The web config difference between Nagios Core and Nagios XI
Tiger777
Post by Tiger777 »
Hello all
Can smbd tell me about difference in main config between Nagios Core and Nagios XI ?
I'm going to test the Nagios system, and the main testing point is hosts/services configuration and notifications configuration. So can you tell me completly is there any difference in the algorithms of this in Core&XI ?
yancy
Re: The web config difference between Nagios Core and Nagios
Post by yancy »
Tiger777,
NagiosXI uses Nagios Core config files. There is no difference in how the config files look between implementations.
The big difference with NagiosXI is all of the configurations are stored in a database, and then when configurations are applied, NagiosXI will write the configs from the database to flat config files. Essentially, NagiosXI will write the config files for you.
-Yancy
Tiger777
Post by Tiger777 »
Yancy, thanks a lot!
