scottwilkerson wrote:
Also, is it ALL of the links under reports, or just some?
Reports
Availability ----- Gateway Timeout .The gateway did not receive a timely response from the upstream server or application.
Trends ----- no image shows up just this line : ios/images/trends.gif' BORDER=0 ALT='Host State Trends' TITLE='Host State Trends'>
Alerts ----- Internal Server Error
History ----- Internal Server Error
Summary ----- still processing for past 20 min
Histogram ----- no graph or image showing up.
Notifications ----- Internal Server Error
Event Log ----- Internal Server Error
all of these error shows up after very long processing time
sinkak wrote:I installed new version of nagios on new server but copied old nagios config files and scripts and made changes to the conf files accordingly.
changed timeout to 600 still same error.
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator at webmaster@localhost to inform them of the time this error occurred, and the actions you performed just before this error.
More information about this error may be available in the server error log.
Apache/2.4.7 (Ubuntu) Server at xx.xx.xx.xx Port 80
ubuntu@nagios-2015:/var/log/apache2$ tail -n1000 /var/log/apache2/error.log.1
PHP Deprecated: Comments starting with '#' are deprecated in /etc/php5/apache2/php.ini on line 833 in Unknown on line 0
PHP Deprecated: Comments starting with '#' are deprecated in /etc/php5/apache2/php.ini on line 834 in Unknown on line 0
[Mon Nov 09 06:38:29.668261 2015] [mpm_prefork:notice] [pid 14320] AH00163: Apache/2.4.7 (Ubuntu) PHP/5.5.9-1ubuntu4.11 configured -- resuming normal operations
[Mon Nov 09 06:38:29.668271 2015] [core:notice] [pid 14320] AH00094: Command line: '/usr/sbin/apache2'
[Mon Nov 09 19:07:40.768181 2015] [cgi:error] [pid 16186] [client 50.246.35.62:58546] End of script output before headers: history.cgi, referer: http://52.6.142.190/nagios/side.php
[Tue Nov 10 01:38:23.871138 2015] [:error] [pid 16186] [client 91.196.50.33:52722] script '/var/www/html/testproxy.php' not found or unable to stat
[Fri Nov 13 13:53:06.922613 2015] [:error] [pid 16187] [client 91.196.50.33:40437] script '/var/www/html/testproxy.php' not found or unable to stat
[Sun Nov 15 06:30:28.292267 2015] [mpm_prefork:notice] [pid 14320] AH00171: Graceful restart requested, doing restart
AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.0.1. Set the 'ServerName' directive globally to suppress this message
