"Nagios deamon is not running"
m_OO_m
Post by m_OO_m »
Hello there,
trying to find a reason for some interface problems, I have imported a new VMWare-Image (1.3 D). As soon as the appliance is up and passwords are set, go to then Config Manager / Tools / Write Config Files and try to restart nagios. And you will see:
Nagios deamon is not running, cannot send restart command
mguthrie
Re: "Nagios deamon is not running"
Post by mguthrie »
We've seen this before, and if I repeat your steps I get the same message. I'm not sure as to the cause of this, but I'm going to post it to the bug tracker.
http://tracker.nagios.com/view.php?id=93
Meanwhile:
You can also restart Nagios from the Admin->XI System Component Status->Monitoring Engine link.
