Problem with monitoring Windows 2012 R2 servers
Re: Problem with monitoring Windows 2012 R2 servers
Could you post how the command is setup in NagiosXI command.cfg file and the service file?
Frédéric GRANAT
Post by Frédéric GRANAT »
command_name check_win_cpu
command_line $USER1$/check_wmi_plus.pl -H $HOSTADDRESS$ -u $ARG1$ -p $ARG2$ -m checkcpu -w $ARG3$ -c $ARG4$ $ARG5$
Shouldn't the command be using the new check_wmi_plus_latest.pl perl script instead of the old check_wmi_plus.pl perl script?
Can you provide the service check that is using the check_win_cpu so we can see how the arguments are setup?
Frédéric GRANAT
=> Running check_wmi_plus_latest.pl in command line doesn't work, so what's the point of testing a command using check_wmi_plus_latest.pl ?
=> Here's the command view in the service template :
$ARG1$=login
$ARG2$=password
$ARG3$=80
$ARG4$=90
Everything looks good so far. Last thing to try is can you delete the service from XI, delete the state files from the /tmp folder recreate the service and see if it works.
Frédéric GRANAT
I created the following objects :
command_name check_win_cpu_latest
command_line $USER1$/check_wmi_plus_latest.pl -H $HOSTADDRESS$ -u $ARG1$ -p $ARG2$ -m checkcpu -w $ARG3$ -c $ARG4$ $ARG5$
name windows-cpu-latest
use windows
check_command check_win_cpu_latest!svc_riverbed!dsisvc!80!90!!!!
register 0
host_name W2K-APPLI16.cg.ahp
service_description CPU Usage
use windows-cpu-latest
register 1
It fails :
UNKNOWN - The WMI query had problems. You might have your username/password wrong or the user's access level is too low. Wmic error text on the next line.
cmerchant
Post by cmerchant »
Was there an additional line to this error message?
Frédéric GRANAT
Same message than the once given a few posts ago :
[librpc/rpc/dcerpc_util.c:1290:dcerpc_pipe_auth_recv()] Failed to bind to uuid 4d9f4ab8-7d1c-11cf-861e-0020af6e7c57 - NT_STATUS_NET_WRITE_FAULT
[librpc/rpc/dcerpc_connect.c:790:dcerpc_pipe_connect_b_recv()] failed NT status (c0000022) in dcerpc_pipe_connect_b_recv
[wmi/wmic.c:196:main()] ERROR: Login to remote object.
NTSTATUS: NT_STATUS_ACCESS_DENIED - Access denied
Usually you get this error when your user has a limited permission access to WMI datasources, i.e. local users group has been removed from "acces this computer from the network" in User Rights Assignment of the Local Group Policy. You could try re-adding that permission to the account in order to fix the issue.
Frédéric GRANAT
Please explain me how to re-add that permission to the account
Frederic
