Nov 13 11:41:25 bugzillabck avahi-daemon[2775]: Invalid query packet.
Nov 13 11:41:26 bugzillabck avahi-daemon[2775]: Invalid query packet.
Nov 13 11:41:28 bugzillabck avahi-daemon[2775]: Invalid query packet.
Nov 13 11:41:35 bugzillabck avahi-daemon[2775]: Invalid query packet.
Nov 13 11:42:02 bugzillabck avahi-daemon[2775]: Invalid query packet.
abrist
Red Shirt
Post by abrist »
I don't know if this is related, but the "invalid query packet" error is usually due to an old version of avahi. Try updating it:
yum update avahi
