Error: nagiosxi-deps-el7 conflicts with nrpe-3.2.0-6.el7.x86
Re: Error: nagiosxi-deps-el7 conflicts with nrpe-3.2.0-6.el7
rtsupport wrote:we cannot do up gradation directly on PRD,
I understand that.
rtsupport wrote:Restore PRD backup to Test/Dev environment (same Nagios XI version)--> then upgrade Test environment to latest Nagios XI.. -- > Take Backup --> now restore that backup to new OS with same latest version. ??
Correct me if i am missing something as this we can do..
That sounds great!
Then you can also take a moment and let the Test/Dev run for a minute making sure everything appears normal before taking the backup that will be used to restore on the new OS
this will take a LOT of variables out of the mix
rtsupport
Post by rtsupport »
Hi Scott,
as per last discussion i am trying to upgrade test server but that is also falling have attached upgrade log for your reference
Referring doc for up gradation-
https://assets.nagios.com/downloads/nag ... ctions.pdf
Linux version -
Red Hat Enterprise Linux Server release 7.4 (Maipo)
Current Nagios XI Version -
Nagios XI 2014R2.7
Is part of this log missing? I don't see any errors. Is it erroring on the screen?
rtsupport
Post by rtsupport »
no error on the screen as well, its just finishing like attached image. Not getting "Nagios XI Upgrade Complete!" message aslo
I have no idea why this is erroring here but, here is what I would like you to do
edit /tmp/nagiosxi/subcomponents/ndoutils/post-upgrade
Comment out this line
sysctl -e -p /etc/sysctl.conf
making it read
#sysctl -e -p /etc/sysctl.conf
the run the ./upgrade again
rtsupport
Post by rtsupport »
it move forward but failed now at below error.. have attached upgrade log again.
Installing new PNP templates...
Updating init script...
Enabling large install tweaks...
Fixing config file permissions...
Fixing htpasswd permissions...
Checking group memberships...
Installing new XI templates...
URL: https://localhost/nagiosxi/includes/components/ccm/
CMDLINE
/usr/bin/wget --save-cookies nagiosql.cookies --keep-session-cookies https://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'submit=Login&hidelog=true&loginSubmitted=true&backend=1&username=nagiosxi&password=n@gweb' -O nagiosql.login--2018-06-27 16:56:33--  https://localhost/nagiosxi/includes/components/ccm/
Resolving www.mc.xerox.com... 13.131.1.242
Connecting to www.mc.xerox.com|13.131.1.242|:8000... connected.
Proxy tunneling failed: Service UnavailableUnable to establish SSL connection.
NAGIOSQL LOGIN FAILED!
This system needs to have localhost added to the no_proxy in /etc/wgetrc
see
https://support.nagios.com/kb/article.php?id=147
How was this functioning?
after you add that, you can run upgrade again..
The good news is the upgrade script is close to done
rtsupport
Post by rtsupport »
great!! all set now on up-gradation... part Test server is upgraded to latest one Nagios XI.
Total Warnings: 716
Total Errors:   0
RET: 0
Running configuration check...
Stopping nagios:. done.
Starting nagios: done.
Fixing php-mcrypt bug...
Stopping httpd:                                            [  OK  ]
Starting httpd:                                            [  OK  ]
Now next step for me..
1- Will install latest version of Nagios XI on new RHEL 7 server
.. For installation server is ready with RHEL subscription manager
.. RHEL optional Repo enabled
.. Proxy is configured as per - https://support.nagios.com/kb/article.php?id=147
2- Take backup from updated Test server and scp to new RHEL 7 Server
3- Restore it using ./restore script
Please add if i missed. something.
rtsupport wrote:great!! all set now on up-gradation... part Test server is upgraded to latest one Nagios XI.
Before step 2 You will need to install nagios xi latest on the server
https://assets.nagios.com/downloads/nag ... -Linux.pdf
The rest looks correct!
rtsupport
Post by rtsupport »
one more thing would also like to clear.
As we have configured nagiosramdisk so -- we have to follow.
1.
-Install latest version of Nagios XI.
-Create nagiosramdisk
-Restore backup
-run /upgrade script
OR
2.
-Restore backup
Note : In Test server nagiosramdisk is created and configured as /u01/var/nagiosramdisk but as per ramdisk doc it will create and configured /var/nagiosramdisk
so is there anything which need to be taken care ? before proceeding
# nagiosramdisk doc
https://assets.nagios.com/downloads/nag ... giosXI.pdf
