I made a misc command in nagios that can use these external commands.
/usr/local/nagios/libexec/eventhandlers/handle-master-host-event $HOSTSTATE$ $HOSTSTATETYPE$They both monitor each other, but only alert on their own facilities and each others router.
Here is a map.
Naigos1----Router1-----Router2----Nagios2From the view point of the nagios server in Facility 1
If
Naigos1: Up ---- Router1: Up ----- Router2: Up---- Nagios2: Down
then
Nagios will enable notifications on Facility 2Code: Select all
If
Naigos1: Up ---- Router1: Up ----- Router2: Down---- Nagios2: Down
then
Nagios will disable notifications on Facility 2Code: Select all
If
Naigos2: Up ---- Router2: Up ----- Router1: Up---- Nagios1: Down
then
Nagios will enable notifications on Facility 1Code: Select all
If
Naigos2: Up ---- Router2: Up ----- Router1: Down---- Nagios1: Down
then
Nagios will disable notifications on Facility 1If the service is up, then disable alerts.
If the serivce is down/unknown, then enable alerts.
Then set up the same thing on Nagios2.
So from Nagios1 perspective what would happen when Router2 goes down, as well as Nagios2, would it's Event Handler overrule the services Event Handler?
What version of Nagios XI are you using? Nagios XI 2012R1.8
Linux Distribution and version? centos 6.3
32 or 64bit? 32bit
VMware Image or Manual Install of XI? VMware Image
Are there specials configurations on your system, ie; is Gnome installed? Are you using a proxy? Are you using SSL? none
