Check Windows Processes
ofadl
Re: Check Windows Processes
Post by ofadl »
yes, but it doesnt list all of the processes, it just checks to see if they are working. The check is called " Check processes are running". The command check on the windows server is called :
command[check_procs_from_file]=cscript.exe //NoLogo //T:60 c:\nrpe_nt\check_process_instances_from_file.wsf $ARG1$
this file is located in the nrpe.cfg file which is located in the nrpe_nt folder, which is on the windows server
the service definition on the nagios host machine, looks like so :
use comtex-service-template-vna ; Name of service template to use
host_name vnainp109
service_description Check processes are running
check_command check_nrpe!check_procs_from_file!c:\\nrpe_nt\\host.proclist.txt
This method was used on windows servers
i also found these commands definitions, but i am not sure if they are relative or help the service definition above run:
# 'check_winproc' command definition
command_name check_winproc
command_line $USER1$/is_process_running $HOSTADDRESS$ $ARG1$
# 'check_winproclist' command definition
command_name check_winproclist
command_line $USER1$/are_processes_running $HOSTADDRESS$ $USER3$/$ARG1$
# 'check_multiwinproc' command definition
command_name check_multiwinproc
command_line $USER1$/are_multi_processes_running $HOSTADDRESS$ $USER3$/$ARG1$
Post by slansing »
So you are using NRPE_NT instead of NSclient? These are the details we need to know. If you are not doing this then it is suggested you completely remove NRPE_NT as trying to run them side by side is going to cause issues since both with use port 5666 for traffic. If you are trying to use that command definition you can try to copy it from that .cfg to the nsc.ini file of nsclient, change this portion of the copied command definition to match the new location of that script once you move it to the "nsclient++/scripts/" directory:
then restart the nsclient service and try to call the command from the nagios server as was demonstrated earlier.
ofadl
Post by ofadl »
no, the old nagios is using the nrpe_nt. The new nagios, which im trying to work on now, will use NSClient. Is there a way i can suspend the nrpe_nt without removing it?
Post by slansing »
You can stop its service in windows services.msc. That will suspend it from sending or receiving data. Except that the other nagios server will try to connect to the same port that nrpe_nt uses so you could run into some issues unless you disable it's checks.
ofadl
Post by ofadl »
yes that is what i have done, i have disabled the service check on the windows server to stop the nrpe_nt from working. I am trying to run this now:
./check_nrpe -H 10.100.50.15 -p 5666 -c check_procs_from_file -a c:\\nrpe_nt\\host.proclist.txt
and am getting this error from prompt
Could not construct return packet in NRPE handler check client side (nsclient.log) logs...
and i go into the windows server, and check the nsclient.log file and get this:
2013-07-11 11:15:53: error:modules\NRPEListener\NRPEListener.cpp:422: Request contained arguments (not currently allowed, check the allow_arguments option).
2013-07-11 11:15:53: error:modules\NRPEListener\NRPEListener.cpp:320: Exception handling NRPE packet
but i dont understand, because i enabled allow_arguments to true, for both the nrpe section and nsclient section. Even when i try to make one or the other work individually, still get the same error no matter what
yancy
Post by yancy »
Uncomment and change the following lines the following lines in NSC.ini under the [NRPE] section
;# COMMAND ARGUMENT PROCESSING
;  This option determines whether or not the NRPE daemon will allow clients to specify arguments to commands that are executed.
allow_arguments=1
;# COMMAND ALLOW NASTY META CHARS
;  This option determines whether or not the NRPE daemon will allow clients to specify nasty (as in |`&><'"\[]{}) characters in arguments.
allow_nasty_meta_chars=1
restart the service and that should do the trick.
-Yancy
ofadl
Post by ofadl »
ok did as you said, ran this:
and got this:
UNKNOWN: No handler for that command
inside the nsc.ini file beholds this:
2013-07-11 12:01:50: message:NSClient++.cpp:1195: No handler for command: 'check_procs_from_file'
2013-07-11 12:01:50: message:include\NSCHelper.cpp:238: No handler for command 'check_procs_from_file'.\
Ok, so i did a little investigating and came across this in the nsc.ini file:
; Script to check external scripts and/or internal aliases.
CheckExternalScripts.dll
and did an uncomment for CheckExternalScripts.dll, and ran
and got :
ExternalCommands: failed to create process (scripts\cscript.exe //NoLogo //T:60 scripts\check_process_instances_from_file.wsf $ARG1$): 2: The system cannot find the file specified.
I dont know if that helps, or i should comment it back out?
yancy
Post by yancy »
Where is the file check_process_instances_from_file.wsf located? It should be in the Nsclient++ scripts directory.
ofadl
Post by ofadl »
I have this defined in the "External Scripts" section, like i was told to do earlier in this threat.
check_procs_from_file=scripts\cscript.exe //NoLogo //T:60 scripts\check_process_instances_from_file.wsf $ARG1$
yancy
Post by yancy »
Yes, but where is the file check_process_instances_from_file.wsf located on the windows machine? what is it's path location?
