Modifying Reports
mikew
Modifying Reports
Post by mikew »
I am wondering if there is a way to do two things with reports:
1. Save reports to a database either on the server or on a remote server
The idea here is if you send a report automatically to a user and then 3 weeks later they ask a question on it you do not have a copy of the report...I guess you could select the day but not as convenient.
2. Save reports with a date
Here, if you had a report called "CentOS Availability" it would overwrite the last report if you sent them out because they are called the same. Is there a way of entering a date macro on that report.
As always...thanks for the help...appreaciate the time you take to look at these questions.
Mike Weber
Nagios Training/Consulting
abrist
Red Shirt
Re: Modifying Reports
Post by abrist »
Both of these feature requests require modifying sourceguardian protected code, otherwise I would try to do the edits to the php for you. Put in a feature request @ tracker.nagios.com and we will see what we can do.
