Acknowldgement is not working
absarcompass
Re: Acknowldgement is not working
Hi ssax,
I have PMd you the nagios.debug and ndo2db.debug files.
those were getting rotated within the span of 7 to 10 minutes. please let me know if you require further logs
Did you try rebooting the system? If you haven't, please do.
Try this, please run this tail command (and leave it running):
Then try to submit the acknowledgement again and send me the full output.
tail -F /usr/local/nagiosxi/var/cmdsubsys.log /usr/local/nagios/var/nagios.log-
absarcompass
Hi ssax,
thanks for the reply, i did reboot the machine before. becuase it is not just about acknowledgment of service, now when i reboot server or restart nagios service ipcs -q peaks to max and web gui greyed out all services for hours and then it starts working again.
I have rebooted the machine this morning to get the said logs.
after reboot the web gui showed all the service greyed out and was not showing any acknowledgement option tab.
same was for the hosts check but atleast hosts check had the option of 'Force an immediate check'
below are the required logs when i force immediate check on host
==> /usr/local/nagiosxi/var/cmdsubsys.log <==
PROCESSED 0 COMMANDS
==> /usr/local/nagios/var/nagios.log <==
[1540237625] ndomod registered for external command data'
[1540237625] ndomod registered for aggregated status data'
[1540237625] ndomod registered for retention data'
[1540237625] ndomod registered for contact data'
[1540237625] ndomod registered for contact notification data'
[1540237625] ndomod registered for acknowledgement data'
[1540237625] ndomod registered for state change data'
[1540237625] ndomod registered for contact status data'
[1540237625] ndomod registered for adaptive contact data'
[1540237625] Event broker module '/usr/local/nagios/bin/ndomod.o' initialized successfully.
.............................PROCESSING COMMAND ID 12667...
PROCESS COMMAND: CMD=16, DATA=a:3:{s:9:"host_name";s:30:"WIR_Puketutu-Ubiquiti-McGregor";s:3:"cmd";i:98;s:10:"start_time";i:1540238053;}
COMMAND DATA: a:3:{s:9:"host_name";s:30:"WIR_Puketutu-Ubiquiti-McGregor";s:3:"cmd";i:98;s:10:"start_time";i:1540238053;}
CMDARR:
Array
[host_name] => WIR_Puketutu-Ubiquiti-McGregor
[cmd] => 98
[start_time] => 1540238053
CORE CMD: SCHEDULE_FORCED_HOST_CHECK;WIR_Puketutu-Ubiquiti-McGregor;1540238053
SUBMITTING A NAGIOSCORE COMMAND...
PROCESSED 1 COMMANDS
Broadcast message from [email protected]
(/dev/pts/2) at 8:55 ...
Ok, we're not seeing the issues based on your profile information.
Do this, please run this tail command (and leave it run):
Then apply configuration through the web interface and send the full output of the tail command after it finishes or fails.
Can you try moving the DB back to the XI server to see if that resolves the issue?
tail -F /usr/local/nagiosxi/var/cmdsubsys.logCan you try moving the DB back to the XI server to see if that resolves the issue?
absarcompass
Thanks ssax,
settings applied successfully, took longer time though.
after applying settings ipcsq is peaked to max values. And web gui has greyed out all services and checks
below are the cmdsubsys.log of that timeEvery 2.0s: ipcs -q Tue Oct 23 11:02:52 2018
------ Message Queues --------
key msqid owner perms used-bytes messages
0x1e000002 196608 nagios 600 393123840 383910
Thanks[root@nagiosxi ~]# tail -F /usr/local/nagiosxi/var/cmdsubsys.log
PROCESSED 2 COMMANDS
...............PROCESSING COMMAND ID 12670...
PROCESS COMMAND: CMD=17, DATA=
APPLYING NAGIOSCORE CONFIG...
CMDLINE=cd /usr/local/nagiosxi/scripts && ./reconfigure_nagios.sh
No entry for terminal type "unknown";
using dumb terminal settings.
--- reset_config_perms.sh ------------
> Setting CCM script permissions
> Setting script permissions
> Setting special component script permissions
> Setting configuration file/directory permissions
> Setting perfdata directory and RRD permissions
> Setting NOM checkpoint user:group permissions
> + Setting Nagios Core corelog.newobjects user:group permissions
> + Setting CCM configuration file user:group permissions
> + Setting Recurring Downtime file user:group permissions
> + Setting BPI configuration file user:group permissions
--- ccm_import.php -------------------
> Setting import directory: /usr/local/nagios/etc/import/
> Importing config files into the CCM
No files to import
--- ccm_export.php -------------------
> Writing CCM configuration to Nagios files
Finished writing out configuraton
> Verifying configuration with Nagios Core
> Output:
Nagios Core 4.4.1
Last Modified: 2018-06-25
License: GPL
Reading configuration data...
Read main config file okay...
Checking objects...
Checked 3360 services.
Checked 633 hosts.
Checked 156 host groups.
Checked 45 service groups.
Checked 38 contacts.
Checked 9 contact groups.
Checked 273 commands.
Checked 30 time periods.
Checked 0 host escalations.
Checked 633 hosts
Checked 0 host dependencies
Checked 30 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors: 0
> Return Code: 0
Stopping nagios: ......................done.
Starting nagios: done.
OUTPUT=Starting nagios: done.
RETURNCODE=0
PROCESSING COMMAND ID 12671...
PROCESS COMMAND: CMD=1150, DATA=remove
CMDLINE=php /usr/local/nagiosxi/html/includes/components/nagiosbpi/api_tool.php --cmd=syncall
.....PHP Notice: Undefined index: VHOST - SZOLNLB03 in /usr/local/nagiosxi/html/includes/components/nagiosbpi/classes/BpGroup_class.php on line 0
PHP Notice: Undefined index: VHOST - SZOLNLB03 - Load-balancing cluster in /usr/local/nagiosxi/html/includes/components/nagiosbpi/classes/BpGroup_class.php on line 0
..Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.BPI configuration applied successfully! Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.BPI configuration applied successfully!Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.BPI configuration applied successfully! Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.BPI configuration applied successfully!Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.BPI configuration applied successfully! Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.BPI configuration applied successfully!Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.BPI configuration applied successfully! Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.BPI configuration applied successfully!Member: VHOST - SCCLGRD9024.ivasp.net;CMS - SAP Business One License Manager 2007 removed!
Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.BPI configuration applied successfully! Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.Groups Deleted: 0 <br />Unable to match string in config file.BPI configuration applied successfully!CMD: syncall
MSG: Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.BPI configuration applied successfully! Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.BPI configuration applied successfully!
OUTPUT=MSG: Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.BPI configuration applied successfully! Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.Groups Deleted: 0 Unable to match string in config file.BPI configuration applied successfully!
RETURNCODE=40
Please run this command and send me the resulting /tmp/NAGIOSFILES.zip file:
zip /tmp/NAGIOSFILES.zip /usr/local/nagios/etc/ndo2db.cfg /usr/local/nagios/etc/ndomod.cfg /usr/local/nagiosxi/html/config.inc.php /var/www/html/nagiosql/config/settings.php-
absarcompass
Hi ssax,
Have PMd you the zipped files
absarcompass
In Addition to that now the web gui is not recovering from greyed out status.
I am receiving email and sms alert and but can not see services or host status on web gui
[img][/img]
All services greyed out and not recovering although operation centre tab is showing correct results and notifications are working
I have restarted Apache but no luck
[img][/img]
[img][/img]
[img][/img]
Please try running these commands to see if it resolves the issue:
service nagios stop
rm -rf /usr/local/nagios/var/retention.dat
service nagios start-
absarcompass
Thanks ssax,
deleting retention file has started the webgui, but all my acknowledged and scheduled downtime alarms are now active.
