On-Line
But the onstat command is not returning On-Line so the plugin returning an unknown state.
Can you login to the duey server and run the following commands and post the full output?
export INFORMIXDIR=/usr/informix
export INFORMIXSERVER=dueynet
export ONCONFIG=onconfig
/usr/informix/bin/onstat -
echo $?Is the old script still on the server and if so, can you use that script again?
This is the old script, if it exists, can you upload it?
/usr/local/nagios/libexec/check_ifx.sh
