check_nrpe
nebblkshts
Re: check_nrpe
Post by nebblkshts »
administrator@NETSERVICES:/etc/nagios3$ sudo service nagios start
nagios: unrecognized service
hsmith
Agent Smith
Re: check_nrpe
Post by hsmith »
Maybe it's nagios3 in your case. Regardless, start Nagios however your normally would.
Former Nagios Employee.
me.
nebblkshts
Re: check_nrpe
administrator@NETSERVICES:/etc/init.d$ sudo service nagios3 start
* Starting nagios3 monitoring daemon nagios3 * named pipe exists - removing
[ OK ]
administrator@NETSERVICES:/etc/init.d$ sudo ps -ef | grep nagios
nagios 1726 1 0 Aug01 ? 00:14:10 /usr/sbin/nrpe -c /etc/nagios/nrpe.cfg -d
nagios 21324 1 0 11:02 ? 00:00:00 /usr/sbin/nagios3 -d /etc/nagios3/nagios.cfg
nagios 21514 1 0 11:02 ? 00:00:00 /usr/sbin/nagios3 -d /etc/nagios3/nagios.cfg
nagios 21515 21514 0 11:02 ? 00:00:00 sh -c /usr/lib/nagios/plugins/check_ping -H '10.10.30.61' -w 5000,100% -c 5000,100% -p 1
nagios 21516 21515 0 11:02 ? 00:00:00 /usr/lib/nagios/plugins/check_ping -H 10.10.30.61 -w 5000,100% -c 5000,100% -p 1
nagios 21517 21516 0 11:02 ? 00:00:00 /bin/ping -n -U -w 10 -c 1 10.10.30.61
nagios 21519 1 0 11:02 ? 00:00:00 /usr/sbin/nagios3 -d /etc/nagios3/nagios.cfg
nagios 21520 21519 0 11:02 ? 00:00:00 sh -c /usr/lib/nagios/plugins/check_ping -H '10.10.30.50' -w 5000,100% -c 5000,100% -p 1
nagios 21521 21520 0 11:02 ? 00:00:00 /usr/lib/nagios/plugins/check_ping -H 10.10.30.50 -w 5000,100% -c 5000,100% -p 1
nagios 21522 21521 0 11:02 ? 00:00:00 /bin/ping -n -U -w 10 -c 1 10.10.30.50
nagios 21529 1 0 11:02 ? 00:00:00 /usr/sbin/nagios3 -d /etc/nagios3/nagios.cfg
nagios 21530 21529 0 11:02 ? 00:00:00 sh -c /usr/lib/nagios/plugins/check_snmp_printer -H 10.10.30.55 -C public -x "CONSUMX Maintenance Tank R" -w 5 -c 0
nagios 21531 21530 0 11:02 ? 00:00:00 /bin/bash /usr/lib/nagios/plugins/check_snmp_printer -H 10.10.30.55 -C public -x CONSUMX Maintenance Tank R -w 5 -c 0
nagios 21561 21531 0 11:02 ? 00:00:00 /bin/bash /usr/lib/nagios/plugins/check_snmp_printer -H 10.10.30.55 -C public -x CONSUMX Maintenance Tank R -w 5 -c 0
nagios 21562 21561 0 11:02 ? 00:00:00 snmpwalk -v1 -On -c 10.10.30.55 1.3.6.1.2.1.43.11.1.1.6.1
1000 21605 11137 0 11:02 pts/4 00:00:00 grep --color=auto nagios
hsmith
Agent Smith
Re: check_nrpe
Post by hsmith »
Now that we killed it out of memory, can we do a grep -r -e "command_name.*check_nrpe" /var/cache/nagios3/objects.cache to see if the check_nrpe command is still defined?
me.
nebblkshts
Re: check_nrpe
command_name check_nrpe
command_name check_nrpe_1arg
Re: check_nrpe
Can you please run the following, it should search fairly quick.
grep -R 'check_nrpe' /etc/nagios3/
Let us know the output.
nebblkshts
Re: check_nrpe
administrator@NETSERVICES:/etc/init.d$ sudo grep -R 'check_nrpe' /etc/nagios3/
[sudo] password for administrator:
/etc/nagios3/objects/commands.cfg:#        command_name check_nrpe
/etc/nagios3/objects/commands.cfg:#        command_line ./usr/lib/nagios/plugins/check_nrpe -H $HOSTADDRESS$ -c $ARG1$ -t 20
/etc/nagios3/objects/commands.cfg:        command_line    $USER1$/check_nrpe -H $HOSTADDRESS$ -t 30 -c $ARG1$ $ARG2$
/etc/nagios3/commands.cfg:       command_name                             check_nrpe
/etc/nagios3/commands.cfg:       command_line                             $USER1$/check_nrpe -H $HOSTADDRESS$ -t 30 -c $ARG1$ $ARG2$
/etc/nagios3/servers/CHATCLARITY.cfg:   check_command           check_nrpe!CheckCPU!warn=80 crit=90 time=5m
/etc/nagios3/servers/CHATCLARITY.cfg:   check_command           check_nrpe!CheckMem!MaxWarn=80% MaxCrit=90% ShowAll type=physical
/etc/nagios3/servers/CHATCLARITY.cfg:   check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=c:
/etc/nagios3/servers/CHATCLARITY.cfg:#        check_command           check_nrpe!CheckProcState!spoolsv.exe=Started
/etc/nagios3/servers/LYNC1.cfg: check_command           check_nrpe!CheckCPU!warn=80 crit=90 time=5m
/etc/nagios3/servers/LYNC1.cfg: check_command           check_nrpe!CheckMem!MaxWarn=85% MaxCrit=92% ShowAll type=physical
/etc/nagios3/servers/LYNC1.cfg: check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=c:
/etc/nagios3/servers/LYNC1.cfg:#        check_command           check_nrpe!CheckProcState!spoolsv.exe=Started
/etc/nagios3/servers/RIP3.cfg:  check_command           check_nrpe!CheckCPU!warn=80 crit=90 time=5m
/etc/nagios3/servers/RIP3.cfg:  check_command           check_nrpe!CheckMem!MaxWarn=80% MaxCrit=90% ShowAll type=physical
/etc/nagios3/servers/RIP3.cfg:  check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=c:
/etc/nagios3/servers/RIP3.cfg:#        check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=f:
/etc/nagios3/servers/RIP3.cfg:#        check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=e:
/etc/nagios3/servers/DOCO2.cfg: check_command           check_nrpe!CheckCPU!warn=80 crit=90 time=5m
/etc/nagios3/servers/DOCO2.cfg: check_command           check_nrpe!CheckMem!MaxWarn=80% MaxCrit=90% ShowAll type=physical
/etc/nagios3/servers/DOCO2.cfg: check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=c:
/etc/nagios3/servers/DOCO2.cfg: check_command           check_nrpe!CheckProcState!W3SVC=Started
/etc/nagios3/servers/DOCO2.cfg:        check_command           check_nrpe!CheckProcState!NTDS=Started
/etc/nagios3/servers/PROIMAGE3.cfg:     check_command           check_nrpe!CheckCPU!warn=80 crit=90 time=5m
/etc/nagios3/servers/PROIMAGE3.cfg:     check_command           check_nrpe!CheckMem!MaxWarn=80% MaxCrit=90% ShowAll type=physical
/etc/nagios3/servers/PROIMAGE3.cfg:     check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=c:
/etc/nagios3/servers/PROIMAGE3.cfg:        check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=d:
/etc/nagios3/servers/PROIMAGE3.cfg:        check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=e:
/etc/nagios3/servers/PROIMAGE3.cfg:        check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=f:
/etc/nagios3/servers/PROSTATIC2.cfg:    check_command                   check_nrpe_1arg!check_disk_main
/etc/nagios3/servers/PROSTATIC2.cfg:    check_command                   check_nrpe_1arg!check_load
/etc/nagios3/servers/PROSTATIC2.cfg:    check_command                   check_nrpe_1arg!check_swap
/etc/nagios3/servers/PROSTATIC2.cfg:#        check_command                   check_nrpe_1arg!check_vpn
/etc/nagios3/servers/PROSTATIC2.cfg:#        check_command                   check_nrpe_1arg!check_squid
/etc/nagios3/servers/GDVIRTUAL5.cfg:#   check_command                   check_nrpe!check_disk
/etc/nagios3/servers/GDVIRTUAL5.cfg:#   check_command                   check_nrpe!check_load
/etc/nagios3/servers/GDVIRTUAL5.cfg:#   check_command                   check_nrpe!check_swap
/etc/nagios3/servers/GDVIRTUAL4.cfg:#   check_command                   check_nrpe!check_disk
/etc/nagios3/servers/GDVIRTUAL4.cfg:#   check_command                   check_nrpe!check_load
/etc/nagios3/servers/GDVIRTUAL4.cfg:#   check_command                   check_nrpe!check_swap
/etc/nagios3/servers/RIP2.cfg:  check_command           check_nrpe!CheckCPU!warn=80 crit=90 time=5m
/etc/nagios3/servers/RIP2.cfg:  check_command           check_nrpe!CheckMem!MaxWarn=80% MaxCrit=90% ShowAll type=physical
/etc/nagios3/servers/RIP2.cfg:  check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=c:
/etc/nagios3/servers/RIP2.cfg:#        check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=f:
/etc/nagios3/servers/RIP2.cfg:#        check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=e:
/etc/nagios3/servers/IMAGE1.cfg:        check_command                   check_nrpe_1arg!check_disk1s1
/etc/nagios3/servers/IMAGE1.cfg:#        check_command                   check_nrpe_1arg!check_disk2s3
/etc/nagios3/servers/IMAGE1.cfg:        check_command                   check_nrpe_1arg!check_disk0s3
/etc/nagios3/servers/IMAGE1.cfg:#        check_command                   check_nrpe!check_rip1
/etc/nagios3/servers/IMAGE1.cfg:#        check_command                   check_nrpe!check_rip2
/etc/nagios3/servers/IMAGE1.cfg:        check_command                   check_nrpe_1arg!check_load
/etc/nagios3/servers/IMAGE1.cfg:#       check_command                   check_nrpe!check_swap
/etc/nagios3/servers/IMAGE1.cfg:        check_command                   check_nrpe_1arg!check_graphiklogon
/etc/nagios3/servers/IFSAPPLIVE.off:    check_command                   check_nrpe!check_disk
/etc/nagios3/servers/IFSAPPLIVE.off:    check_command                   check_nrpe!check_load
/etc/nagios3/servers/IFSAPPLIVE.off:        check_command                   check_nrpe!check_zombie_procs
/etc/nagios3/servers/IFSAPPLIVE.off:    check_command                   check_nrpe!check_swap
/etc/nagios3/servers/UV2.cfg:   check_command                   check_nrpe_1arg!check_vg_uv2-lv_root
/etc/nagios3/servers/UV2.cfg:        check_command                   check_nrpe_1arg!check_sdb1
/etc/nagios3/servers/UV2.cfg:#        check_command                   check_nrpe_1arg!check_sda5
/etc/nagios3/servers/UV2.cfg:#        check_command                   check_nrpe_1arg!check_sda7
/etc/nagios3/servers/UV2.cfg:        check_command                   check_nrpe_1arg!check_vg_uv2-lv_home
/etc/nagios3/servers/UV2.cfg:   check_command                   check_nrpe_1arg!check_load
/etc/nagios3/servers/UV2.cfg:   check_command                   check_nrpe_1arg!check_swap
/etc/nagios3/servers/UV2.cfg:        check_command                   check_nrpe_1arg!check_universe
/etc/nagios3/servers/FISE1.cfg: check_command           check_nrpe!CheckCPU!warn=80 crit=90 time=5m
/etc/nagios3/servers/FISE1.cfg: check_command           check_nrpe!CheckMem!MaxWarn=80% MaxCrit=90% ShowAll type=physical
/etc/nagios3/servers/FISE1.cfg: check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=c:
/etc/nagios3/servers/FISE1.cfg:        check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=d:
/etc/nagios3/servers/FISE1.cfg:        check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=e:
/etc/nagios3/servers/FISE1.cfg:#        check_command           check_nrpe!CheckUPS!warn=98 crit=10 time=5m
/etc/nagios3/servers/DOPRCAGE.cfg:      check_command           check_nrpe_1arg!check_load
/etc/nagios3/servers/DOPRCAGE.cfg:      check_command           check_nrpe_1arg!check_swap
/etc/nagios3/servers/DOPRCAGE.cfg:      check_command           check_nrpe_1arg!check_sda1
/etc/nagios3/servers/DOPRCAGE.cfg:        check_command           check_nrpe_1arg!check_sdb
/etc/nagios3/servers/DOPRCAGE.cfg:        check_command           check_nrpe_1arg!check_sdc
/etc/nagios3/servers/DOPRCAGE.cfg:        check_command           check_nrpe_1arg!check_sdd
/etc/nagios3/servers/POSTALSERVICES.cfg:        check_command                   check_nrpe_1arg!check_disk_main
/etc/nagios3/servers/POSTALSERVICES.cfg:        check_command                   check_nrpe_1arg!check_load
/etc/nagios3/servers/POSTALSERVICES.cfg:        check_command                   check_nrpe_1arg!check_swap
/etc/nagios3/servers/POSTALSERVICES.cfg:#        check_command                   check_nrpe_1arg!check_vpn
/etc/nagios3/servers/POSTALSERVICES.cfg:#        check_command                   check_nrpe_1arg!check_squid
/etc/nagios3/servers/CALLCLARITY.cfg:   check_command           check_nrpe!CheckCPU!warn=80 crit=90 time=5m
/etc/nagios3/servers/CALLCLARITY.cfg:   check_command           check_nrpe!CheckMem!MaxWarn=80% MaxCrit=90% ShowAll type=physical
/etc/nagios3/servers/CALLCLARITY.cfg:   check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=c:
/etc/nagios3/servers/CALLCLARITY.cfg:#        check_command           check_nrpe!CheckProcState!spoolsv.exe=Started
/etc/nagios3/servers/RIP5.cfg:  check_command           check_nrpe!CheckCPU!warn=80 crit=90 time=5m
/etc/nagios3/servers/RIP5.cfg:  check_command           check_nrpe!CheckMem!MaxWarn=80% MaxCrit=90% ShowAll type=physical
/etc/nagios3/servers/RIP5.cfg:  check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=c:
/etc/nagios3/servers/RIP5.cfg:#        check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=f:
/etc/nagios3/servers/RIP5.cfg:#        check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=e:
/etc/nagios3/servers/FISE2.cfg: check_command           check_nrpe!CheckCPU!warn=80 crit=90 time=5m
/etc/nagios3/servers/FISE2.cfg: check_command           check_nrpe!CheckMem!MaxWarn=80% MaxCrit=90% ShowAll type=physical
/etc/nagios3/servers/FISE2.cfg: check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=c:
/etc/nagios3/servers/FISE2.cfg:        check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=d:
/etc/nagios3/servers/FISE2.cfg:        check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=e:
/etc/nagios3/servers/FISE2.cfg:        check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=f:
/etc/nagios3/servers/PROIMAGE1.cfg:     check_command           check_nrpe!CheckCPU!warn=80 crit=90 time=5m
/etc/nagios3/servers/PROIMAGE1.cfg:     check_command           check_nrpe!CheckMem!MaxWarn=80% MaxCrit=90% ShowAll type=physical
/etc/nagios3/servers/PROIMAGE1.cfg:     check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=c:
/etc/nagios3/servers/PROIMAGE1.cfg:        check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=d:
/etc/nagios3/servers/PROIMAGE1.cfg:#        check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=e:
/etc/nagios3/servers/PROIMAGE1.cfg:        check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=f:
/etc/nagios3/servers/PRONETSERVICES.cfg:        check_command                   check_nrpe_1arg!check_disk_main
/etc/nagios3/servers/PRONETSERVICES.cfg:        check_command                   check_nrpe_1arg!check_load
/etc/nagios3/servers/PRONETSERVICES.cfg:        check_command                   check_nrpe_1arg!check_swap
/etc/nagios3/servers/PRONETSERVICES.cfg:        check_command                   check_nrpe_1arg!check_vpn
/etc/nagios3/servers/PRONETSERVICES.cfg:#        check_command                   check_nrpe_1arg!check_squid
/etc/nagios3/servers/NSA.cfg:   check_command           check_nrpe!CheckCPU!warn=80 crit=90 time=5m
/etc/nagios3/servers/NSA.cfg:   check_command           check_nrpe!CheckMem!MaxWarn=80% MaxCrit=90% ShowAll type=physical
/etc/nagios3/servers/NSA.cfg:   check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=c:
/etc/nagios3/servers/NSA.cfg:#        check_command           check_nrpe!CheckProcState!spoolsv.exe=Started
/etc/nagios3/servers/PROSTATIC1.cfg:    check_command                   check_nrpe_1arg!check_disk_main
/etc/nagios3/servers/PROSTATIC1.cfg:    check_command                   check_nrpe_1arg!check_load
/etc/nagios3/servers/PROSTATIC1.cfg:    check_command                   check_nrpe_1arg!check_swap
/etc/nagios3/servers/PROSTATIC1.cfg:#        check_command                   check_nrpe_1arg!check_vpn
/etc/nagios3/servers/PROSTATIC1.cfg:#        check_command                   check_nrpe_1arg!check_squid
/etc/nagios3/servers/FEDEX.cfg: check_command           check_nrpe!CheckCPU!warn=80 crit=90 time=5m
/etc/nagios3/servers/FEDEX.cfg: check_command           check_nrpe!CheckMem!MaxWarn=80% MaxCrit=90% ShowAll type=physical
/etc/nagios3/servers/FEDEX.cfg: check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=c:
/etc/nagios3/servers/FEDEX.cfg: check_command           check_nrpe!CheckProcState!ShipManager.exe=Started
/etc/nagios3/servers/RIP4.cfg:  check_command           check_nrpe!CheckCPU!warn=80 crit=90 time=5m
/etc/nagios3/servers/RIP4.cfg:  check_command           check_nrpe!CheckMem!MaxWarn=80% MaxCrit=90% ShowAll type=physical
/etc/nagios3/servers/RIP4.cfg:  check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=c:
/etc/nagios3/servers/RIP4.cfg:#        check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=f:
/etc/nagios3/servers/RIP4.cfg:#        check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=e:
/etc/nagios3/servers/NETSERVICES.cfg:   check_command                   check_nrpe_1arg!check_disk_main
/etc/nagios3/servers/NETSERVICES.cfg:   check_command                   check_nrpe_1arg!check_load
/etc/nagios3/servers/NETSERVICES.cfg:   check_command                   check_nrpe_1arg!check_swap
/etc/nagios3/servers/NETSERVICES.cfg:        check_command                   check_nrpe_1arg!check_vpn
/etc/nagios3/servers/NETSERVICES.cfg:        check_command                   check_nrpe_1arg!check_squid
/etc/nagios3/servers/SQLSERVICES.cfg:   check_command           check_nrpe!CheckCPU!warn=80 crit=90 time=5m
/etc/nagios3/servers/SQLSERVICES.cfg:   check_command           check_nrpe!CheckMem!MaxWarn=80% MaxCrit=90% ShowAll type=physical
/etc/nagios3/servers/SQLSERVICES.cfg:   check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=c:
/etc/nagios3/servers/SQLSERVICES.cfg:#        check_command           check_nrpe!CheckProcState!spoolsv.exe=Started
/etc/nagios3/servers/CMSLIVE.off:       check_command                   check_nrpe!check_disk
/etc/nagios3/servers/CMSLIVE.off:       check_command                   check_nrpe!check_load
/etc/nagios3/servers/CMSLIVE.off:        check_command                   check_nrpe!check_zombie_procs
/etc/nagios3/servers/CMSLIVE.off:       check_command                   check_nrpe!check_swap
/etc/nagios3/servers/LYNC2.cfg: check_command           check_nrpe!CheckCPU!warn=80 crit=90 time=5m
/etc/nagios3/servers/LYNC2.cfg: check_command           check_nrpe!CheckMem!MaxWarn=85% MaxCrit=92% ShowAll type=physical
/etc/nagios3/servers/LYNC2.cfg: check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=c:
/etc/nagios3/servers/LYNC2.cfg:#        check_command           check_nrpe!CheckProcState!spoolsv.exe=Started
/etc/nagios3/servers/GDVIRTUAL1.cfg:#   check_command                   check_nrpe!check_disk
/etc/nagios3/servers/GDVIRTUAL1.cfg:#   check_command                   check_nrpe!check_load
/etc/nagios3/servers/GDVIRTUAL1.cfg:#   check_command                   check_nrpe!check_swap
/etc/nagios3/servers/GDVIRTUAL2.cfg:#   check_command                   check_nrpe!check_disk
/etc/nagios3/servers/GDVIRTUAL2.cfg:#   check_command                   check_nrpe!check_load
/etc/nagios3/servers/GDVIRTUAL2.cfg:#   check_command                   check_nrpe!check_swap
/etc/nagios3/servers/CPSMASTER.cfg:#    check_command           check_nrpe!CheckCPU!warn=80 crit=90 time=5m
/etc/nagios3/servers/CPSMASTER.cfg:#    check_command           check_nrpe!CheckMem!MaxWarn=80% MaxCrit=90% ShowAll type=physical
/etc/nagios3/servers/CPSMASTER.cfg:#    check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=c:
/etc/nagios3/servers/CPSMASTER.cfg:#    check_command           check_nrpe!CheckProcState!ShipManager.exe=Started
/etc/nagios3/servers/PROIMAGE2.cfg:     check_command           check_nrpe_1arg!check_load
/etc/nagios3/servers/PROIMAGE2.cfg:     check_command           check_nrpe_1arg!check_swap
/etc/nagios3/servers/PROIMAGE2.cfg:     check_command           check_nrpe_1arg!check_sda1
/etc/nagios3/servers/PROIMAGE2.cfg:        check_command           check_nrpe_1arg!check_sdb
/etc/nagios3/servers/PROIMAGE2.cfg:        check_command           check_nrpe_1arg!check_md127
/etc/nagios3/servers/WINSERVICES.cfg:   check_command           check_nrpe!CheckCPU!warn=80 crit=90 time=5m
/etc/nagios3/servers/WINSERVICES.cfg:   check_command           check_nrpe!CheckMem!MaxWarn=80% MaxCrit=90% ShowAll type=physical
/etc/nagios3/servers/WINSERVICES.cfg:   check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=c:
/etc/nagios3/servers/WINSERVICES.cfg:        check_command           check_nrpe!CheckProcState!spoolsv.exe=Started
/etc/nagios3/servers/ADP.cfg:   check_command           check_nrpe!CheckCPU!warn=80 crit=90 time=5m
/etc/nagios3/servers/ADP.cfg:   check_command           check_nrpe!CheckMem!MaxWarn=80% MaxCrit=90% ShowAll type=physical
/etc/nagios3/servers/ADP.cfg:#  check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=c:
/etc/nagios3/servers/ADP.cfg:#        check_command           check_nrpe!CheckProcState!spoolsv.exe=Started
/etc/nagios3/servers/UV1.cfg:   check_command                   check_nrpe_1arg!check_sda10
/etc/nagios3/servers/UV1.cfg:        check_command                   check_nrpe_1arg!check_sda3
/etc/nagios3/servers/UV1.cfg:        check_command                   check_nrpe_1arg!check_sda5
/etc/nagios3/servers/UV1.cfg:        check_command                   check_nrpe_1arg!check_sda7
/etc/nagios3/servers/UV1.cfg:        check_command                   check_nrpe_1arg!check_sda6
/etc/nagios3/servers/UV1.cfg:   check_command                   check_nrpe_1arg!check_load
/etc/nagios3/servers/UV1.cfg:   check_command                   check_nrpe_1arg!check_swap
/etc/nagios3/servers/UV1.cfg:        check_command                   check_nrpe_1arg!check_universe
/etc/nagios3/servers/GDVIRTUAL3.cfg:#   check_command                   check_nrpe!check_disk
/etc/nagios3/servers/GDVIRTUAL3.cfg:#   check_command                   check_nrpe!check_load
/etc/nagios3/servers/GDVIRTUAL3.cfg:#   check_command                   check_nrpe!check_swap
/etc/nagios3/servers/RIP1.cfg:  check_command           check_nrpe!CheckCPU!warn=80 crit=90 time=5m
/etc/nagios3/servers/RIP1.cfg:  check_command           check_nrpe!CheckMem!MaxWarn=80% MaxCrit=90% ShowAll type=physical
/etc/nagios3/servers/RIP1.cfg:  check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=c:
/etc/nagios3/servers/RIP1.cfg:        check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=f:
/etc/nagios3/servers/RIP1.cfg:#        check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=e:
/etc/nagios3/servers/GDSUBV.cfg:        check_command                   check_nrpe_1arg!check_root
/etc/nagios3/servers/GDSUBV.cfg:        check_command                   check_nrpe_1arg!check_load
/etc/nagios3/servers/GDSUBV.cfg:        check_command                   check_nrpe_1arg!check_swap
/etc/nagios3/servers/CALLCENTER1.cfg:   check_command           check_nrpe!CheckCPU!warn=80 crit=90 time=5m
/etc/nagios3/servers/CALLCENTER1.cfg:   check_command           check_nrpe!CheckMem!MaxWarn=80% MaxCrit=90% ShowAll type=physical
/etc/nagios3/servers/CALLCENTER1.cfg:   check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=c:
/etc/nagios3/servers/CALLCENTER1.cfg:   check_command           check_nrpe!CheckProcState!CCServer.exe=Started
/etc/nagios3/servers/DOCO1.cfg: check_command           check_nrpe!CheckCPU!warn=80 crit=90 time=5m
/etc/nagios3/servers/DOCO1.cfg: check_command           check_nrpe!CheckMem!MaxWarn=80% MaxCrit=90% ShowAll type=physical
/etc/nagios3/servers/DOCO1.cfg: check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=c:
/etc/nagios3/servers/DOCO1.cfg: check_command           check_nrpe!CheckProcState!W3SVC=Started
/etc/nagios3/servers/DOCO1.cfg:        check_command           check_nrpe!CheckProcState!NTDS=Started
/etc/nagios3/servers/PROIMAGE4.cfg:     check_command           check_nrpe!CheckCPU!warn=80 crit=90 time=5m
/etc/nagios3/servers/PROIMAGE4.cfg:     check_command           check_nrpe!CheckMem!MaxWarn=80% MaxCrit=90% ShowAll type=physical
/etc/nagios3/servers/PROIMAGE4.cfg:#    check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=c:
/etc/nagios3/servers/PROIMAGE4.cfg:        check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=f:
/etc/nagios3/servers/PROIMAGE4.cfg:#        check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=e:
/etc/nagios3/servers/PROIMAGE4.cfg:#        check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=f:
Reason: Please wrap long outputs in [code][/code] tags.
Re: check_nrpe
Can you post the following two files for us to take a look at?
nebblkshts
Re: check_nrpe
Here you go...
commands(Nagios3).cfg
(2.81 KiB) Downloaded 208 times
commands(Objects).cfg
(7.12 KiB) Downloaded 221 times
hsmith
Agent Smith
Re: check_nrpe
Post by hsmith »
In commands (nagios3) can you change
to
  command_line                             $USER1$/check_nrpe -H $HOSTADDRESS$ -t 30 -c '$ARG1$' '$ARG2$'
restart nagios, and see if that fixes it?
me.
