Error: nagiosxi-deps-el7 conflicts with nrpe-3.2.0-6.el7.x86
Re: Error: nagiosxi-deps-el7 conflicts with nrpe-3.2.0-6.el7
At present can you visit the nagios XI pages through the web UI?
Getting http error while accessing web page. please refer attached error for more info.
Status for all services.
systemctl status httpd
systemctl status nagios
cd /usr/local/nagios/var/
systemctl status ndo2db
systemctl status npcd
systemctl status mariadb
● httpd.service - The Apache HTTP Server
Loaded: loaded (/usr/lib/systemd/system/httpd.service; enabled; vendor preset: disabled)
Active: active (running) since Mon 2018-07-02 10:49:31 EDT; 1 day 18h ago
Docs: man:httpd(8)
man:apachectl(8)
Process: 79065 ExecStop=/bin/kill -WINCH ${MAINPID} (code=exited, status=0/SUCCESS)
Main PID: 79070 (httpd)
Status: "Total requests: 8115; Current requests/sec: 0; Current traffic: 0 B/sec"
CGroup: /system.slice/httpd.service
├─ 79070 /usr/sbin/httpd -DFOREGROUND
├─ 79071 /usr/sbin/httpd -DFOREGROUND
├─ 79074 /usr/sbin/httpd -DFOREGROUND
├─ 79076 /usr/sbin/httpd -DFOREGROUND
├─ 79077 /usr/sbin/httpd -DFOREGROUND
├─ 79078 /usr/sbin/httpd -DFOREGROUND
├─ 79826 /usr/sbin/httpd -DFOREGROUND
├─ 80124 /usr/sbin/httpd -DFOREGROUND
├─ 81738 /usr/sbin/httpd -DFOREGROUND
├─ 81973 /usr/sbin/httpd -DFOREGROUND
├─ 82848 /usr/sbin/httpd -DFOREGROUND
└─110059 /usr/sbin/httpd -DFOREGROUND
Jul 02 10:49:31 usa0300lv1759 systemd[1]: Starting The Apache HTTP Server...
Jul 02 10:49:31 usa0300lv1759 httpd[79070]: AH00558: httpd: Could not reliably determine the server's fully qualified domain name,...message
Jul 02 10:49:31 usa0300lv1759 systemd[1]: Started The Apache HTTP Server.
Hint: Some lines were ellipsized, use -l to show in full.
● nagios.service - LSB: Starts and stops the Nagios monitoring server
Loaded: loaded (/etc/rc.d/init.d/nagios; bad; vendor preset: disabled)
Active: failed (Result: resources) since Mon 2018-07-02 10:41:09 EDT; 1 day 18h ago
Docs: man:systemd-sysv-generator(8)
Main PID: 95866 (code=exited, status=0/SUCCESS)
Jul 02 10:41:07 usa0300lv1759 nagios[76480]: ndomod registered for process data
Jul 02 10:41:07 usa0300lv1759 nagios[76480]: ndomod registered for log data'
Jul 02 10:41:07 usa0300lv1759 nagios[76480]: ndomod registered for system command data'
Jul 02 10:41:07 usa0300lv1759 nagios[76480]: ndomod registered for event handler data'
Jul 02 10:41:07 usa0300lv1759 nagios[76447]: Starting nagios: done.
Jul 02 10:41:07 usa0300lv1759 systemd[1]: PID 76480 read from file /usr/local/nagios/var/nagios.lock does not exist or is a zombie.
Jul 02 10:41:09 usa0300lv1759 systemd[1]: nagios.service never wrote its PID file. Failing.
Jul 02 10:41:09 usa0300lv1759 systemd[1]: Failed to start LSB: Starts and stops the Nagios monitoring server.
Jul 02 10:41:09 usa0300lv1759 systemd[1]: Unit nagios.service entered failed state.
Jul 02 10:41:09 usa0300lv1759 systemd[1]: nagios.service failed.
[root@usa0300lv1759 50004256]# systemctl start nagios
Job for nagios.service failed because a configured resource limit was exceeded. See "systemctl status nagios.service" and "journalctl -xe" for details.
[root@usa0300lv1759 50004256]# systemctl status nagios.service
Active: failed (Result: resources) since Wed 2018-07-04 05:32:32 EDT; 8s ago
Process: 88029 ExecStart=/etc/rc.d/init.d/nagios start (code=exited, status=0/SUCCESS)
Jul 04 05:32:30 usa0300lv1759 nagios[88060]: Error: Failed to load module '/usr/local/lib/mod_gearman2/mod_gearman2.o'.
Jul 04 05:32:30 usa0300lv1759 nagios[88060]: ndomod: NDOMOD 2.1.2 (11-14-2016) Copyright (c) 2009 Nagios Core Development Team and...ibutors
Jul 04 05:32:30 usa0300lv1759 nagios[88060]: ndomod: Successfully connected to data sink. 0 queued items to flush.
Jul 04 05:32:30 usa0300lv1759 nagios[88060]: ndomod registered for process data
Jul 04 05:32:30 usa0300lv1759 nagios[88029]: Starting nagios: done.
Jul 04 05:32:30 usa0300lv1759 systemd[1]: PID 88060 read from file /usr/local/nagios/var/nagios.lock does not exist or is a zombie.
Jul 04 05:32:32 usa0300lv1759 systemd[1]: nagios.service never wrote its PID file. Failing.
Jul 04 05:32:32 usa0300lv1759 systemd[1]: Failed to start LSB: Starts and stops the Nagios monitoring server.
Jul 04 05:32:32 usa0300lv1759 systemd[1]: Unit nagios.service entered failed state.
Jul 04 05:32:32 usa0300lv1759 systemd[1]: nagios.service failed.
drwxrwxr-x 2 nagios nagios 4096 Jun 26 05:55 archives
-rw-r--r-- 1 nagios nagios 178650546 Jun 11 2015 host-perfdata
-rw-r--r-- 1 root root 10875797 Feb 5 08:54 host-perfdata.tar.tz
-rw-r--r-- 1 nagios nagios 3949 Jul 4 05:32 nagios.configtest
-rw-rw-r-- 1 nagios nagios 5421803 Jul 4 05:32 nagios.log
-rw-r--r-- 1 nagios nagios 6 Jul 2 10:41 ndo2db.lock
-rw-r--r-- 1 nagios nagios 0 Jun 26 08:26 ndomod.tmp
srwxr-xr-x 1 nagios nagios 0 Jul 2 10:41 ndo.sock
-rw-rw-r-- 1 nagios nagios 293470 Jul 2 10:41 npcd.log
-rw-rw-r-- 1 nagios nagios 697820 Jun 12 2015 objects.cache
-rw-r--r-- 1 nagios nagios 636311 Jul 4 05:32 objects.precache
-rw-rw-rw- 1 nagios nagios 3901674 Jun 26 08:26 perfdata.log
-rw------- 1 nagios nagios 913132 Jul 4 05:32 retention.dat
drwxrwsr-x 2 nagios nagios 23 Jul 4 05:32 rw
-rw-r--r-- 1 nagios nagios 1016761289 Jun 11 2015 service-perfdata
drwxrwxr-x 5 nagios nagios 55 Oct 31 2014 spool
drwxrwxr-x 2 nagios nagios 22 Jun 26 08:26 stats
● ndo2db.service - Nagios Data Out Daemon
Loaded: loaded (/usr/lib/systemd/system/ndo2db.service; enabled; vendor preset: disabled)
Active: active (running) since Mon 2018-07-02 10:41:07 EDT; 1 day 18h ago
Docs: http://www.nagios.org/documentation
Main PID: 76435 (ndo2db)
CGroup: /system.slice/ndo2db.service
└─76435 /usr/local/nagios/bin/ndo2db -c /usr/local/nagios/etc/ndo2db.cfg -f
Jul 02 10:41:07 usa0300lv1759 systemd[1]: Started Nagios Data Out Daemon.
Jul 02 10:41:07 usa0300lv1759 systemd[1]: Starting Nagios Data Out Daemon...
Jul 02 10:41:07 usa0300lv1759 ndo2db[76491]: Successfully connected to MySQL database
Jul 02 10:41:07 usa0300lv1759 ndo2db[76491]: Successfully disconnected from MySQL database
● npcd.service - SYSV: Visit the Website at http://sourceforge.net/projects/pnp4nagios/
Loaded: loaded (/etc/rc.d/init.d/npcd; bad; vendor preset: disabled)
Main PID: 76423 (npcd)
CGroup: /system.slice/npcd.service
└─76423 /usr/local/nagios/bin/npcd -d -f /usr/local/nagios/etc/pnp/npcd.cfg
Jul 02 10:41:07 usa0300lv1759 systemd[1]: Starting SYSV: Visit the Website at http://sourceforge.net/projects/pnp4nagios/...
Jul 02 10:41:07 usa0300lv1759 npcd[76417]: NPCD started.
Jul 02 10:41:07 usa0300lv1759 systemd[1]: Failed to read PID from file /usr/local/nagiosxi/var/subsys/npcd.pid: Invalid argument
Jul 02 10:41:07 usa0300lv1759 systemd[1]: Started SYSV: Visit the Website at http://sourceforge.net/projects/pnp4nagios/.
mariadb.service - MariaDB database server
Loaded: loaded (/usr/lib/systemd/system/mariadb.service; enabled; vendor preset: disabled)
Active: active (running) since Mon 2018-07-02 10:41:05 EDT; 1 day 18h ago
Main PID: 75941 (mysqld_safe)
CGroup: /system.slice/mariadb.service
├─75941 /bin/sh /usr/bin/mysqld_safe --basedir=/usr
└─76175 /usr/libexec/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib64/mysql/plugin --log-error=/var/log/...
Jul 02 10:41:03 usa0300lv1759 systemd[1]: Starting MariaDB database server...
Jul 02 10:41:03 usa0300lv1759 mariadb-prepare-db-dir[75910]: Database MariaDB is probably initialized in /var/lib/mysql already, not...done.
Jul 02 10:41:03 usa0300lv1759 mariadb-prepare-db-dir[75910]: If this is not the case, make sure the /var/lib/mysql is empty before r...-dir.
Jul 02 10:41:03 usa0300lv1759 mysqld_safe[75941]: 180702 10:41:03 mysqld_safe Logging to '/var/log/mariadb/mariadb.log'.
Jul 02 10:41:03 usa0300lv1759 mysqld_safe[75941]: 180702 10:41:03 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql
Jul 02 10:41:05 usa0300lv1759 systemd[1]: Started MariaDB database server.
Let's see the httpd error log again, I don't see what could be causing these 500 errors
Have attached all logs for your reference ..
Also when we are accessing localhost homepage we are able to access it but when we click on "Access Nagios XI" we are getting 500 error page as shared before.
thought to update you! in existing environment we have gearmand service running to offload the checks load is that cause any issue while restoring backup ?
Please run the following
service postgresql start
systemctl start mariadb
systemctl enable mariadb
systemctl enable postgresqlRe: Error: nagiosxi-deps-el7 conflicts with nrpe-3.2.0-6.el7
done, but still 500 error page while accessing web page. http://serverip/nagiosxi/
[root@usa0***** 50004256]# service postgresql start
Redirecting to /bin/systemctl start postgresql.service
[root@usa03***** 50004256]# systemctl start mariadb
[root@usa03***** 50004256]# systemctl enable mariadb
[root@usa03***** 50004256]# systemctl enable postgresql
systemctl status postgresql
postgresql.service - PostgreSQL database server
Loaded: loaded (/usr/lib/systemd/system/postgresql.service; enabled; vendor preset: disabled)
Active: active (running) since Wed 2018-07-04 10:48:48 EDT; 1 day 18h ago
Main PID: 39179 (postgres)
CGroup: /system.slice/postgresql.service
├─27089 postgres: nagiosxi nagiosxi 127.0.0.1(44816) idle
├─39179 /usr/bin/postgres -D /var/lib/pgsql/data -p 5432
├─39180 postgres: logger process
├─39182 postgres: checkpointer process
├─39183 postgres: writer process
├─39184 postgres: wal writer process
├─39185 postgres: autovacuum launcher process
├─39186 postgres: stats collector process
├─39188 postgres: nagiosxi nagiosxi 127.0.0.1(39506) idle
├─39189 postgres: nagiosxi nagiosxi 127.0.0.1(39508) idle
├─39191 postgres: nagiosxi nagiosxi 127.0.0.1(39512) idle
├─39193 postgres: nagiosxi nagiosxi 127.0.0.1(39516) idle
├─39194 postgres: nagiosxi nagiosxi 127.0.0.1(39518) idle
├─39196 postgres: nagiosxi nagiosxi 127.0.0.1(39520) idle
├─39340 postgres: nagiosxi nagiosxi 127.0.0.1(39540) idle
├─40070 postgres: nagiosxi nagiosxi 127.0.0.1(39638) idle
├─42480 postgres: nagiosxi nagiosxi 127.0.0.1(33434) idle
├─42584 postgres: nagiosxi nagiosxi 127.0.0.1(33444) idle
├─42586 postgres: nagiosxi nagiosxi 127.0.0.1(33448) idle
├─42589 postgres: nagiosxi nagiosxi 127.0.0.1(33450) idle
├─42602 postgres: nagiosxi nagiosxi 127.0.0.1(33456) idle
└─42603 postgres: nagiosxi nagiosxi 127.0.0.1(33458) idle
Jul 04 10:48:46 usa0300lv1759 systemd[1]: Starting PostgreSQL database server...
Jul 04 10:48:47 usa0300lv1759 pg_ctl[39175]: LOG: could not bind IPv6 socket: Cannot assign requested address
Jul 04 10:48:47 usa0300lv1759 pg_ctl[39175]: HINT: Is another postmaster already running on port 5432? If not, wait a few seconds... retry.
Jul 04 10:48:48 usa0300lv1759 systemd[1]: Started PostgreSQL database server.
● mariadb.service - MariaDB database server
Active: active (running) since Mon 2018-07-02 10:41:05 EDT; 3 days ago
The only 500 errors I could see in the logs from you accessing the login page was from not being able to connect to those services.
Error is still same while accessing http://myserverip/nagiosxi/
http://myserverip/ (accessible ) attached screenshot and when we click on "Access NagiosXI" getting http 500 error (Attached error)
just now when i check all services status all are running except nagios. don't know whats going on and what we are missing?
and just to update you on another server i am able to install the Nagios XI 2014 R2.7
so now we have two VM's
1-
RHEL 7.4 having 5.4.13 ( on which currently we are working upon)
2-
RHEL 7.4 having 2014 R2.7 (older version we are running in live environment)
As this thread is going too long and still we are not able to identify what we are missing, can we do remote session where you can directly work and troubleshoot if needed. keeping both VM as per requirement.
[root@usa03**** crt]# systemctl status nagios
Active: failed (Result: resources) since Fri 2018-07-06 05:12:10 EDT; 5h 51min ago
Process: 45271 ExecStart=/etc/rc.d/init.d/nagios start (code=exited, status=0/SUCCESS)
Main PID: 42829 (code=exited, status=1/FAILURE)
Jul 06 05:12:08 usa0300lv1759 nagios[45302]: Error: Failed to load module '/usr/local/lib/mod_gearman2/mod_gearman2.o'.
Jul 06 05:12:08 usa0300lv1759 nagios[45302]: ndomod: NDOMOD 2.1.2 (11-14-2016) Copyright (c) 2009 Nagios Core Development Team and...ibutors
Jul 06 05:12:08 usa0300lv1759 nagios[45302]: ndomod: Successfully connected to data sink. 0 queued items to flush.
Jul 06 05:12:08 usa0300lv1759 nagios[45302]: ndomod registered for process data
Jul 06 05:12:08 usa0300lv1759 nagios[45271]: Starting nagios: done.
Jul 06 05:12:08 usa0300lv1759 systemd[1]: PID 45302 read from file /usr/local/nagios/var/nagios.lock does not exist or is a zombie.
Jul 06 05:12:10 usa0300lv1759 systemd[1]: nagios.service never wrote its PID file. Failing.
Jul 06 05:12:10 usa0300lv1759 systemd[1]: Failed to start LSB: Starts and stops the Nagios monitoring server.
Jul 06 05:12:10 usa0300lv1759 systemd[1]: Unit nagios.service entered failed state.
Jul 06 05:12:10 usa0300lv1759 systemd[1]: nagios.service failed.
1-
2-
I think this is an excellent idea as I agree the thread is long and getting hard to work with, can you please open a support ticket atrtsupport wrote:As this thread is going too long and still we are not able to identify what we are missing, can we do remote session where you can directly work and troubleshoot if needed. keeping both VM as per requirement.
https://support.nagios.com/tickets/
Reference this thread and we will close the thread and can setup a support session.
Closing the thread as we have a ticket open.
