SNMP trap config
gormank
Re: SNMP trap config
Post by gormank »
Just one, that may not have an answer...
In ThreeParMIB.mib I see this, which corresponds to 232 for HP.
::= { enterprises 12925 }
But when I snmpwalk, I get nothing.
# snmpwalk -t 300 -v 2c -Cc -m ALL -c sp1der txslm2mfchp001 1.3.6.1.4.1.12925
ThreeParMIB::threepar = No Such Object available on this agent at this OID
# snmpwalk -t 300 -v 2c -Cc -On -c sp1der txslm2mfchp001 1.3.6.1.4.1.12925
.1.3.6.1.4.1.12925 = No Such Object available on this agent at this OID
It knows from the output what MIB it is (attached).
Am I being brain dead again, or?
There's only one entry in snmptt.conf so the MIB is small, but something should show up...
MIB: ThreeParMIB (file:./ThreeParMIB.txt) converted on Thu Oct 8 20:53:36 2015 using snmpttconvertmib v1.3
EVENT alertNotify .1.3.6.1.4.1.12925.1.8 "Status Events" Normal
FORMAT Alert notification contains details about an event that $*
EXEC /usr/local/bin/snmptraphandling.py "$r" "SNMP Traps" "$s" "$@" "$-*" "Alert notification contains details about an event that $*"
SDESC
may affect system operations and performance. The
details include all columns defined in alertTable.
Variables:
1: component
2: details
3: nodeID
4: severity
5: timeOccurred
6: id
7: messageCode
8: state
9: serialNumber
EDESC
SteveBeauchemin
Post by SteveBeauchemin »
On this new host...
If you try to walk and grab the following data - it should tell you the OID that is available to exploit.
snmpwalk -t 3 -v 2c -Cc -On -c [community] [device] SNMPv2-MIB::sysObjectID
It may be that the MIB you think you need is not the MIB.
Also, just FYI...The name of the MIB text file is actually meaningless.
What actually matters is the text at the top of the file.
The line that contains DEFINITIONS ::= BEGIN starts with the actual MIB name.
From looking at one of your earlier posts I see this.
# snmpwalk -v2c -c sp1der txslm2mlapp006.ilo
SNMPv2-MIB::sysDescr.0 = STRING: Integrated Lights-Out 4 2.00 Jul 30 2014
SNMPv2-MIB::sysObjectID.0 = OID: SNMPv2-SMI::enterprises.232.9.4.10
DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (3901337205) 451 days, 13:02:52.05
SNMPv2-MIB::sysContact.0 = STRING:
And on the iLo the 232 was a clue where to go digging. sysObjecID sometimes get you closer to where you need to look.
(actually I think check_*ilo tests from the exchange probably do good stuff and are worth looking at)
Anyway, that Object ID is telling you what the hardware knows about itself.
There will be other data available if you query .1 - but the vendor specific data is sometimes identified for you via that ID.
Also, just because that MIB only exports one Trap definition does not mean it doesn't have a ton of other data inside waiting for you to discover.
Plan to be surprised by stuff in SNMP data.
You do not always get what you think from different pieces of hardware.
And the vendor OID may not always expose the inner working that you want insight on.
Steve B
XI 5.7.3 / Core 4.4.6 / NagVis 1.9.8 / LiveStatus 1.5.0p11 / RRDCached 1.7.0 / Redis 3.2.8 /
SNMPTT / Gearman 0.33-7 / Mod_Gearman 3.0.7 / NLS 2.0.8 / NNA 2.3.1 /
NSClient 0.5.0 / NRPE Solaris 3.2.1 Linux 3.2.1 HPUX 3.2.1
gormank
Post by gormank »
Not sure why you're hung up on the filename. If an snmpwalk on the numeric oid returns the mib name and that matches the mib file, there's no issue.
# grep DEFINITIONS /usr/share/snmp/mibs/ThreeParMIB.txt
ThreeParMIB DEFINITIONS ::= BEGIN
A walk on the oid gives the name of the mib:
Yes, I know the MIB is in the file named ThreeParMIB but the internet also says the OID is enterprises.12925
A walk on OID.n produces the same nothingness as above.
snmpwalk -t 300 -v 2c -Cc -On -c sp1der txslm2mfchp001 1.3.6.1.4.1.12925.1
.1.3.6.1.4.1.12925.1 = No Such Object available on this agent at this OID
SteveBeauchemin
try this...
# snmpwalk -t 300 -v 2c -Cc -m ALL -c sp1der txslm2mfchp001 SNMPv2-MIB::sysObjectID
Let us know if it works for you.
gormank
Post by gormank »
Steve,
Yes that works, but its on the brocade, not the 3par. I can walk the brocade, not the 3par. Still working on the latter.
SNMPv2-MIB::sysObjectID.0 = OID: SW-MIB::sw
SteveBeauchemin
so
gets you nothing
but
gets you SW-MIB::sw
Which I translate into .1.3.6.1.4.1.1588.1
so what does
snmpwalk -t 300 -v 2c -Cc -m ALL -c sp1der txslm2mfchp001 1.3.6.1.4.1.1588
give you.
As for the 3par. Does it have the same host name as the Brocade? Is it an add on module plugged into the brocade?
Steve B
gormank
Post by gormank »
Sorry, the 3par is a storage system 3prf (12925). Above I showed snmpwalk on the wrong host. The fchp are the fiber switches (1588).
Plenty of OIDs for the switch so we're good ther.
# snmpwalk -t 300 -v 2c -Cc -m ALL -c sp1der txslm2mfchp001 1.3.6.1.4.1.1588 | wc -l
15368
Nada for the storage.
# snmpwalk -t 300 -v 2c -Cc -m ALL -c sp1der txslm2m3prf001 1.3.6.1.4.1.12925
ThreeParMIB::threepar = No Such Instance currently exists at this OID
Its interesting (to me) that it converts ....12925 to ThreeParMIB.threepar , 0 to threepar.0, and 1 to inserv.1, but doesn't list OIDs.
# snmpwalk -t 300 -v 2c -Cc -m ALL -c sp1der txslm2m3prf001 1.3.6.1.4.1.12925.0
ThreeParMIB::threepar.0 = No Such Instance currently exists at this OID
# snmpwalk -t 300 -v 2c -Cc -m ALL -c sp1der txslm2m3prf001 1.3.6.1.4.1.12925.1
ThreeParMIB::inserv = No Such Instance currently exists at this OID
In looking at the previous few lines and the MIB, it seems the OIDs are implied on lines beginning with ::=.
So for most MIBs , I could use enterprises.232/1588, etc but enterprises.12925 (seemingly the same as 1.3.6.1.4.1.12925) is no good.
From the below info I would think that enterprises.12925.1.4 would give me whatever inservAgentCaps is. But my logic seems incorrect.
inservAgentCaps OBJECT-IDENTITY
STATUS current
DESCRIPTION "InServ agent profile"
::= { inserv 4 }
# grep ::= /usr/share/snmp/mibs/ThreeParMIB.txt
ThreeparLongDisplayString ::= TEXTUAL-CONVENTION
::= { threepar 1 }
::= { inserv 4 }
::= { inserv 7 }
::= { alertTable 1 }
AlertEntry ::= SEQUENCE {
::= { alertEntry 1 }
::= { alertEntry 2 }
::= { alertEntry 3 }
::= { alertEntry 4 }
::= { alertEntry 5 }
::= { alertEntry 6 }
::= { alertEntry 7 }
::= { alertEntry 8 }
::= { alertEntry 9 }
::= { alertEntry 10 }
::= { inserv 8 }
::= { inservAgentCaps 1 }
SteveBeauchemin
On the storage try a shorter less specifc oid query. whenever I get nothing, I always shorten the oid until it gives me something.
See if you get a list.
Or you can at least prove it is alive by asking for something non vendor specific, like maybe some basic info.
This should prove the credentials are working.
snmpwalk -t 300 -v 2c -Cc -m ALL -c sp1der txslm2m3prf001 .1.3.6.1.2.1.1.1.0
Or better yet, let it tell you the OID it considers to be its identity. Get the numeric output for the sys object id
snmpwalk -t 300 -v 2c -Cc -On -c sp1der txslm2m3prf001 SNMPv2-MIB::sysObjectID
It may not give up the 12925. It may have something else in mind.
But it should at least give something to one of these examples. At least prove it can provide SNMP output in some form.
Whatever it gives you is what I would try to exploit.
BTW - the failed snmp queries where it give you the output - comes from snmpwalk and not your device under test.
Steve B
ssax
Dreams In Code
Post by ssax »
gormank, SteveBeauchemin's is right, that OID might not be available, it's just an the enterprise, try the walk like he said and see if it will give you the information you are looking for.
Let us know how it goes, thank you.
