I'm trying to create a dashboard that presents the bandwidth utilization for switchports that connect to our vendor controlled routers. We have about 10 locations and I'd like to add the bandwidth graph from each switchport that connects to the router router in each location. This is simple enough, but the presentation of the data leaves a few things I'd like to modify.
1. I have added a description to each graph, but this is only available if a user mouses over on the graph. The graph shows "Datasource: ds1", but I'm not sure how to change that.
2. Thresholds for Warning and Critical are not shown in the graph. Circuit speeds and thresholds are different at each location and I'd like to display the bandwidth relative to the thresholds all in one place.
3. On the left it says Mb/s but if traffic is below a certain amount, traffic is displayed as 100-900 m
Is there a better way to go about this, or is this just not something that is commonly done?
Bandwidth Dashboard
thepacketslinger
Bandwidth Dashboard
sreinhardt
- -fno-stack-protector
Re: Bandwidth Dashboard
I think these changes are possible. However it would likely require changes to some of our protected code. We will discuss with a few developers, but I might also suggest to contact sales and look into custom development of a new dashlet for you. I think this could be done pretty quickly.
This feature/question is of great interest to me as well. Specifically I'm interested in part 2 of the original post:
I know when I create performance data through a plugin I can define these thresholds and they show up as lines on the graph. Can this be done for Bandwidth graphs created via mrtg?
Should I open a separate query for this?
Cheers,
Lee Benson
Transmax
Cheers,
Lee Benson
Transmax
2. Thresholds will only display as you near the threshold. The graph images, when generated, will do so based on the max 'y' value recorded. When setting up monitoring through the switch/routing wizard, thresholds can be specified. In you example, both of these ports are averaging less than 1Mbps - If these are 10/100 or gigabit, the recorded values are much smaller than the default thresholds.
3. 'm' represents 'mils' - so 600m is equivalent to 0.6 Mbps.
Hi again,
Sorry to disagree, but your comment on 2) is incorrect.
Please see images attached. In the last month, the warning threshold was passed twice. We got alerts (good) but the graph does NOT show the threshold lines.
Cheers,
Lee
Cheers,
Lee
Seems that is the case with the mrtg template. You could add the threshold lines by adding a few lines to the mrtg template:transmax wrote:Sorry to disagree, but your comment on 2) is incorrect.
vi /usr/local/nagios/share/pnp/templates/check_xi_service_mrtgtraf.phpCode: Select all
$def[1] .= "HRULE:$WARN[1]#ffff00:\"IN Warning $WARN[1]$UNIT[1] \" " ;
$def[1] .= "HRULE:$CRIT[1]#ff0000:\"IN Critical $CRIT[1]$UNIT[1] \" " ;
$def[1] .= "HRULE:$WARN[2]#ffcc00:\"OUT Warning $WARN[2] $UNIT[2] \" " ;
$def[1] .= "HRULE:$CRIT[2]#a00000:\"OUT Critical $CRIT[2] $UNIT[2] \" " ;I will talk to the devs as I am unsure why this was not a part of the template to begin with.
