I would recommend upping that limit so your crons can run
ulimit -u 4096Code: Select all
# ulimit -u
4096
# /usr/local/nagiosxi/cron/feedproc.php
PROCESSED 0 COMMANDS
tail -50 /var/log/cronI checked and I was getting the same messages, so I rebooted the server to try and kick them off again.scottwilkerson wrote:The bigger issue is "are your crons runningCode: Select all
Apr 18 20:18:01 nagiosxivm CROND[2536]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cleaner.php > /usr/local/nagiosxi/var/cleaner.log 2>&1)
Apr 18 20:18:01 nagiosxivm CROND[2538]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php > /usr/local/nagiosxi/var/feedproc.log 2>&1)
Apr 18 20:18:01 nagiosxivm CROND[2537]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php > /usr/local/nagiosxi/var/eventman.log 2>&1)
Apr 18 20:18:01 nagiosxivm CROND[2539]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/reportengine.php > /usr/local/nagiosxi/var/reportengine.log 2>&1)
Apr 18 20:18:01 nagiosxivm CROND[2541]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php > /usr/local/nagiosxi/var/cmdsubsys.log 2>&1)
Apr 18 20:18:01 nagiosxivm CROND[2540]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php > /usr/local/nagiosxi/var/perfdataproc.log 2>&1)
Apr 18 20:18:01 nagiosxivm CROND[2542]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/nom.php > /usr/local/nagiosxi/var/nom.log 2>&1)
Apr 18 20:18:01 nagiosxivm CROND[2543]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php > /usr/local/nagiosxi/var/sysstat.log 2>&1)
Apr 18 20:19:01 nagiosxivm CROND[4420]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cleaner.php > /usr/local/nagiosxi/var/cleaner.log 2>&1)
Apr 18 20:19:01 nagiosxivm CROND[4421]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/reportengine.php > /usr/local/nagiosxi/var/reportengine.log 2>&1)
Apr 18 20:19:01 nagiosxivm CROND[4422]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/nom.php > /usr/local/nagiosxi/var/nom.log 2>&1)
Apr 18 20:19:01 nagiosxivm CROND[4423]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php > /usr/local/nagiosxi/var/perfdataproc.log 2>&1)
Apr 18 20:19:01 nagiosxivm CROND[4424]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php > /usr/local/nagiosxi/var/feedproc.log 2>&1)
Apr 18 20:19:01 nagiosxivm CROND[4425]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php > /usr/local/nagiosxi/var/cmdsubsys.log 2>&1)
Apr 18 20:19:01 nagiosxivm CROND[4426]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php > /usr/local/nagiosxi/var/eventman.log 2>&1)
Apr 18 20:19:01 nagiosxivm CROND[4427]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php > /usr/local/nagiosxi/var/sysstat.log 2>&1)
Apr 18 20:20:01 nagiosxivm CROND[7515]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/dbmaint.php > /usr/local/nagiosxi/var/dbmaint.log 2>&1)
Apr 18 20:20:01 nagiosxivm CROND[7519]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/reportengine.php > /usr/local/nagiosxi/var/reportengine.log 2>&1)
Apr 18 20:20:01 nagiosxivm CROND[7516]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/deadpool.php > /usr/local/nagiosxi/var/deadpool.log 2>&1)
Apr 18 20:20:01 nagiosxivm CROND[7520]: (root) CMD (/usr/lib/sa/sa1 -S DISK 1 1)
Apr 18 20:20:01 nagiosxivm CROND[7514]: (root) CMD (LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg --lock-file /var/lock/mrtg/mrtg_l --confcache-file /var/lib/mrtg/mrtg.ok &> /dev/null)
Apr 18 20:20:01 nagiosxivm CROND[7522]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php > /usr/local/nagiosxi/var/sysstat.log 2>&1)
Apr 18 20:20:01 nagiosxivm CROND[7517]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cleaner.php > /usr/local/nagiosxi/var/cleaner.log 2>&1)
Apr 18 20:20:01 nagiosxivm CROND[7518]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php > /usr/local/nagiosxi/var/perfdataproc.log 2>&1)
Apr 18 20:20:01 nagiosxivm CROND[7521]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php > /usr/local/nagiosxi/var/feedproc.log 2>&1)
Apr 18 20:20:01 nagiosxivm CROND[7523]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/nom.php > /usr/local/nagiosxi/var/nom.log 2>&1)
Apr 18 20:20:01 nagiosxivm CROND[7525]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php > /usr/local/nagiosxi/var/eventman.log 2>&1)
Apr 18 20:20:01 nagiosxivm CROND[7524]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php > /usr/local/nagiosxi/var/cmdsubsys.log 2>&1)Code: Select all
/usr/local/nrdp/clients/nrds/nrds.pl -H testlane2Code: Select all
# /usr/local/nrdp/clients/nrds/nrds.pl -H testlane2
ERROR: STDIN must be either 3 or 4 fields long, I found 2
Sent 5 checks to http://xxx.xxx.xxx.xxx/nrdp/
