2014R1.0RC1 Initial reaction and question(s)
Re: 2014R1.0RC1 Initial reaction and question(s)
I'll check it out. If it is still not working, it's a bit disappointing as we are waiting for this so long.
Give it a try and let us know if it's working for you. Thanks!
Okay, I tested it again. I'll open a new thread and repeat what I wrote some days / weeks ago. Maybe it is taken serious thenlmiltchev wrote:Give it a try and let us know if it's working for you. Thanks!
This should be the sense of a beta phase, yessreinhardt wrote:OK, I see what you are saying with the commands that are defined. Going to check some things and will be back with more info or a fix from us.
