check_nrpe
nebblkshts
Re: check_nrpe
Post by nebblkshts »
apt.cfg disk.cfg flexlm.cfg hppjd.cfg load.cfg mysql.cfg ntp.cfg radius.cfg ssh.cfg
breeze.cfg disk-smb.cfg fping.cfg http.cfg mail.cfg netware.cfg pgsql.cfg real.cfg tcp_udp.cfg
check_nrpe.cfg dns.cfg ftp.cfg ifstatus.cfg mailq.cfg news.cfg ping.cfg rpc-nfs.cfg telnet.cfg
dhcp.cfg dummy.cfg games.cfg ldap.cfg mrtg.cfg nt.cfg procs.cfg snmp.cfg users.cfg
Re: check_nrpe
Can you please post the contents of /etc/nagios-plugins/config/check_nrpe.cfg?
nebblkshts
Re: check_nrpe
# this command runs a program $ARG1$ with arguments $ARG2$
        command_name    check_nrpe
        command_line    /usr/lib/nagios/plugins/check_nrpe -H $HOSTADDRESS$ -c $ARG1$ -a $ARG2$
# this command runs a program $ARG1$ with no arguments
        command_name    check_nrpe_1arg
Re: check_nrpe
Looks like we found the the long lost file! Can you remove the -a from the command below?
So it should look like -
       command_line    /usr/lib/nagios/plugins/check_nrpe -H $HOSTADDRESS$ -c $ARG1$ $ARG2$
Restart Nagios, and let us know the result!
nebblkshts
Re: check_nrpe
I made the change and then all the sudden I was getting flooded with emails so I put it back. The emails were delayed by about 5 minutes but the error did not appear to go away unless I did not wait long enough. Why did it kick all those emails?
Re: check_nrpe
The reason you received a lot of emails is because it probably broke a few checks when you made this change. The way we would normally run a check_nrpe is with the -a defined seperately.
Can you post the service definition in question that isn't working for us to look at? We should be able to adjust this as needed, knowing now that the -a flag is already defined.
nebblkshts
Re: check_nrpe
This is one of the services that started screaming...
        use                     infra-trivial-service
        host_name               FISE2
        service_description     Backup Drive Space
        check_command           check_nrpe!CheckDriveSize!ShowAll MinWarnFree=10% MinCritFree=5% Drive=f:
This is the email notice:
Notification Type: PROBLEM
Service: Backup Drive Space
Host: FISE2
State: CRITICAL
Date/Time: Mon Dec 21 16:25:42 EST 2015
Additional Info:
Missing argument(s).
Re: check_nrpe
Yeah, it's because of the -a flag being included in the command already and we had taken it out.
Can you post the service definition of the one that's still not working?
nebblkshts
Re: check_nrpe
This works I just have this error I am trying to correct
        host_name               LYNCFE2
        service_description     Memory Usage
        check_command           check_nrpe!CheckMem!MaxWarn=85% MaxCrit=92% ShowAll type=physical
hsmith
Agent Smith
Re: check_nrpe
Post by hsmith »
Let's change it to this:
        host_name               LYNCFE2
        check_command           check_nrpe!CheckMem!'MaxWarn=85% MaxCrit=92% ShowAll type=physical'
Reload the Nagios service.
Former Nagios Employee.
me.
