Sporadic 'Connection refused' errors in 4.2.4
Re: Sporadic 'Connection refused' errors in 4.2.4
I saw the missing info in the post so I figured that could be the issue.
When you say "Same old connection refused errors again on the checks I re-enabled." are you having that error all of the time or is it intermittent still?
If it is intermittent, you may try increasing the timeout to a higher value that what you have and see if that helps. Of if you have access to the host, check it's log to see if there are any clues there.
If it is happening all of the time, run the check in the command line with the -v (Verbose) and post the output here.
kernow5000
Just sometimes, and re-enabling those checks seems to kick others off that were fine.
I've tried upping timeouts and it doesn't really seem to do anything, 99% fine, then the old connection refused stuff.
Running command line checks all day - work 100% but I will add -v to check this time.
kernow5000
Well, this is a new one:
CRITICAL - Plugin timed out while executing system call
kernow5000
I've always thought this was a problem with forking off processes to do the service checks, since the start.
I am trying to see if I can replicate the Sporadic Connection Refused to the servers you are testing. One of the servers I cannot connect at all and the other seems to be redirecting the page but so far it is working.
One thing to check, see if the ISP that are hosting those sites are throttling connections, etc. and see if that is happening.
kernow5000
Hi, I've check with my hosting providers and none of them have any connection throttling in place.
Thanks.
Thanks.
- Former Nagios Staff
@kernow5000 I got your PM about needing to get approval to send more logs. Assuming you get approval, once you send the logs, please update this thread.
kernow5000
Excellent. No hurry on our end!
UPDATE: debug shared received and shared with techs
kernow5000
(Section) of nagios.debug sent.
