Add sevices to servicegroup
MichaelW
Post by MichaelW »
Hi all,
I know how to create a service group and to add services to it manually. What I want to do is to do it more automatically.
I have created a service template called fileage-sevice. After that I have created several services that use this template to monitor the age of certain logfiles.
Now I would like to create a service group that includes all services that use the fileage-service template.
Unfortunately
define servicegroup{
        servicegroup_name       LogFiles
        alias                   Log File Monitor
        members      hostname,fileage-service
does not work.
Any idea how this can be done?
Regards,
Michael
Re: Add sevices to servicegroup
Post by slansing »
This can be done two ways as outlined here:
http://nagios.sourceforge.net/docs/3_0/ ... rvicegroup
You can either define the servicegroups as you have, or add the servicegroup name to each individual service's config file, it should work in either fashion, what is happening once you verify the config files?
MichaelW
Post by MichaelW »
Thank you. I didn't realize I can add a servicegroup to a service. This is exactly what I was looking for.
