check_nrpe
nebblkshts
Re: check_nrpe
Post by nebblkshts »
hsmith wrote:So if you run ./check_nrpe -H LYNCFE2 -c CheckMem -a MaxWarn=80% MaxCrit=90% ShowAll type=physical it works, you stated earlier. Yes
This is your service definition:
use infra-trivial-service
host_name LYNCFE2
service_description Memory Usage
check_command check_nrpe!CheckMem!-a MaxWarn=80% MaxCrit=90% ShowAll type=physical
This looks good. Yes This is the definition
This is your check_nrpe command:
command_line                             $USER1$/check_nrpe -H $HOSTADDRESS$ -t 30 -c '$ARG1$' '$ARG2$'
I can't see a reason this wouldn't be working right now. Everything should be getting passed correctly. Can you please upload a screenshot of the error you are getting in the GUI?
Yes, but I have it commented out because of the following information I just noticed
Warning: Duplicate definition found for command 'check_nrpe' (config file '/etc/nagios3/objects/commands.cfg', starting on line 65)
Error: Could not add object property in file '/etc/nagios3/objects/commands.cfg' on line 66.
* errors in config!
and
#NRPE Definition
#define command{
#        command_name check_nrpe
#        /usr/lib/nagios/plugins/check_nrpe -H $HOSTADDRESS$ -t 30 -c '$ARG1$' '$ARG2$'
# 'check_ups' command definition
        command_name    check_ups
        command_line    $USER1$/check_nrpe -H $HOSTADDRESS$ -t 30 -c $ARG1$ $ARG2$
and here is the gui screenshot
hsmith
Agent Smith
Re: check_nrpe
Post by hsmith »
You have two commands.cfg files. One of them has the check_nrpe commented out and the other does not. If you changed them both to have it commented out, then it will absolutely fail.
Former Nagios Employee.
me.
nebblkshts
Re: check_nrpe
I only one of them commented out (/etc/nagios3/objects/commands.cfg) the other one(/etc/nagios3/commands.cfg) did not seem to do anything. and if I reverse these two I get the same error.
* errors in config!
Which I thought that meant the system must be trying to use this config file (/etc/nagios3/objects/commands.cfg) which has the code commented out.
hsmith
Agent Smith
Re: check_nrpe
Post by hsmith »
What's the output of ls /etc/nagios3/conf.d ?
me.
nebblkshts
Re: check_nrpe
administrator@NETSERVICES:/usr/lib/nagios/plugins$ ls /etc/nagios3/conf.d
contacts_nagios2.off generic-host_nagios2.off hostgroups_nagios2.off services_nagios2.off
extinfo_nagios2.off generic-service_nagios2.off localhost_nagios2.off timeperiods_nagios2.off
Re: check_nrpe
Can you post the 'nagios.cfg', '/etc/nagios3/objects/commands.cfg', and '/etc/nagios3/commands.cfg' file?
nebblkshts
Re: check_nrpe
Here you go.
commands(Objects).cfg
(7.12 KiB) Downloaded 291 times
commands(Nagios3).cfg
(2.81 KiB) Downloaded 303 times
nagios.cfg
(44.13 KiB) Downloaded 302 times
hsmith
Agent Smith
Re: check_nrpe
Post by hsmith »
Can you do the following?
cd /etc/conf.d/nagios3
mv * ~
pkill -9 nagios
service nagios3 start
grep -r -e "command_name.*check_nrpe" /var/cache/nagios3/objects.cache
Let me know what happens. Thanks!
me.
nebblkshts
Re: check_nrpe
I get the same issue. GUI has the error but everything moved and started just fine. the grep had this result:
command_name check_nrpe_1arg
hsmith
Agent Smith
Re: check_nrpe
Post by hsmith »
What is in the /etc/nagios-plugins/config directory?
me.
