This support forum board is for support questions relating to
Nagios XI , our flagship commercial network monitoring solution.
damiancurry
Posts: 10 Joined: Thu Oct 21, 2010 4:23 pm
Post
by damiancurry » Wed Nov 17, 2010 5:27 pm
Processing object config file '/usr/local/nagios/etc/hosts/sea-tts04.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/seapdc01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/spmpu003.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-xtap2776a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru1117.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/em2355c.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2138.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/seagfi01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/dpmpu008.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-voip-jnpr-1.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-auth01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/xtap2695e.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2125.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-voip-acme-4500-02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-xtap2750a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-app-vip04.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-encrypt02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-ihttp-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-ecti-vip01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-esx02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-edns-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/xtap38d.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-tts07.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2117.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2146.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-uxbh01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-syslog02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-esoap-vip02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-esx09.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-xtap2676a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru1132.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-chsoap-via-den.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2014.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2133.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru1119.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2122.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2136.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-esx03.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-xtap01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2139.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-websrv03.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-koi-02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-vcdb-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2004.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/ps2903.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-bkup02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2123.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2126.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-xtap2627a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/spcvt03.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2013.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/seapalm01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-mq2676a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-xtap2629a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-winbh01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-twst01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-app-sca03.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-lds02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/dpmpu009.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/seapscsp.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2121.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-xtap2747a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/spmpu007.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-xtap2595e.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-ihttp-vip-51.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-ss-sca02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2007.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-ldm01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-xtap2614c.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/xtap2695h.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2018.cfg'...
Processing object config directory '/usr/local/nagios/etc/services'...
Processing object config file '/usr/local/nagios/etc/services/vru1002.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2699a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2735a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/dpmpu003.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-esoap-vip02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-mail-vip02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-osprey01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-sea-gateway.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-voip-4500-01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-osprey02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-app-scb01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap31c.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-esoap-vip01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-ctiejb-vip01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-lis03.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-ossdb01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-mq2677b.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/vru1131.cfg'...
Processing object config file '/usr/local/nagios/etc/services/spvx01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/spmpu011.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2779a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-esx10.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-xtap2723a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-esx02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/spmpu013.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-osprey01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-bkup02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/bg-sea-gateway.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-iwi-02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-xtapmc01a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-winbh02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/voip_hosts.cfg'...
Processing object config file '/usr/local/nagios/etc/services/dpmpu004.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-chsoap-via-den.cfg'...
Processing object config file '/usr/local/nagios/etc/services/ps1903.cfg'...
Processing object config file '/usr/local/nagios/etc/services/spmpu010.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-lis02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-chsoap-via-sea.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-app-vip03.cfg'...
Processing object config file '/usr/local/nagios/etc/services/dpcvt01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/vru1134.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-xtap99a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/vru1122.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-dcmstr-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/services/spmpu008.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-tts08.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-syslog02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/spvx02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/xtap2638f.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2634c.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2683a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/spmpu006.cfg'...
Processing object config file '/usr/local/nagios/etc/services/spmpu001.cfg'...
Processing object config file '/usr/local/nagios/etc/services/dpmpu005.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-ss-sca01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-esx11.cfg'...
Processing object config file '/usr/local/nagios/etc/services/spmpu004.cfg'...
Processing object config file '/usr/local/nagios/etc/services/seaplog01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-xtap2632a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/vru1123.cfg'...
Processing object config file '/usr/local/nagios/etc/services/dpdc02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2784a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/dpvx01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-ss-sca01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/xtap2638e.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-media-sca02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-soapejb-vip01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-eproxy-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/services/dpalm01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-auth02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-twse01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-chapp01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-xtap2476a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/vru1135.cfg'...
Processing object config file '/usr/local/nagios/etc/services/em2638g.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-uxbh02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2620c.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-app-scb02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-rmanprd-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/services/vru1001.cfg'...
Processing object config file '/usr/local/nagios/etc/services/vru1136.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-soapejb-vip02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-app-vip02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/windowschecks.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-lb-sca01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/snmpchecks.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-ss-sca02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/dpcvt02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-xtap2620a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-esx12.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-encrypt02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/spcvt01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-ehttp-vip02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/spmpu015.cfg'...
Processing object config file '/usr/local/nagios/etc/services/seapstg01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/seapdc02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/spmpu019.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2644a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/dpcfg01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-db15.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-sea-gateway.cfg'...
Processing object config file '/usr/local/nagios/etc/services/dpstg01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/vru1116.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2638c.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-lis01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/vru1118.cfg'...
Processing object config file '/usr/local/nagios/etc/services/dpmpu006.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-chweb01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-voip-4500-02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-xtap27a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-esx12.cfg'...
Processing object config file '/usr/local/nagios/etc/services/dpmpu001.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-eproxy-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-ihttp-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-app-sca01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-media-sca01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-odmz-sca01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-idns-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-esx06.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-ismtp-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-app-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2625c.cfg'...
Processing object config file '/usr/local/nagios/etc/services/spmpu009.cfg'...
Processing object config file '/usr/local/nagios/etc/services/services.cfg'...
Processing object config file '/usr/local/nagios/etc/services/spmpu012.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-esx11.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-db14.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-ehttp-vip01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-xtap1216a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-chsoap-via-erica.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-tts06.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2794a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2625d.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap02-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-voip-acme-4500-01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/em2638a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-xtap2751a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/vru1124.cfg'...
Processing object config file '/usr/local/nagios/etc/services/dpvx02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-db16.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-mq2676b.cfg'...
Processing object config file '/usr/local/nagios/etc/services/vru1133.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-mqa-vip01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-lds01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-vc02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-app-vip04.cfg'...
Processing object config file '/usr/local/nagios/etc/services/ps1904.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-esx08.cfg'...
Processing object config file '/usr/local/nagios/etc/services/dpmpu010.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-esmtp-vip02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-esx05.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-encrypt01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/seapsalvo01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/vru1125.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-mail-vip01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/dpmpu007.cfg'...
Processing object config file '/usr/local/nagios/etc/services/dplog01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/vru1108.cfg'...
Processing object config file '/usr/local/nagios/etc/services/dpmpu002.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-osprey02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-ch-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2654a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/localhost.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-idmz-sca01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-ctiejb-vip02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-chsoap-via-sea.cfg'...
Processing object config file '/usr/local/nagios/etc/services/dpvx03.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-oltp-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-mqm-vip01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-ossdb01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-app-sca02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-app-vip01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/spcfg01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/port_checks.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2683c.cfg'...
Processing object config file '/usr/local/nagios/etc/services/io_checks.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2676b.cfg'...
Processing object config file '/usr/local/nagios/etc/services/vru1110.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-lis03.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-syslog01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-app-sca04.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-esx07.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2683d.cfg'...
Processing object config file '/usr/local/nagios/etc/services/dpsalvo01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-tts05.cfg'...
Processing object config file '/usr/local/nagios/etc/services/dpdc01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-xtap2746a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-odmz-sca02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2688c.cfg'...
Processing object config file '/usr/local/nagios/etc/services/em2638h.cfg'...
Processing object config file '/usr/local/nagios/etc/services/spmpu002.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-esmtp-vip01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-xtap2678a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2648a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/spmpu014.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2767a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/spmpu005.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-lb-sca02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/proc_checks.cfg'...
Processing object config file '/usr/local/nagios/etc/services/vru1107.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-ecti-vip02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2792a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/spcvt02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-encrypt03.cfg'...
Processing object config file '/usr/local/nagios/etc/services/vru1109.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-mq2677a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2775a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-chsoap-via-erica.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-idmz-sca02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-encrypt04.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2787a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-esx01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/seapdc01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/spmpu003.cfg'...
Processing object config file '/usr/local/nagios/etc/services/#den-xtap02-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2776a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/vru1117.cfg'...
Processing object config file '/usr/local/nagios/etc/services/dpmpu008.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-voip-acme-4500-02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2750a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-ecti-vip01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-edns-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-tts07.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-uxbh01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-esx09.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2676a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/vru1132.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-chsoap-via-den.cfg'...
Processing object config file '/usr/local/nagios/etc/services/ingrian.cfg'...
Processing object config file '/usr/local/nagios/etc/services/vru1119.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-koi-02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-vcdb-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2627a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/spcvt03.cfg'...
Processing object config file '/usr/local/nagios/etc/services/vru2013.cfg'...
Processing object config file '/usr/local/nagios/etc/services/seapalm01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-mq2676a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2629a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-winbh01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-twst01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-app-sca03.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-lds02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/dpmpu009.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2747a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/spmpu007.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-ss-sca02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/logchecks.cfg'...
Warning: Duplicate definition found for service 'ssh' on host 'den-xtap02-vip' (config file '/usr/local/nagios/etc/services/den-xtap02-vip.cfg', starting on line 64)
Warning: Duplicate definition found for service 'procs_syslog' on host 'den-xtap02-vip' (config file '/usr/local/nagios/etc/services/den-xtap02-vip.cfg', starting on line 56)
Warning: Duplicate definition found for service 'power_supply' on host 'den-xtap02-vip' (config file '/usr/local/nagios/etc/services/den-xtap02-vip.cfg', starting on line 47)
Warning: Duplicate definition found for service 'icmp' on host 'den-xtap02-vip' (config file '/usr/local/nagios/etc/services/den-xtap02-vip.cfg', starting on line 31)
Warning: Duplicate definition found for service 'disk_error' on host 'den-xtap02-vip' (config file '/usr/local/nagios/etc/services/den-xtap02-vip.cfg', starting on line 22)
Warning: Duplicate definition found for service 'disk' on host 'den-xtap02-vip' (config file '/usr/local/nagios/etc/services/den-xtap02-vip.cfg', starting on line 14)
Checking services...
Warning: Service 'snmp_trap' on host 'den-voip-4500-01' has a notification interval less than its check interval! Notifications are only re-sent after checks are made, so the effective notification interval will be that of the check interval.
Warning: Service 'snmp_trap' on host 'den-voip-4500-02' has a notification interval less than its check interval! Notifications are only re-sent after checks are made, so the effective notification interval will be that of the check interval.
Warning: Service 'snmp_trap' on host 'sea-voip-acme-4500-01' has a notification interval less than its check interval! Notifications are only re-sent after checks are made, so the effective notification interval will be that of the check interval.
Warning: Service 'snmp_trap' on host 'sea-voip-acme-4500-02' has a notification interval less than its check interval! Notifications are only re-sent after checks are made, so the effective notification interval will be that of the check interval.
Checked 2309 services.
Checking hosts...
Checked 472 hosts.
Checking host groups...
Checked 43 host groups.
Checking service groups...
Checked 0 service groups.
Checking contacts...
Checked 13 contacts.
Checking contact groups...
Checked 8 contact groups.
Checking service escalations...
Checked 2309 service escalations.
Checking service dependencies...
Checked 0 service dependencies.
Checking host escalations...
Checked 0 host escalations.
Checking host dependencies...
Checked 0 host dependencies.
Checking commands...
Checked 152 commands.
Checking time periods...
Checked 9 time periods.
Checking for circular paths between hosts...
Checking for circular host and service dependencies...
Checking misc settings...
Total Warnings: 4
Total Errors: 0
RET: 0
Running configuration check...done.
Stopping nagios: .done.
Starting nagios: done.
/usr/local/nagiosxi/nom/checkpoints/nagioscore /usr/local/nagiosxi/scripts
mguthrie
Posts: 4380 Joined: Mon Jun 14, 2010 10:21 am
Post
by mguthrie » Wed Nov 17, 2010 5:42 pm
Let's try this, and if it doesn't work, I'll send you a remote invitation tomorrow morning:
/usr/local/nagiosxi/scripts/reset_config_perms
/usr/localnagiosxi/scripts/reconfigure_nagios.sh
damiancurry
Post
by damiancurry » Wed Nov 17, 2010 5:56 pm
I was unable to execute /usr/local/nagiosxi/scripts/reset_config_perms, but /usr/local/nagiosxi/scripts/reset_config_perms.sh executed fine. Here is the output:
[root@sea-moncon01 scripts]# ./reset_config_perms
-bash: ./reset_config_perms: /lib/ld-linux.so.2: bad ELF interpreter: No such file or directory
[root@sea-moncon01 scripts]# ./reset_config_perms.sh
RESETTING PERMS
And here is the script output, in 2 posts:
[root@sea-moncon01 scripts]# ./reconfigure_nagios.sh | tee output.txt
--2010-11-17 14:51:41-- http://localhost/nagiosql/index.php
Resolving localhost... 127.0.0.1
Connecting to localhost|127.0.0.1|:80... connected.
HTTP request sent, awaiting response... 302 Found
Location: http://localhost/nagiosql/admin.php [following]
--2010-11-17 14:51:41-- http://localhost/nagiosql/admin.php
Length: 5286 (5.2K) [text/html]
Saving to: `nagiosql.login'
100%[=============================================================>] 5,286 --.-K/s in 0s
2010-11-17 14:51:41 (219 MB/s) - `nagiosql.login' saved [5286/5286]
IMPORTING CONFIG FILES...Array
./export_nagiosql.sh: ./reset_config_perms: /lib/ld-linux.so.2: bad ELF interpreter: No such file or directory
--2010-11-17 14:51:42-- http://localhost/nagiosql/admin.php
2010-11-17 14:51:42 (194 MB/s) - `nagiosql.login' saved [5286/5286]
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosql/admin/verify.php --post-data 'writeMonitoring=Go' -O nagiosql.export.monitoring
--2010-11-17 14:51:42-- http://localhost/nagiosql/admin/verify.php
Length: 7096 (6.9K) [text/html]
Saving to: `nagiosql.export.monitoring'
100%[=============================================================>] 7,096 --.-K/s in 0s
2010-11-17 14:51:42 (165 MB/s) - `nagiosql.export.monitoring' saved [7096/7096]
Length: 7400 (7.2K) [text/html]
Saving to: `nagiosql.export.additional'
100%[=============================================================>] 7,400 --.-K/s in 0s
2010-11-17 14:51:43 (243 MB/s) - `nagiosql.export.additional' saved [7400/7400]
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosql/admin/verify.php --post-data 'writeAdditional=Go' -O nagiosql.export.additional
OUTPUT:
Nagios Core 3.2.2
Copyright (c) 2009-2010 Nagios Core Development Team and Community Contributors
Last Modified: 09-01-2010
License: GPL
Reading configuration data...
Read main config file okay...
Processing object config directory '/usr/local/nagios/etc/static'...
Processing object config file '/usr/local/nagios/etc/static/xitest.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xiobjects.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xitemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/contacttemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/contactgroups.cfg'...
Processing object config file '/usr/local/nagios/etc/contacts.cfg'...
Processing object config file '/usr/local/nagios/etc/timeperiods.cfg'...
Processing object config file '/usr/local/nagios/etc/commands.cfg'...
Processing object config file '/usr/local/nagios/etc/hostgroups.cfg'...
Processing object config file '/usr/local/nagios/etc/servicegroups.cfg'...
Processing object config file '/usr/local/nagios/etc/hosttemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/servicetemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/servicedependencies.cfg'...
Processing object config file '/usr/local/nagios/etc/serviceescalations.cfg'...
Processing object config file '/usr/local/nagios/etc/hostdependencies.cfg'...
Processing object config file '/usr/local/nagios/etc/hostescalations.cfg'...
Processing object config file '/usr/local/nagios/etc/hostextinfo.cfg'...
Processing object config file '/usr/local/nagios/etc/serviceextinfo.cfg'...
Processing object config directory '/usr/local/nagios/etc/hosts'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-srv01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2127.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-app-vip02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru1002.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-xtap2699a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2128.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/xtap2709a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2148.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-xtap2735a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/dpmpu003.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-esoap-vip02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-esx01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-mail-vip02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-osprey01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-sea-gateway.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/SEAPSEP01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-sanutil.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-xtap2631a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-voip-4500-01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-osprey02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-app-scb01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/services01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-ctiejb-vip02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/citigw03.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-lis01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-xtap2726a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/xtap38e.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-xtap31c.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-esoap-vip01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-ctiejb-vip01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-lis03.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-xtap5e.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-ossdb01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-mq2677b.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2124.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-xtap02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-esmtp-vip02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru1131.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2110.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-encrypt03.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/spvx01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-tts02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/spmpu011.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/xtap2595c.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-xtap2779a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-esquid-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-esx10.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-xtap2723a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-esx02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/spmpu013.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-ch-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-osprey01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-soap-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/xtap2722c.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-bkup02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-winbh01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/bg-sea-gateway.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-iwi-02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-rpt-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2120.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/xtap2628b.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-xtapmc01a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-winbh02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-oltp-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/dpmpu004.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2008.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-chsoap-via-den.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2022.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/ps1903.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/spmpu010.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-lis02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-chsoap-via-sea.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-app-vip03.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-uxbh02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-dmz-em01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/dpcvt01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/services02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2006.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru1134.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2010.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-xtap99a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru1122.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-dcmstr-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/spmpu008.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-tts08.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-db16.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/xtap2749b.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2142.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-isyslog-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2012.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/evmon01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-syslog02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/xtap2595a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/spvx02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/xtap2638f.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-xtap2634c.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2106.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-xtap2683a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-xtap52a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/spmpu006.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2111.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-app-vip01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/spmpu001.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/em2355k.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/dpmpu005.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-ss-sca01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-em2698a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-esx07.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-esx11.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/spmpu004.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/ps2904.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/seaplog01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-xtap2632a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru1123.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-voip-acme-2.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-auth02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/dpdc02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-xtap2784a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/dpvx01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-ss-sca01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/xtap2638e.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-sea-voip-jnpr-2-ext.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-chapp01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-media-sca02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-soapejb-vip01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-eproxy-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2015.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/dpalm01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-auth02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-twse01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-encrypt04.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/services-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-chapp01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-xtap2476a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru1135.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/em2638g.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-uxbh02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-websrv01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2021.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-xtap2620c.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2141.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-db14.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-idns-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-uxbh01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-app-scb02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-rmanprd-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-xtap38g.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru1001.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru1136.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-soapejb-vip02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-app-vip02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-vc01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2005.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-rmanprd-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2009.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-lb-sca01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/xtap38c.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-ss-sca02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-xtap2793a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-chweb01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-den-voip-jnpr-1-ext.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-soapejb-vip01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/dpcvt02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-xtap2620a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-esx12.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-db07.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/xtap2722a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-encrypt02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/spcvt01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-xtap2795a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-ehttp-vip02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-voip-jnpr-1-ext.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-app-vip03.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/spmpu015.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/xtap2595d.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-mqa-vip01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-encrypt01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/seapstg01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/koi.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/seapdc02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/xtap102a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2119.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/spmpu019.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-xtap2644a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/dpcfg01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-db15.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-sea-gateway.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/dpstg01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-voip-jnpr-2.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-dmz-em02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/xtap102b.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2129.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-mqm-vip01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-voip-jnpr-sw.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru1116.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-xtap2638c.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-lis01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-mail-vip01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru1118.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/dpmpu006.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-srv02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-xtap2785a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-voip-jnpr-1-ext.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-chweb01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-voip-4500-02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-xtap27a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-esx12.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/dpmpu001.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-eproxy-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-db08.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2113.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-voip-jnpr-2-ext.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-lb-sca02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2003.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-ihttp-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/xtap2355b.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/xtap2706a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2019.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-app-sca01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2137.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-media-sca01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2109.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-odmz-sca01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-idns-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-esx06.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-tts06.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-xtap01-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-db15.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-xtap2764a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-dcmstr-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-ismtp-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-app-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-xtap2625c.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/xtap3d.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-esx08.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-esoap-vip01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/spmpu009.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-xtap2631e.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-xtap38h.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2147.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/spmpu012.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-esx11.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/em2355o.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-db14.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/em2777a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-ehttp-vip01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-ehttp-vip01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/em2355b.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-xtap1216a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-chsoap-via-erica.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-tts06.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-xtap2794a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-xtap2625d.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-xtap02-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-voip-acme-4500-01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-syslog01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/em2638a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-app05.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2107.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-xtap2751a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-em2698b.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-tts01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru1124.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/dpvx02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-db16.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-mq2676b.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-edns-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-mail-vip02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru1133.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-sea-voip-jnpr-1-ext.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/xtap2695g.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2103.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/em2355l.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-mqa-vip01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2145.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-xtap105a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-ecti-vip02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-lds01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-db-xtap52.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2105.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2140.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-vc02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-app-vip04.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/ps1904.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-esx08.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/dpmpu010.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/xtap2628a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-esmtp-vip02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-xtap52c.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-esx05.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-voip-jnpr-2-ext.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-encrypt01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/seapsalvo01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-lb-sca01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru1125.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-esx05.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-mail-vip01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/dpmpu007.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/em2355a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/dplog01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru1108.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2102.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/dpmpu002.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-xtap78a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-ctiejb-vip01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-osprey02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-ch-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-xtap2654a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/localhost.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-den-voip-jnpr-2-ext.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-idmz-sca01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-ctiejb-vip02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-esftp.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-ismtp-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-mqsrv52a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-esx06.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2108.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/xtap2722b.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2011.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/xtap3c.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/citigw04.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-chsoap-via-sea.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/dpvx03.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-oltp-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-mqm-vip01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-ossdb01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-voip-jnpr-sw.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-app-sca02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-app-vip01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/spcfg01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/xtap2722d.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-xtap2683c.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-psq0052.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-xtap2676b.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru1110.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-support-01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-lis03.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-syslog01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-ehttp-vip02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-app-sca04.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-esx07.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-xtap2683d.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/dpsalvo01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-tts05.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/em2355p.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-iossec-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2143.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/dpdc01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-xtap2746a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-odmz-sca02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-esx09.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-xtap2688c.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/em2638h.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-soapejb-vip02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/spmpu002.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/xtap2709b.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-esmtp-vip01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-winbh02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-esx04.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-xtap2678a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/netopsec.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-websrv02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-xtap2648a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2112.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/spmpu014.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-esmtp-vip01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2017.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/em2355d.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-lis02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/xtap38f.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-xtap2767a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/spmpu005.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-lb-sca02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-ecti-vip01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru1107.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-ecti-vip02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-twst01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-xtap2792a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/spcvt02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-vcdb-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-encrypt03.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-xtap2455e.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/xtap2695f.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-tts03.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-tts05.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/xtap2595b.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru1109.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-mq2677a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-xtap2775a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/xtap95c.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2104.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-chsoap-via-erica.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2016.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-idmz-sca02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-twse01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-encrypt04.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-xtap2787a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-esx01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-voip-acme-1.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/xtap2706b.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-esx10.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-tts04.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/seapdc01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/spmpu003.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-xtap2776a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru1117.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/em2355c.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2138.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/seagfi01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/dpmpu008.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-voip-jnpr-1.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-auth01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/xtap2695e.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2125.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-voip-acme-4500-02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-xtap2750a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-app-vip04.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-encrypt02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-ihttp-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-ecti-vip01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-esx02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-edns-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/xtap38d.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-tts07.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2117.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2146.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-uxbh01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-syslog02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-esoap-vip02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-esx09.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-xtap2676a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru1132.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-chsoap-via-den.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2014.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2133.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru1119.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2122.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2136.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-esx03.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-xtap01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2139.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-websrv03.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-koi-02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-vcdb-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2004.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/ps2903.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-bkup02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2123.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2126.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-xtap2627a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/spcvt03.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2013.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/seapalm01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-mq2676a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-xtap2629a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-winbh01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-twst01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-app-sca03.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-lds02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/dpmpu009.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/seapscsp.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2121.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-xtap2747a.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/spmpu007.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-xtap2595e.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-ihttp-vip-51.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/den-ss-sca02.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2007.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-ldm01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sea-xtap2614c.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/xtap2695h.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/vru2018.cfg'...
Processing object config directory '/usr/local/nagios/etc/services'...
Processing object config file '/usr/local/nagios/etc/services/vru1002.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2699a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2735a.cfg'...
damiancurry
Posts: 10 Joined: Thu Oct 21, 2010 4:23 pm
Post
Processing object config file '/usr/local/nagios/etc/services/dpmpu003.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-esoap-vip02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-mail-vip02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-osprey01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-sea-gateway.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-voip-4500-01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-osprey02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-app-scb01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap31c.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-esoap-vip01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-ctiejb-vip01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-lis03.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-ossdb01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-mq2677b.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/vru1131.cfg'...
Processing object config file '/usr/local/nagios/etc/services/spvx01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/spmpu011.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2779a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-esx10.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-xtap2723a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-esx02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/spmpu013.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-osprey01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-bkup02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/bg-sea-gateway.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-iwi-02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-xtapmc01a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-winbh02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/voip_hosts.cfg'...
Processing object config file '/usr/local/nagios/etc/services/dpmpu004.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-chsoap-via-den.cfg'...
Processing object config file '/usr/local/nagios/etc/services/ps1903.cfg'...
Processing object config file '/usr/local/nagios/etc/services/spmpu010.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-lis02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-chsoap-via-sea.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-app-vip03.cfg'...
Processing object config file '/usr/local/nagios/etc/services/dpcvt01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/vru1134.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-xtap99a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/vru1122.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-dcmstr-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/services/spmpu008.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-tts08.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-syslog02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/spvx02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/xtap2638f.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2634c.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2683a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/spmpu006.cfg'...
Processing object config file '/usr/local/nagios/etc/services/spmpu001.cfg'...
Processing object config file '/usr/local/nagios/etc/services/dpmpu005.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-ss-sca01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-esx11.cfg'...
Processing object config file '/usr/local/nagios/etc/services/spmpu004.cfg'...
Processing object config file '/usr/local/nagios/etc/services/seaplog01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-xtap2632a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/vru1123.cfg'...
Processing object config file '/usr/local/nagios/etc/services/dpdc02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2784a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/dpvx01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-ss-sca01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/xtap2638e.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-media-sca02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-soapejb-vip01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-eproxy-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/services/dpalm01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-auth02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-twse01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-chapp01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-xtap2476a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/vru1135.cfg'...
Processing object config file '/usr/local/nagios/etc/services/em2638g.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-uxbh02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2620c.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-app-scb02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-rmanprd-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/services/vru1001.cfg'...
Processing object config file '/usr/local/nagios/etc/services/vru1136.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-soapejb-vip02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-app-vip02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/windowschecks.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-lb-sca01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/snmpchecks.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-ss-sca02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/dpcvt02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-xtap2620a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-esx12.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-encrypt02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/spcvt01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-ehttp-vip02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/spmpu015.cfg'...
Processing object config file '/usr/local/nagios/etc/services/seapstg01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/seapdc02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/spmpu019.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2644a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/dpcfg01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-db15.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-sea-gateway.cfg'...
Processing object config file '/usr/local/nagios/etc/services/dpstg01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/vru1116.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2638c.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-lis01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/vru1118.cfg'...
Processing object config file '/usr/local/nagios/etc/services/dpmpu006.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-chweb01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-voip-4500-02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-xtap27a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-esx12.cfg'...
Processing object config file '/usr/local/nagios/etc/services/dpmpu001.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-eproxy-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-ihttp-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-app-sca01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-media-sca01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-odmz-sca01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-idns-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-esx06.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-ismtp-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-app-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2625c.cfg'...
Processing object config file '/usr/local/nagios/etc/services/spmpu009.cfg'...
Processing object config file '/usr/local/nagios/etc/services/services.cfg'...
Processing object config file '/usr/local/nagios/etc/services/spmpu012.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-esx11.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-db14.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-ehttp-vip01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-xtap1216a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-chsoap-via-erica.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-tts06.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2794a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2625d.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap02-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-voip-acme-4500-01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/em2638a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-xtap2751a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/vru1124.cfg'...
Processing object config file '/usr/local/nagios/etc/services/dpvx02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-db16.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-mq2676b.cfg'...
Processing object config file '/usr/local/nagios/etc/services/vru1133.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-mqa-vip01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-lds01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-vc02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-app-vip04.cfg'...
Processing object config file '/usr/local/nagios/etc/services/ps1904.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-esx08.cfg'...
Processing object config file '/usr/local/nagios/etc/services/dpmpu010.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-esmtp-vip02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-esx05.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-encrypt01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/seapsalvo01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/vru1125.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-mail-vip01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/dpmpu007.cfg'...
Processing object config file '/usr/local/nagios/etc/services/dplog01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/vru1108.cfg'...
Processing object config file '/usr/local/nagios/etc/services/dpmpu002.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-osprey02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-ch-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2654a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/localhost.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-idmz-sca01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-ctiejb-vip02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-chsoap-via-sea.cfg'...
Processing object config file '/usr/local/nagios/etc/services/dpvx03.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-oltp-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-mqm-vip01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-ossdb01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-app-sca02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-app-vip01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/spcfg01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/port_checks.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2683c.cfg'...
Processing object config file '/usr/local/nagios/etc/services/io_checks.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2676b.cfg'...
Processing object config file '/usr/local/nagios/etc/services/vru1110.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-lis03.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-syslog01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-app-sca04.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-esx07.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2683d.cfg'...
Processing object config file '/usr/local/nagios/etc/services/dpsalvo01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-tts05.cfg'...
Processing object config file '/usr/local/nagios/etc/services/dpdc01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-xtap2746a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-odmz-sca02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2688c.cfg'...
Processing object config file '/usr/local/nagios/etc/services/em2638h.cfg'...
Processing object config file '/usr/local/nagios/etc/services/spmpu002.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-esmtp-vip01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-xtap2678a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2648a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/spmpu014.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2767a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/spmpu005.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-lb-sca02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/proc_checks.cfg'...
Processing object config file '/usr/local/nagios/etc/services/vru1107.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-ecti-vip02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2792a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/spcvt02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-encrypt03.cfg'...
Processing object config file '/usr/local/nagios/etc/services/vru1109.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-mq2677a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2775a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-chsoap-via-erica.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-idmz-sca02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-encrypt04.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2787a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-esx01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/seapdc01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/spmpu003.cfg'...
Processing object config file '/usr/local/nagios/etc/services/#den-xtap02-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2776a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/vru1117.cfg'...
Processing object config file '/usr/local/nagios/etc/services/dpmpu008.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-voip-acme-4500-02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2750a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-ecti-vip01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-edns-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-tts07.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-uxbh01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-esx09.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2676a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/vru1132.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-chsoap-via-den.cfg'...
Processing object config file '/usr/local/nagios/etc/services/ingrian.cfg'...
Processing object config file '/usr/local/nagios/etc/services/vru1119.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sea-koi-02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-vcdb-vip.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2627a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/spcvt03.cfg'...
Processing object config file '/usr/local/nagios/etc/services/vru2013.cfg'...
Processing object config file '/usr/local/nagios/etc/services/seapalm01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-mq2676a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2629a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-winbh01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-twst01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-app-sca03.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-lds02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/dpmpu009.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-xtap2747a.cfg'...
Processing object config file '/usr/local/nagios/etc/services/spmpu007.cfg'...
Processing object config file '/usr/local/nagios/etc/services/den-ss-sca02.cfg'...
Processing object config file '/usr/local/nagios/etc/services/logchecks.cfg'...
Error: Could not find any hostgroup matching 'Q-vru' (config file '/usr/local/nagios/etc/hosts/vru2013.cfg', starting on line 14)
RET: 254
/usr/local/nagiosxi/nom/checkpoints/nagioscore/errors /usr/local/nagiosxi/scripts
tar: Removing leading `/' from member names
LATEST NOM SNAPSHOT: /usr/local/nagiosxi/nom/checkpoints/nagioscore/1290025203.tar.gz
/ /usr/local/nagiosxi/scripts
RESTORING NOM SNAPSHOT : /usr/local/nagiosxi/nom/checkpoints/nagioscore/1290025203.tar.gz
./nom_restore_nagioscore_checkpoint.sh: ./reset_config_perms: /lib/ld-linux.so.2: bad ELF interpreter: No such file or directory
[root@sea-moncon01 scripts]#
damiancurry
Post
by damiancurry » Thu Nov 18, 2010 1:21 pm
Can I please get an update on my ticket?
mguthrie
Posts: 4380 Joined: Mon Jun 14, 2010 10:21 am
Post
by mguthrie » Thu Nov 18, 2010 3:56 pm
Hopefully we've got things up and running for you again, if you encounter issues with the upgrading process go ahead and start a new thread.
