Help with NRDS?
Re: Help with NRDS?
Let us know if they show up
jbennett
Re: Help with NRDS?
Post by jbennett »
*sigh*
Still nothing. I've even gone so far as to reboot the system in the off chance it would help (not sure why though).
I ran the same check on the remote system and received the same response:
# /usr/local/nrdp/clients/nrds/nrds.pl -H testlane2
ERROR: STDIN must be either 3 or 4 fields long, I found 2
Sent 5 checks to http://xxx.xxx.xxx.xxx/nrdp/
Going to unconfigured objects on that nagios server, I don't see anything listed.
Re: Help with NRDS?
Can you go to http://xxx.xxx.xxx.xxx/nrdp/ in a web browser and sobmit the test command (entering your token) to see if it show up in unconfigured objects
jbennett
Re: Help with NRDS?
Post by jbennett »
scottwilkerson wrote:Can you go to http://xxx.xxx.xxx.xxx/nrdp/ in a web browser and sobmit the test command (entering your token) to see if it show up in unconfigured objects
When I do this, I get the following results:
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<result>
<status>0</status>
<message>OK</message>
</result>
<result>
<status>0</status>
<meta>
<output>2 checks processed.</output>
</meta>
</result>
I have nothing showing up under unconfigured objects after this. I'm assuming it should be relatively instant? What should it show as? 'somehost'?
Re: Help with NRDS?
Try restarting xinetd on the Nagios XI server:
service xinetd restart
wait for a while, then check the unconfigured objects again.
jbennett
Re: Help with NRDS?
Post by jbennett »
Nothing. I've waited a while too... :lol:
Re: Help with NRDS?
We will likely have to schedule a remote session to try to debug what is actually happening to cause the unconfigured objects to not show up.
Can you create a support ticket by emailing [email protected] referencing this thread and we will setup a time to take a look.
jbennett
Re: Help with NRDS?
Post by jbennett »
I've started messing with this on a new box and I found something interesting.
I have successfully gotten the controller to show up in unconfigured objects by using the IP of the Nagios box instead of the name.
I suppose this would indicate a lookup issue from the client to the host, correct?
sreinhardt
-fno-stack-protector
Re: Help with NRDS?
Post by sreinhardt »
Yes this would likely be the case!
jbennett
Re: Help with NRDS?
Post by jbennett »
I'm noticing that my remote clients are not getting the updated version of the configs that they should be.
There should be a cron that runs on the remote client that would do this, correct? Where would that cron be configured normally? cron.d?
Also, where is the new config file pushed to on the client? is nrds.cfg just overwritten each time? I'm not seeing that if it is the case.
