Check_snmp: Range format incorrect
adrian1984
Post by adrian1984 »
I'm trying to use check_snmp for some ups script, but I always get the title error.
The parameter of warning and critical are the following: -w 80:50 -c 49:0
I was looking for something similar around the web and i read about a bug in the nagios plugin 1.4.14.
Do you know something about it? I use it even with an older version and it works.
There is anybody could help me? thanks
